Visualizing 2D model data
example. In the ``plot.setup`` we can provide a dictionary to map names
:py:obj:`ogstools.plot.plot_setup.PlotSetup`. Some of these options are also
:py:obj:`ogstools.plot.contourplots.contourf` for more information.
ot.plot.setup.material_names = {i + 1: f"Layer {i+1}" for i in range(26)}
ms = examples.load_meshseries_THM_2D_PVD().scale(spatial="km")
mesh = ms.mesh(1)
# ..  code-block:: python
#   mesh_series = ot.MeshSeries("filepath/filename_pvd_or_xdmf", "km")
# Plotting Cell Data
# First, let's plot the material ids, which is part of the mesh's cell_data.
# Per default in the setup, this will automatically show the element edges.
# Plotting Point Data
# Now, let's plot the temperature field (point_data) at the first timestep.
# The default temperature variable from the ``variables`` reads the temperature
# data as Kelvin and converts them to degrees Celsius. This also shows how to
# only plot a specific part of the model by creating a clip with
# `pyvista.clip_box` beforehand.
part = mesh.clip_box(bounds=[2, 5, -1.1, -0.7, 6, 7], invert=False)
fig = ot.plot.contourf(part, ot.variables.temperature, show_max=True)
# We can also plot components of vector variables:
    mesh, ot.variables.displacement[0], show_min=True, show_max=True
fig = ot.plot.contourf(mesh, ot.variables.displacement[1], show_max=True)
# To have a continuous colormap instead of discrete colors per level pass a
# the equally named argument. In this case this helps to increase the level
# of detail of the negative displacements due to the bilinear colormap.
fig = ot.plot.contourf(mesh, ot.variables.displacement[1], continuous_cmap=True)
# Plotting with deactivated subdomains
# This example has hydraulically deactivated subdomains, which will mask the
# related variables.
fig = ot.plot.contourf(mesh, ot.variables.pressure.get_mask(), fontsize=40)
fig = ot.plot.contourf(mesh, ot.variables.pressure)
# Plotting vector data
# Let's plot the fluid velocity field. As this is vectorial data, this will
# automatically add streamlines to indicate the vector directions.
fig = ot.plot.contourf(mesh, ot.variables.velocity, show_region_bounds=False)
# Let's plot it again, this time log-scaled.
fig = ot.plot.contourf(mesh, ot.variables.velocity, log_scaled=True, vmin=-8)
