How to plot data at observation points
.. sectionauthor:: Florian Zill (Helmholtz Centre for Environmental Research GmbH - UFZ)
timesteps. Since requested observation points don't necessarily coincide with
:py:mod:`ogstools.meshlib.mesh_series.MeshSeries.probe` for more details.
# sphinx_gallery_start_ignore
# sphinx_gallery_thumbnail_number = 2
# sphinx_gallery_end_ignore
mesh_series = examples.load_meshseries_CT_2D_XDMF().scale(time=("s", "a"))
si = ot.variables.saturation
# ..  code-block:: python
# You can also use a variable from the available presets instead of needing to
# create your own:
# :ref:`sphx_glr_auto_examples_howto_postprocessing_plot_variables.py`
# Let's define 4 observation points and plot them on the mesh.
rows = np.array([np.linspace([0, 0, z], [120, 0, z], 4) for z in [60, 40]])
fig = mesh_series.mesh(0).plot_contourf(si)
fig.axes[0].scatter(rows[..., 0], rows[..., 2], s=50, fc="none", ec="r", lw=3)
for i, pt in enumerate(rows.reshape(-1, 3)):
    fig.axes[0].annotate(str(i), (pt[0], pt[2] - 5), va="top", fontsize=32)
# And now probe the points and plot the values over time.
labels = [
    [f"{i}: x={pt[0]: >5} z={pt[2]}" for i, pt in enumerate(pts)]
    for pts in rows
ms_pts = [ot.MeshSeries.extract_probe(mesh_series, pts) for pts in rows]
fig = ot.plot.line(ms_pts[0], "time", si, labels=labels[0], monospace=True)
# You can also pass create your own matplotlib figure and pass the axes object.
# Additionally, you can pass any keyword arguments which are known by
# matplotlibs plot function to further customize the curves.
# To show, how to customize a plot afterwards, we add the mean saturation of the
# 4 observation points per row to each subplot.
fig, axs = plt.subplots(nrows=2, figsize=[16, 10], sharey=True)
ot.plot.line(ms_pts[0], "time", si, ax=axs[0], color="k", fontsize=20)
ot.plot.line(ms_pts[1], "time", si, ax=axs[1], marker="o", fontsize=20)
# add the mean of the observation point timeseries
for index in range(2):
    values = si.transform(ms_pts[index])
    mean_values = np.mean((values), axis=-1)
    ts = ms_pts[index].timevalues
    fig.axes[index].plot(ts, mean_values, "rk"[index], lw=4)
    fig.axes[index].legend(labels[index] + ["mean"], fontsize=20)
