Plot data of a sampling lines
.. sectionauthor:: Florian Zill (Helmholtz Centre for Environmental Research GmbH - UFZ)
This example provides clean coding recipes for plotting data of meshes over
sampling lines. We also present different ways to setup the sampling lines.
For plotting we us the function :py:func:`ogstools.plot.line`.
# sphinx_gallery_start_ignore
# sphinx_gallery_end_ignore
# Simple case: straight line
# We use the ``pyvista`` function ``sample_over_line`` and use two points to
# define the line and get a Mesh with the sampled data. Let's plot the Mesh and
# the line together.
sample = mesh.sample_over_line([25, -460, 0], [100, -800, 0])
fig = mesh.plot_contourf(ot.variables.temperature)
fig = ot.plot.line(sample, ax=fig.axes[0], linestyle="--")
# Now we plot the temperature data. The spatial coordinate for the x-axis is
# automatically detected here.
fig = ot.plot.line(sample, ot.variables.temperature)
# Simple case: circular arc
# With 3 points we can define an arc over which to sample the data.
# Having the arc directly on a boundary might result in some gaps in the
# sampled data, thus we extend the arc by a small margin.
sample = mesh.sample_over_circular_arc(
    pointa=[100 - 1e-4, -650, 0],
    pointb=[200 + 1e-4, -650, 0],
    center=[150, -650, 0],
fig, axs = plt.subplots(ncols=2, figsize=[26, 10])
mesh.plot_contourf(ot.variables.displacement["x"], fig=fig, ax=axs[1])
ot.plot.line(sample, ax=axs[1], lw=3, color="red")
ot.plot.line(sample, ot.variables.displacement["x"], ax=axs[0])
# Other methods to setup the sampling line
# The following section shows different methods of creating sampling lines.
# Linear spaced points
# This basically does the same as the ``pyvista`` function `sample_over_line`.
pts = np.linspace([50, -460, 0], [50, -800, 0], 100)
sample_1 = pv.PolyData(pts).sample(mesh)
# Mutilsegmented line from list of points
# The following code allows you to have a line connecting multiple observation
# points.
obs_pts = np.asarray([[150, -460, 0], [50, -650, 0], [150, -800, 0]])
pts = np.vstack([np.linspace(pt1, pt2, 50) for pt1, pt2 in pairwise(obs_pts)])
sample_2 = pv.PolyData(pts).sample(mesh)
# Spline from list of points
# You can also create smooth sampling lines by using a fitting function.
# The following creates a second order polynomial fit for the x-coordinates
# in dependence of the y-coordinates.
pts = np.asarray([[200, -460, 0], [250, -650, 0], [200, -800, 0]])
fit = np.poly1d(np.polyfit(pts[:, 1], pts[:, 0], 2))
y = np.linspace(-460, -800, 100)
pts = np.transpose([fit(y), y, y * 0])
sample_3 = pv.PolyData(pts).sample(mesh)
# Use existing geometry
# Another way to setup the sampling line is to extract points from the domain
# mesh. Here, we use the ``clip`` function from ``pyvista`` and some boolean logic,
# to extract a vertical line through the center, which follows the boundary of
# the hole.
edges = mesh.clip("x").extract_feature_edges()
is_top_bot = np.isin(edges.points[:, 1], [-800, -460])
is_left = edges.points[:, 0] == 0
pts = edges.points[np.invert(is_top_bot | is_left)]
sample_4 = pv.PolyData(pts).sample(mesh)
# Now we plot all samples for comparison.
u_x = ot.variables.displacement["x"]
mesh.plot_contourf(u_x, fig=fig, ax=axs[1])
for i, sample in enumerate([sample_1, sample_2, sample_3, sample_4]):
    c = f"C{i}"  # cycle through default color cycle
    ot.plot.line(sample, ax=axs[1], linestyle="--", color=c)
    ot.plot.line(sample, u_x, "y", ax=axs[0], label=f"sample {i + 1}", color=c)
# If you want to sample data over multiple timesteps in a MeshSeries, have a
# look at :ref:`sphx_glr_auto_examples_howto_plot_plot_timeslice.py`.
