Feflowlib: How to modify the project-file after converting a FEFLOW model.
This example shows how to convert a FEFLOW model and how to modify the corresponding OGS project file and boundary meshes after conversion.
# 0. Necessary imports
import tempfile
temp_dir = Path(tempfile.mkdtemp("converted_models"))
feflow_model = ot.FeflowModel(feflow_model_2D_CT_t_560, temp_dir / "CT_model")
# 2. Get the mesh and run the FEFLOW model in OGS.
mesh = feflow_model.mesh
feflow_model.setup_prj(
    end_time=1e11, time_stepping=[(1, 1e6), (1, 1e8), (1, 1e10)]
feflow_model.run()
# 3. Plot the results.
ms = ot.MeshSeries(temp_dir / "CT_model.pvd")
ot.plot.contourf(ogs_sim_res, "single_species")
# 4. Replace the scalar pore diffusion constant by a tensor to introducec anisotropy.
# How to manipulate a prj file also is explained in this example:
# # :ref:`sphx_glr_auto_examples_howto_simulation_plot_010_simulate.py`.
tensor = """
        1e-9 1e-12
feflow_model.project.replace_phase_property_value(
    mediumid=0, component="single_species", name="pore_diffusion", value=tensor
feflow_model.save()
model_prjfile = ET.parse(temp_dir / "CT_model.prj")
ET.dump(model_prjfile)
# 5. Remove some points of the boundary mesh, which is part of the subdomains.
bounds = [0.037, 0.039, 0.003, 0.006, 0, 0]
new_bc_mesh = feflow_model.subdomains["single_species_P_BC_MASS"].clip_box(
    bounds, invert=False
feflow_model.subdomains["single_species_P_BC_MASS"] = new_bc_mesh
# 6. Run the model.
