Plotting nuclear waste heat over time
First, some minimal example usage:
import ogstools.physics.nuclearwasteheat as nuclear
repo = nuclear.repo_2020_conservative
units = {"time_unit": "yrs", "power_unit": "kW"}  # default is s and W
print("Heat at start of deposition (1 nuclear waste bundle): ")
print(f"{0:6n} yrs: {repo.heat(t=0, **units):10.1f} kW")
print("Heat after deposition complete (all nuclear waste bundles): ")
print(
    f"{repo.time_deposit('yrs'):6n} yrs: "
    f"{repo.heat(t=repo.time_deposit('yrs'), **units):10.1f} kW"
print("Heat for a timeseries: ")
time = np.geomspace(1, 1e5, num=6)
heat = repo.heat(t=time, **units)
print(
    *[f"{t:6n} yrs: {q:10.1f} kW" for t, q in zip(time, heat, strict=False)],
    sep="\n",
# Now for the plotting define the timeframe and heat models of interest.
# Also let's make a convenience function to format our plots.
time = np.geomspace(1, 1e6, num=100)
models = [model for model in nuclear.waste_types if "2016" not in model.name]
ls = ["-", "--", "-.", ":", (0, (1, 10))]
def format_ax(ax: plt.Axes):
    ax.set_xlabel("time / yrs")
    ax.set_ylabel("heat / kW")
    ax.grid(True, which="major", linestyle="-")
    ax.grid(True, which="minor", linestyle="--", alpha=0.2)
    ax.legend()
# Let's compare the heat timeseries of single containers of different nuclear
# waste types without interim storage or deposition taken into account
# (baseline=True).
fig, ax = plt.subplots(figsize=(8, 4))
for model in models:
    q = model.heat(time, baseline=True, **units)
    ax.loglog(time, q, label=model.name, lw=2.5)
format_ax(ax)
ax.set_ylim([1e-4, 5])
# The bumps in the curves stem from the different leading nuclides in the
# proxy model sequentially decaying to nothing. The leading nuclides don't
# necessarily represent actual physical nuclides, but they give a close match
# to the result of burn-off simulations. We can visualize the decay of the
# nuclides themselves as well:
fig, axs = plt.subplots(
    nrows=int(0.5 + len(models) / 2), ncols=2, figsize=(16, 8), sharex=True
axs: list[plt.Axes] = np.reshape(axs, (-1))
colors = plt.rcParams["axes.prop_cycle"].by_key()["color"]
for ax, model, color in zip(axs, models, colors, strict=False):
    ax.loglog(time, q, label=model.name, lw=2.5, c=color)
    for i, _ in enumerate(model.nuclide_powers):
        q = model.heat(time, baseline=True, ncl_id=i, **units)
        ax.loglog(time, q, label=f"Nuclide {i}", lw=1.5, c=color, ls=ls[i])
    format_ax(ax)
    ax.set_ylim([1e-4, 20])
# When taking the interim storage time and the time to fill the repository
# into account we get a linear increase of bundles adding to the total heat.
# Is is assumed, that each bundle has reached exactly the interim storage
# time at the moment it is deposited. Let's compare the different available
# repository models.
repos = [
    nuclear.repo_2020_conservative,
    nuclear.repo_2020,
    nuclear.repo_be_ha_2016,
repo_heat = [repo.heat(time, **units) for repo in repos]
ax.loglog(time, repo_heat[0], "k", label="DWR-Mix conservative", lw=2, ls=ls[0])
ax.loglog(time, repo_heat[1], "k", label="DWR-Mix + WWER + CSD", lw=2, ls=ls[1])
ax.loglog(time, repo_heat[2], "k", label="RK-BE + RK-HA", lw=2, ls=ls[2])
format_ax(ax)
ax.set_ylim([9, 25000])
fig, ax = plt.subplots(figsize=(8, 2))
ax.loglog(time, repo_heat[0], label="DWR-Mix", lw=2, c="k")
for i, _ in enumerate(nuclear.repo_2020_conservative.waste[0].nuclide_powers):
    q = nuclear.repo_2020_conservative.heat(time, ncl_id=i, **units)
    ax.loglog(time, q, label=f"Nuclide {i}", lw=1.5, c="k", ls=ls[i])
format_ax(ax)
