How to create Animations
To demonstrate the creation of an animated plot we use a component transport
example from the ogs benchmark gallery
ms = examples.load_meshseries_CT_2D_XDMF().scale(time=("s", "yrs"))
# ..  code-block:: python
# You can choose which timesteps to render by either slicing the MeshSeries or
# by resampling it to new timesteps (this interpolates between existing
# timesteps).
# this would only use every second timesteps for animation
# ms = ms[::2]
# this uses equally spaced timesteps for a smooth animation
timevalues = np.linspace(ms.timevalues[0], ms.timevalues[-1], num=21)
ms = ot.MeshSeries.resample(ms, timevalues)
# Now, let's animate the saturation solution. Note that rendering many frames in
# conjunction with large meshes might take a really long time. You need to setup
# a matplotlib figure first and a function, which is executed on each frame.
# This function has to take the individual values of the sequences passed as
# additional arguments, in this case the timevalues and the MeshSeries.
# clip to the right half
ms_r = ms.transform(lambda mesh: mesh.clip("-x", [-1, 0, 0]))
# create initial figure with fixed colorbar
fig = ot.plot.contourf(ms_r[0], saturation, vmin=0, vmax=100, dpi=50)
def plot_contourf(timevalue: float, mesh: ot.Mesh) -> None:
    fig.axes[0].clear()
    ot.plot.contourf(mesh, saturation, ax=fig.axes[0], dpi=50)
anim = ot.plot.animate(fig, plot_contourf, ms_r.timevalues, ms_r)
# You can also use any other function to create an animation this way.
# Just make sure, that the function arguments and those passed to the animation
# call fit together.
ms_x = ms.transform(
    lambda mesh: mesh.sample_over_line([0, 0, 60], [150, 0, 60])
fig = ot.plot.line(ms_x[0], ot.variables.saturation)
def plot_line(mesh: ot.Mesh) -> None:
    fig.axes[0].clear()
    ot.plot.line(mesh, saturation, ax=fig.axes[0])
    fig.axes[0].set_ylim([0, 100])
anim = ot.plot.animate(fig, plot_line, ms_x)
# The animation can be saved (as mp4) like so:
#   ot.plot.utils.save_animation(anim, "Saturation", fps=5)
# sphinx_gallery_start_ignore
# note for developers:
# unfortunately when creating the documentation the animation is run twice:
# once for saving a thumbnail and another time for generating the html_repr
# see .../site-packages/sphinx_gallery/scrapers.py", line 234, 235
# sphinx_gallery_end_ignore
