Read mesh from file (vtu or xdmf) into pyvista mesh
# To read your own data as a MeshSeries you can do:
# ..  code-block:: python
# MeshSeries takes as mandatory argument a str OR pathlib.Path that represents
# the location of the pvd or xdmf file. Here, we load example data and print
# the meta information:
ms
# Accessing time values
# Time values (and spatial coordinates) can be unit transformed via
# :meth:`~ogstools.meshlib.mesh_series.MeshSeries.scale`. Either pass a tuple
# to convert from the first to the second unit or pass a scaling factor.
print(f"First 3 time values are: {ms.timevalues[:3]} s.")
ms = ms.scale(time=("s", "h"))
print(f"Last time value is: {ms.timevalues[-1]} h.")
ms = ms.scale(time=3600.0)
print(f"Last time value is: {ms.timevalues[-1]} s.")
# Accessing meshes
# To get a single mesh at a specified timestep you can use the mesh() method of
# a MeshSeries object (in this example: ms). Another way to to do so is by
# indexing the MeshSeries object with brackets (ms[timestep]).
# Besides custom ogstools functions you can use all available pyvista
# functions. Here we use pyvista's plot function.
mesh_ts10 = ms.mesh(10)  # or ms[10]
# Indexing
# `MeshSeries.values("<variable_name>")`` returns a
# `numpy ndarray <https://numpy.org/doc/stable/reference/generated/numpy.ndarray.html>`_.
# It allows `multidimensional indexing on ndarrays
# <https://numpy.org/doc/stable/user/basics.indexing.html>`_.
# Typically, the first dimension is the time step, second dimension is the
# number of points/cells, and the last dimension is the number of components of
# the variable.
# By default, ``values`` would read the entire dataset. If only a subset of the
# MeshSeries should be read you can select the relevant timesteps by indexing /
# slicing the MeshSeries directly. This selection will also be adhered to if you
# read individual meshes.
# %% This mesh series has 97 time steps and 190 points.
# Temperature is a scalar, Darcy velocity is a vector with 2 components.
# Both are defined at points.
print("Entire dataset:", np.shape(ms.values("temperature")))
print("Every second timestep:", np.shape(ms[::2].values("temperature")))
print("Last two steps:", np.shape(ms[-2:].values("darcy_velocity")))
# To select points or cells you can use the ``extract`` method to specify the
# corresponding ids.
temp_at_points = ms.extract([2, 3, 4]).values("temperature")
print("Data on extracted points:", np.shape(temp_at_points))
print("Temperatures at last timestep:", temp_at_points[-1])
# You can also use pyvista dataset filters to ``transform`` the domain for the
# entire MeshSeries.
ms_right_half = ms.transform(
    lambda mesh: mesh.clip("x", mesh.center, crinkle=True)
temp_right_half = ms_right_half.values("temperature")
print("Data on clipped domain:", np.shape(temp_right_half))
# Let's plot the last timestep of the transformed MeshSeries.
fig = ms_right_half[-1].plot_contourf("temperature")
