Workflow with Feflowlib: Hydraulic model - conversion, simulation and post-processing
In this example we show how a simple flow/hydraulic FEFLOW model can be converted to a pyvista.UnstructuredGrid and then
be simulated in ot.
# 0. Necessary imports
import tempfile
    FeflowModel,
feflow_model = FeflowModel(feflow_model_box_Neumann, temp_dir / "boxNeumann")
feflow_model.mesh.plot(
    show_edges=True,
    off_screen=True,
    scalars="P_HEAD",
    cpos=[0, 1, 0.5],
print(feflow_model.mesh)
# 2. Extract the subdomains conditions.
# Since there can be multiple boundary conditions in the subdomains,
# they are plotted iteratively.
    if name != "topsurface":
        plotter.subplot(i, 0)
# 3. Define endtime and time stepping in the project-file.
feflow_model.setup_prj(
    end_time=int(1e8),
    time_stepping=[(1, 10), (5, 100), (10, 1000), (10, 1e6), (1, 1e7)],
# 4. Run the model
feflow_model.run()
# 5. Read the results and plot them.
ms = ot.MeshSeries(temp_dir / "boxNeumann.pvd")
# Read the last timestep:
ogs_sim_res = pv.read(temp_dir / "boxNeumann_ts_1_t_1.000000.vtu")
ogs_sim_res.plot(
    show_edges=True,
    off_screen=True,
    scalars="HEAD_OGS",
    cpos=[0, 1, 0.5],
# 5.1 Plot the hydraulic head simulated in OGS with :py:mod:`ogstools.plot.contourf`.
head = ot.variables.Scalar(data_name="HEAD_OGS", data_unit="m", output_unit="m")
fig = ot.plot.contourf(ogs_sim_res.slice(normal="z", origin=[50, 50, 0]), head)
# 6. Calculate the difference to the FEFLOW simulation and plot it.
diff = feflow_model.mesh["P_HEAD"] - ogs_sim_res["HEAD_OGS"]
feflow_model.mesh["diff_HEAD"] = diff
    show_edges=True,
    off_screen=True,
    scalars="diff_HEAD",
    cpos=[0, 1, 0.5],
# 6.1 Plot the differences in the hydraulic head with :py:mod:`ogstools.plot.contourf`.
# Slices are taken along the z-axis.
diff_head = ot.variables.Scalar(
slices = np.reshape(
    list(feflow_model.mesh.slice_along_axis(n=4, axis="z")), (2, 2)
fig = ot.plot.contourf(slices, diff_head)
    ax.set_title(f"z = {slice.center[2]:.1f} m", fontsize=32)
# 6.2 Slices are taken along the y-axis.
    list(feflow_model.mesh.slice_along_axis(n=4, axis="y")), (2, 2)
    ax.set_title(f"y = {slice.center[1]:.1f} m", fontsize=32)
