.. DO NOT EDIT. .. THIS FILE WAS AUTOMATICALLY GENERATED BY SPHINX-GALLERY. .. TO MAKE CHANGES, EDIT THE SOURCE PYTHON FILE: .. "auto_user-guide/plot_msh2vtu.py" .. LINE NUMBERS ARE GIVEN BELOW. .. only:: html .. note:: :class: sphx-glr-download-link-note :ref:`Go to the end ` to download the full example code. .. rst-class:: sphx-glr-example-title .. _sphx_glr_auto_user-guide_plot_msh2vtu.py: Meshes from gmsh (msh2vtu) ========================== .. sectionauthor:: Florian Zill (Helmholtz Centre for Environmental Research GmbH - UFZ) Here you find, how you can generate OGS-compatible meshes from a .msh file. This is accomplished by extracting domain-, boundary- and physical groups from the gmsh mesh. This requires the mesh entities to be assigned to a physical group in the gmsh mesh. .. GENERATED FROM PYTHON SOURCE LINES 14-25 .. code-block:: Python from pathlib import Path from tempfile import mkdtemp import pyvista as pv import ogstools as ot from ogstools import examples model_dir = Path(mkdtemp()) msh = examples.msh_geolayers_2d .. GENERATED FROM PYTHON SOURCE LINES 26-36 Conversion ---------- Using :func:`~ogstools.meshlib.gmsh_converter.meshes_from_gmsh` we can generate unstructured grids from a given .msh file. As OGS wants to have the MaterialIDs numbered beginning from zero, you usually want to set reindex to True. The return value is a dict with the mesh names pointing to the corresponding meshes. Here we print the filenames and the number of cells. For a purely file based approach, OGSTools also provides `msh2vtu` as a command line application. Please, call it with `--help` for info about the usage. .. GENERATED FROM PYTHON SOURCE LINES 38-41 .. code-block:: Python meshes = ot.meshes_from_gmsh(filename=msh, reindex=True, log=False) print(*[f"{name}: {mesh.n_cells=}" for name, mesh in meshes.items()], sep="\n") .. rst-class:: sphx-glr-script-out .. code-block:: none domain: mesh.n_cells=2520 physical_group_Left: mesh.n_cells=8 physical_group_Bottom: mesh.n_cells=120 physical_group_Right: mesh.n_cells=8 physical_group_Top: mesh.n_cells=120 physical_group_SedimentLayer1: mesh.n_cells=69 physical_group_SedimentLayer2: mesh.n_cells=146 physical_group_SedimentLayer3: mesh.n_cells=230 physical_group_RockBed: mesh.n_cells=2075 .. GENERATED FROM PYTHON SOURCE LINES 42-43 Let's plot the domain mesh and mark the subdomains. .. GENERATED FROM PYTHON SOURCE LINES 45-53 .. code-block:: Python domain = meshes["domain"] fig = ot.plot.contourf(domain, ot.variables.material_id, show_edges=False) style = {"size": 32, "backgroundcolor": "lightgrey", "ha": "center"} for name, mesh in meshes.items(): text_xy = [mesh.center[0], 0.5 * (mesh.center[1] + mesh.bounds[2])] fig.axes[0].annotate(name.split("_")[-1], text_xy, **style) .. image-sg:: /auto_user-guide/images/sphx_glr_plot_msh2vtu_001.png :alt: plot msh2vtu :srcset: /auto_user-guide/images/sphx_glr_plot_msh2vtu_001.png :class: sphx-glr-single-img .. GENERATED FROM PYTHON SOURCE LINES 54-60 Note regarding saving --------------------- If you want to save the meshes to be used in a OGS simulation, make sure to save the meshes in the following way, so that they are conforming to OGS standards: .. GENERATED FROM PYTHON SOURCE LINES 62-64 .. code-block:: Python for name, mesh in meshes.items(): pv.save_meshio(Path(model_dir, name + ".vtu"), mesh) .. rst-class:: sphx-glr-timing **Total running time of the script:** (0 minutes 0.364 seconds) .. _sphx_glr_download_auto_user-guide_plot_msh2vtu.py: .. only:: html .. container:: sphx-glr-footer sphx-glr-footer-example .. container:: sphx-glr-download sphx-glr-download-jupyter :download:`Download Jupyter notebook: plot_msh2vtu.ipynb ` .. container:: sphx-glr-download sphx-glr-download-python :download:`Download Python source code: plot_msh2vtu.py ` .. container:: sphx-glr-download sphx-glr-download-zip :download:`Download zipped: plot_msh2vtu.zip `
