Aggregation of Meshseries Data
In this example we show how to aggregate data in a model over all timesteps as
well as plot differences between to timesteps. For this purpose we use
a component transport example from the ogs benchmark gallery
To see this benchmark results over all timesteps have a look at
:ref:`sphx_glr_auto_examples_howto_plot_plot_animation.py`.
mesh_series = examples.load_meshseries_CT_2D_XDMF().scale(time="a")
# ..  code-block:: python
# You can also use a variable from the available presets instead of needing to
# create your own:
# :ref:`sphx_glr_auto_examples_howto_postprocessing_plot_variables.py`
# You aggregate the data in MeshSeries over all timesteps given some
# aggregation function, e.g. np.min, np.max, np.var
# (see: :meth:`~ogstools.MeshSeries.aggregate_temporal`).
# The following code gets the maximum saturation for each point in the mesh over
# all timesteps and plots it. Note: the data in the returned mesh has a suffix
# equal to the aggregation functions name. The plot function will find the
# correct data anyway if given the original variable
mesh = mesh_series.aggregate_temporal(saturation, np.max)
fig = ot.plot.contourf(mesh, saturation)
# It is also possible to plot the time when the minimum or maximum occurs.
# However, here we have to use a new variable for the plot to handle the
# units correctly:
mesh = mesh_series.time_of_max(saturation)
    mesh, ot.variables.Scalar("max_Saturation_time", "a", "a")
# Likewise we can calculate and visualize the variance of the saturation:
mesh = mesh_series.aggregate_temporal(saturation, np.var)
# Difference between the last and the first timestep:
mesh = ot.mesh.difference(mesh_series.mesh(-1), mesh_series.mesh(0), saturation)
# It's also possible to aggregate the data per timestep to return a timeseries
# of e.g. the max or mean value of a variable in the entire domain.
mean_satuarion_array = mesh_series.aggregate_spatial(saturation, np.mean)
# Instead of calculating the array itself, you can also plot it directly by
# using methods of the Variable which correspond to the equally named
# ``numpy``-functions. The following are available:
# ``min``, ``max``, ``mean``, ``median``, ``sum``, ``std``, ``var``.
fig = mesh_series.plot_line(saturation.std)
