Running OGS Simulations from Python#
OGSTools is a Python library designed to simplify the process of running
simulations with the OpenGeoSys (OGS) framework. The Project class is a core
component of OGSTools, providing a convenient interface for creating and
altering OGS6 input files up and executing OGS simulations. This allows you to
automate OGS-workflows in Python via Jupyter or just plain Python scripts.
The development of this functionality was first started in
[ogs6py](joergbuchwald/ogs6py) and is continued in OGSTools.
Here you’ll find the detailed API: ogstools.ogs6py.project.Project.
Features: - alternate existing files (e.g., for parameter sweeps) - create new input files from scratch - execute project files - tailored alteration of input files e.g. for mesh replacements or restarts - display and export parameter settings
In this guide, we will walk you through the process of using the Project class to run a simple simulation from an existing model setup. Assuming you have prepared a model with your mesh and a project file you can use the following setup, to run it from python.
results_dir = Path(mkdtemp())
prj_path_in = EXAMPLES_DIR / "prj" / "simple_mechanics.prj"
prj_path_out = results_dir / "simple_mechanics_modified.prj"
prj = ot.Project(
input_file=prj_path_in, output_file=prj_path_out, output_dir=results_dir
prj.write_input()
# as the current working directory of this notebook is not the same as the
# directory of the prj-file and the meshes, we have to tell OGS via the flag
# "-m", that the meshes are in the same directory as the input_file
# "-o" sets the output_directory
prj.run_model(args=f"-m {prj_path_in.parent} -o {results_dir}")
Simulation: /tmp/tmp521ryi31/simple_mechanics_modified.prj
Execution took 0.12925243377685547 s
Manipulating the Project#
By using a prj-file as a template and modifying it in python we have an easy way to parametrize simulations. Below are some methods, which change different parts of the model definition. For more detailed information have a look into the API.
prj.replace_parameter_value(name="E", value=1e9)
# You can achieve the same via the `replace_text` method:
prj.replace_text(1e9, xpath="./parameters/parameter[name='E']/value")
# Let's also replace the output prefix of the result
prj.replace_text("E=1e9", xpath="./time_loop/output/prefix")
# The density of a phase can also be changed
prj.replace_phase_property_value(
After modifying the Project you can execute the model in the same way as before. You have to run the write_input method beforehand again. The changes will not be reflected in the simulation otherwise. This step will be automated in the future.
Background execution#
To execute a simulation in the background, so that your python environment is not frozen until the simulation finishes, you can set background to True.
prj.write_input()
prj.run_model(background=True, args=f"-m {prj_path_in.parent} -o {results_dir}")
print(prj.status)
Status: running for 0.0012149810791015625 s.
If you want to abort the simulation for any reason, use the following command:
prj.terminate_run()
print(prj.status)
Status: terminated with error code -9.
Creating a Project from scratch#
You can also create a Project without a prj-file. Have a look at this example to see how: How to Create Simple Mechanics Problem
Total running time of the script: (0 minutes 0.146 seconds)
