Logparser: Advanced topics
We address to following:
1. Handling OGS logs from parallel computation (OGS with MPI runs).
2. Reduce computation time required for log processing.
3. Creating custom analyses.
Although these topics are discussed together, they are independent of each
other and can be utilized separately as needed.
    debug_parallel_3,
# Logs from parallel computations (with MPI)
# The log file to be investigated in this example is the result of a mpirun (-np 3) from https://gitlab.opengeosys.org/ogs/ogs/-/blob/master/Tests/Data/EllipticPETSc/cube_1e3_XDMF_np3.prj
records = ot.logparser.parse_file(debug_parallel_3)
df_records
df_ts = ot.logparser.analysis_time_step(df_records)
df_ts
# Aggregate measurements over all MPI processes
# If you are not particularly interested in the performance of each MPI_process pandas gives you all you need to further process data. However, for performance measurement it is recommended to consider always the slowest MPI_process for meaningful interpretation of overall performance (because of synchronization barriers in the evaluation scheme of OGS).
# Then the resulting DataFrame has the same structure like a DataFrame gained from serial OGS log.
# Reduce computation time to process logs
# To reduce the computation to evaluate the logs, you can either
# - Reduce set of regular expressions, when you exactly know, what you final analysis will need AND / OR
# - Save and load the pandas.DataFrame for the records.
# Reduce regular expression
# The logparser tries to find matching regular expressions for each line. By default it iterates over all entries specified in :py:mod:`ogstools.logparser.ogs_regexes`.
# You can reduce it to the amount of entries you are actually interested in.
# For this example we are only interested in the number of iterations per time step.
# Because the parsing process is expensive, it is useful to store the records to a file.
# According to :py:mod:`ogstools.logparser.parse_file`
# via parameter ``regexes`` a list of reduced or custom regexes can be provided.
# Save and load records
# We recommend saving the records by any of these methods http://pandas.pydata.org/pandas-docs/stable/user_guide/io.html.
# For example with HDF:
# ```python
# df_records.to_hdf("anyfilename.csv")
# pd.read_hdf("anyfilename.csv")
# Custom analyses
# Introduction into functions of the logparser
# The function :py:mod:`ogstools.logparser.parse_file` iterates over all lines in the log file. For a specific set of regular expressions it finds and creates a new entry into a list (here named records)
    print(log_file.read())
print(df_records.columns)
df_records
df_log
# Custom analyses - example
# We create a pivot_table where for each time step we can see the step_size and the number of iterations.
df_custom
