Creating a BHE mesh (Borehole Heat Exchanger)
# This example demonstrates how to create a Borehole Heat Exchanger (BHE) mesh.
from shapely import Polygon
from ogstools.meshes.gmsh_BHE import BHE, Groundwater, gen_bhe_mesh
# Introduction
# This example shows the general usage of :func:`ogstools.meshes.gmsh_BHE.gen_bhe_mesh` and how some of
# the parameters will effect the mesh. This section demonstrates the mesh
# generation with only three soil layers, groundwater flow in one layer
# and three BHE's. However, this tool provides multiple soil layers,
# groundwater flow in multiple layers and multiple BHE's. The mesh sizes
# provides good initial values for the most Heat-Transport-BHE simulations
# in OGS. They can also be set by the user, to customize the mesh.
# Feel free to try it out!
# Create a simple prism mesh
# Generate a customizable prism BHE mesh:
bhe_meshes = gen_bhe_mesh(
    model_area=Polygon.from_bounds(xmin=0, ymin=0, xmax=150, ymax=100),
    layer=[50, 50, 50],
    groundwater=Groundwater(
        begin=-30,
        isolation_layer_id=1,
        upstream=(179, 181),
        downstream=(359, 1),
    BHE_Array=[
    refinement_area=Polygon.from_bounds(xmin=40, ymin=30, xmax=60, ymax=70),
    meshing_type="prism",
    meshname="bhe_prism",
# Load the domain mesh and all submeshes, extract the BHE lines and visualize it all:
def load_and_plot(bhe_meshes: ot.Meshes):
    bhe_line = bhe_meshes.domain.extract_cells_by_type(pv.CellType.LINE)
    offsets = [(0, 0, 10), (0, 0, -10), (10, 0, 0), (-10, 0, 0)]
    plotter = ot.plot.contourf(
        bhe_meshes.domain.clip("x", bhe_line.center, crinkle=True),
        ot.variables.material_id,
    plotter.add_mesh(bhe_meshes.domain, style="wireframe", color="grey")
    plotter.add_mesh(bhe_line, color="r", line_width=3)
    for submesh, offset in zip(
        bhe_meshes.subdomains.values(), offsets, strict=True
        plotter.add_mesh(
            submesh.translate(offset), show_edges=True, color="lightgrey"
load_and_plot(bhe_meshes)
# Create a simple structured mesh
# Generate a customizable structured BHE mesh:
    layer=[50, 50, 50],
        begin=-30,
    BHE_Array=[
    meshing_type="structured",
    meshname="bhe_prism_2",
# Load the domain mesh and all submeshes as well as extract the BHE lines:
# Create an advanced structured mesh
# Generate a customizable structured BHE mesh with advanced mesh
# sizing options (using gmsh). By adding additional points to the model_area,
# the subdivison of the surface by the structured mesh algorithm is controlled.
# To understand the specific behaviour of every mesh parameter,
# test each one after another.
# .. image:: ../../examples/howto_preprocessing/gen_bhe_mesh.svg
    # add additional points for better subsidivision of the surface by structured algorithm
    # compare with previous example, to see the difference
    model_area=Polygon(
            (0.0, 0.0),
            (40.0, 0.0),
            (60.0, 0.0),
            (150.0, 0.0),
            (150.0, 100.0),
            (60.0, 100.0),
            (40.0, 100.0),
            (0.0, 100.0),
    layer=[50, 50, 50],
        begin=-30,
    BHE_Array=[
        BHE(50, 40, -1, -60, 0.076),
        BHE(50, 50, -1, -60, 0.076),
        BHE(50, 60, -1, -60, 0.076),
    target_z_size_coarse=10,  # default value 7.5
    target_z_size_fine=2,  # default value 1.5
    n_refinement_layers=1,  # default value 2
    propagation=1.2,  # default value 1.1
    inner_mesh_size=8,  # default value 5
    outer_mesh_size=12,  # default value 10
    meshname="bhe_structured",
