How to compare results with reference data or an analytical solution
.. sectionauthor:: Florian Zill (Helmholtz Centre for Environmental Research GmbH - UFZ)
This example provides recipes for frequently needed plots in the OpenGeoSys
benchmark section. It is a repeating pattern, to compare numerical results with
analytical or reference data and evaluate the errors. The goal here is to have a
standardized recipe for cleaner code and less repetition.
# sphinx_gallery_start_ignore
# sphinx_gallery_thumbnail_number = 1
# sphinx_gallery_end_ignore
temp = ot.variables.temperature
# Compute the analytical solution
# Note, that the relative errors are calculated with the reference values in
# data units, i.e. in Kelvin.
results = examples.load_meshseries_diffusion_3D()
x = results[0].points[:, 0]
analytical_func = examples.anasol.heat_conduction_temperature
ref_values = np.asarray([analytical_func(x, tv) for tv in results.timevalues])
abs_error = ref_values - results["temperature"]
rel_error = abs_error / ref_values
np.testing.assert_array_less(np.abs(abs_error), 6)
np.testing.assert_array_less(np.abs(rel_error), 0.02)
results = results.scale(time=("s", "h"))
# Write the data into the results, to leverage plotting features.
results.point_data[temp.anasol.data_name] = ref_values
results.point_data[temp.abs_error.data_name] = abs_error
results.point_data[temp.rel_error.data_name] = rel_error
# Comparing data over a line for multiple timesteps
# If the resulting data is not already one-dimensional we need to extract the
# points which make up the line of interest. We can do so, by using ``extract``
# and the point indices or by using ``extract_probe`` and a set of points.
# We need to further select the timesteps we want to plot. This is done by
# indexing the MeshSeries object.
fig, axs = plt.subplots(1, 3, figsize=[40, 10])
# extract every second timestep and only the points on the x-axis
x_edge = results[::2].extract(
    (results[0].points[:, 1] == 0) & (results[0].points[:, 2] == 0)
labels = [f"{tv:.1f} h" for tv in x_edge.timevalues]
axs[0].plot([], [], "--k", label="analytical\nsolution")
ot.plot.line(x_edge, temp, ax=axs[0], marker="o", labels=labels)
ot.plot.line(x_edge, temp.anasol, ax=axs[0], ls="--")
ot.plot.line(x_edge, temp.abs_error, ax=axs[1])
ot.plot.line(x_edge, temp.rel_error, ax=axs[2])
# Comparing data of multiple points over time
# Here, we use the same strategy as before, but in the ``plot.line`` function,
# we specify, that we want to plot over the time dimension.
fig, axs = plt.subplots(1, 3, figsize=(40, 10))
pts = np.asarray([[0.1, 0, 1], [0.3, 0, 1], [0.5, 0, 1]])
probe = ot.MeshSeries.extract_probe(results, pts)
labels = ot.plot.utils.justified_labels(pts)
ot.plot.line(probe, "time", temp, ax=axs[0], marker="o", labels=labels)
ot.plot.line(probe, "time", temp.anasol, ax=axs[0], ls="--")
ot.plot.line(probe, "time", temp.abs_error, ax=axs[1])
ot.plot.line(probe, "time", temp.rel_error, ax=axs[2])
# Comparing data of a 2D slice in a contourplot
# Again, we prepare the results, by extract the 2D data, we want to inspect.
# This can be done by slicing the original 3D results and selecting the timestep
# of interest.
fig, axs = plt.subplots(1, 3, figsize=[40, 10], sharey=True)
results_y_slice = results.transform(lambda mesh: mesh.slice("y"))
y_slice = results_y_slice[results.closest_timestep(20)]
y_slice.plot_contourf(temp, fig=fig, ax=axs[0])
y_slice.plot_contourf(temp.abs_error, fig=fig, ax=axs[1])
y_slice.plot_contourf(temp.rel_error, fig=fig, ax=axs[2])
# Comparing the transient data of a line
# Here, we extract a line and plot a timeslice, to evaluate the data spatially
# and temporally.
x_edge = results.extract(
x_edge.plot_time_slice("x", "time", temp, fig=fig, ax=axs[0])
x_edge.plot_time_slice("x", "time", temp.abs_error, fig=fig, ax=axs[1])
x_edge.plot_time_slice("x", "time", temp.rel_error, fig=fig, ax=axs[2])
# We can also increase the resolution, by using a large number of probing points
# and by resampling with more timesteps. Using a logarithmic scaling for the
# time is beneficial here, as most of the changes in the results happen in the
# very beginning.
line_pts = np.linspace([0, 0, 0], [1, 0, 0], num=100)
ms_line = ot.MeshSeries.extract_probe(results, line_pts)
ms_line = ot.MeshSeries.resample(ms_line, np.geomspace(1, 3000, num=100))
for i, var in enumerate([temp, temp.abs_error, temp.rel_error]):
    ms_line.plot_time_slice(
        "time", "x", var, fig=fig, ax=axs[i], time_logscale=True
