Stress analysis
The following example from the ogs benchmark collection is used for the
stress analysis:
<https://www.opengeosys.org/docs/benchmarks/thermo-mechanics/creepafterexcavation/>
# sphinx_gallery_start_ignore
# sphinx_gallery_thumbnail_number = -3
# sphinx_gallery_end_ignore
fig = mesh.plot_contourf(ot.variables.displacement)
# Tensor components
# We can inspect the stress (or strain) tensor components by indexing.
fig = mesh.plot_contourf(ot.variables.stress["xx"])
fig = mesh.plot_contourf(ot.variables.stress["xy"])
# Principal stresses
# Let's plot the the principal stress components and also overlay the direction
# of the corresponding eigenvector in the plot. Note: the eigenvalues are sorted
# by increasing order, i.e. eigenvalue[0] is the most negative / largest
# compressive principal stress.
eigvecs = ot.variables.stress.eigenvectors
fig = mesh.plot_contourf(variable=ot.variables.stress.eigenvalues[0])
mesh.plot_quiver(ax=fig.axes[0], variable=eigvecs[0], glyph_type="line")
fig = mesh.plot_contourf(variable=ot.variables.stress.eigenvalues[1])
mesh.plot_quiver(ax=fig.axes[0], variable=eigvecs[1], glyph_type="line")
fig = mesh.plot_contourf(variable=ot.variables.stress.eigenvalues[2])
mesh.plot_quiver(ax=fig.axes[0], variable=eigvecs[2], glyph_type="line")
# We can also plot the mean of the principal stress, i.e. the magnitude of the
# hydrostatic component of the stress tensor.
# see: :py:func:`ogstools.variables.tensor_math.mean`
fig = mesh.plot_contourf(ot.variables.stress.mean)
# Von Mises stress
# see: :py:func:`ogstools.variables.tensor_math.von_mises`
fig = mesh.plot_contourf(ot.variables.stress.von_Mises)
# octahedral shear stress
# see: :py:func:`ogstools.variables.tensor_math.octahedral_shear`
fig = mesh.plot_contourf(ot.variables.stress.octahedral_shear)
# Stresses in polar coordinates
# You can inspect stresses in a polar coordinate system by deriving a new
# Variable from the stress Variable. Specify the polar center and, if needed,
# the rotation axis (default is z-axis: [0, 0, 1]).
polar_stress = ot.variables.stress.to_polar(center=(150, -650, 0))
fig = mesh.plot_contourf(polar_stress["rr"])
fig = mesh.plot_contourf(polar_stress["tt"])
fig = mesh.plot_contourf(polar_stress["pp"])
# Here is a 3D example with a cylindrical hole at (0, 0, 0) in y direction:
mesh_3D = examples.load_mesh_mechanics_3D_sphere()
polar_stress_3D = ot.variables.stress.to_polar()
for comp in ["rr", "tt", "pp"]:
    pl = mesh_3D.plot_contourf(polar_stress_3D[comp])
    pl.view_xz()
    pl.show()
# Integrity criteria
# Evaluating models regarding their integrity is often dependent on the
# geometry, e.g. for a hypothetical water column proportional to the depth.
# Presets which fall under this category make use of
# :py:mod:`ogstools.variables.mesh_dependent`.
# The hypothetical water column used in the integrity criteria would initially
# use existing "pressure" data in the mesh, otherwise it is automatically
# calculated as the following:
mesh["pressure"] = mesh.p_fluid()
fig = mesh.plot_contourf(ot.variables.pressure)
# But since this assumes that the top of the model is equal to the ground
# surface, the resulting pressure is underestimated. In this case we have to
# correct the depth manually. Then the pressure is calculated correctly:
mesh["depth"] = mesh.depth(use_coords=True)
fig = mesh.plot_contourf("depth")
# Dilantancy criterion
# see: :py:func:`ogstools.variables.mesh_dependent.dilatancy_critescu`
fig = mesh.plot_contourf(ot.variables.dilatancy_critescu_tot)
fig = mesh.plot_contourf(ot.variables.dilatancy_critescu_eff)
# Fluid pressure criterion
# see: :py:func:`ogstools.variables.mesh_dependent.fluid_pressure_criterion`
fig = mesh.plot_contourf(ot.variables.fluid_pressure_crit)
