Logparser: Introduction
This simple example demonstrates how to analyze the OGS (OpenGeoSys) log output to
extract performance information regarding various computational parts of OGS.
Here we utilize the project file from the benchmark titled:
`OGS: Constant viscosity (Hydro-Thermal)
<https://www.opengeosys.org/docs/benchmarks/hydro-thermal/constant-viscosity>`_
# Complete example
# For detailed explanation see all sections below.
from ogstools.examples import log_const_viscosity_thermal_convection
df_ts_it
# The log file
# Running ``ogs`` in the command line outputs the logs into the console output. With
# `tee
# <https://en.wikipedia.org/wiki/Tee_(command)>`_ in Linux and Mac
# and
# `Tee-Object
# <https://learn.microsoft.com/en-us/powershell/module/microsoft.powershell.utility/tee-object?view=powershell-7.4>`_
# in Windows Powershell the log gets directed into a file and into the console.
# * **Linux/Mac**: ``ogs <your_prj_file> | tee <your_log_file>``
# * **Windows**: ``ogs <your_prj_file> | Tee-Object -FilePath <your_log_file>``
# For first step we recommend to use either **`ogs -l info`** or `ogs - l debug`.
# Make sure the log file does not contain
# `ANSI escape (e.g.color) code
# <https://en.wikipedia.org/wiki/ANSI_escape_code>`_.
# You can remove it with: ``cat ogs.log | sed 's/\x1b\[[0-9;]*m//g' > ogs.log``
# Parsing steps
# The functions :py:mod:`ogstools.logparser.parse_file` and
# :py:mod:`ogstools.logparser.fill_ogs_context` are explained in
# :ref:`sphx_glr_auto_examples_howto_logparser_plot_102_logparser_advanced.py`.
# All predefined analyses need the result of fill_ogs_context.
# Here ``const_viscosity_thermal_convection_log`` is string representing the
# location of the ogs log file.
# Use predefined analyses
# :py:mod:`ogstools.logparser.time_step_vs_iterations` is one of many predefined
# analyses. All possibilities are shown here:
# :ref:`sphx_glr_auto_examples_howto_logparser_plot_101_logparser_analyses.py`.
# Here we are interested in every time step of the simulation and how many
# iterations have been needed.
# The predefined analyses only work with logs from ``ogs`` run with level ``info`` or finer (`debug`), like `ogs -l info` or `ogs - l debug`.
# (see
# `OGS Developer Guide - log and debug output
# <https://www.opengeosys.org/docs/devguide/advanced/log-and-debug-output>`_
df_ts_it
# Pandas to plot
# You can directly use
# ``plot``
# <https://pandas.pydata.org/pandas-docs/stable/reference/api/pandas.DataFrame.plot.html>`_ from pandas.
ax = df_ts_it.plot(
    y="iteration_number", xlabel="time_step", grid=True, legend=False
df_ts_it.plot(
    y="step_start_time",
    xlabel="time_step",
    ax=ax,
    secondary_y=True,
    grid=True,
    legend=False,
ax.set_ylabel("iteration number")
ax.yaxis.label.set_color("C0")  # colour matches the left line
ax.tick_params(axis="y", colors="C0")
ax_right = ax.right_ax
ax_right.set_ylabel("simulation time")
ax_right.yaxis.label.set_color("C1")
ax_right.tick_params(axis="y", colors="C1")
lines, labels = ax.get_legend_handles_labels()
lines2, labels2 = ax_right.get_legend_handles_labels()
ax.legend(lines + lines2, labels + labels2, loc="upper left")
