Spatial & temporal refinement - nuclear decay
:py:mod:`ogstools.physics.nuclearwasteheat` model.
`Nasa convergence reference
<https://www.grc.nasa.gov/www/wind/valid/tutorial/spatconv.html>`_
`More comprehensive reference
<https://curiosityfluids.com/2016/09/09/establishing-grid-convergence/>`_
At least three meshes from simulations of increasing refinement are
required for the convergence study. The third finest mesh is chosen per default
as the topology to evaluate the results on.
The results to analyze are generated on the fly with the following code. If you
are only interested in the convergence study, please skip to
`Temperature convergence at maximum heat production (t=30 yrs)`_.
First, the required packages are imported and a temporary output directory is
created:
from ogstools import examples, physics, studies, workflow
temp_path = Path(mkdtemp(prefix="nuclear_decay"))
# Let's run the different simulations with increasingly fine spatial and
# temporal discretization via ogs6py. The mesh and its boundaries are generated
# easily via gmsh and :class:`~ogstools.Meshes`. :meth:`~ogstools.Meshes.from_gmsh`.
# First some definitions:
n_refinements = 4
prefix = "stepsize_{0}"
sim_results = []
msh_path = temp_path / "rect.msh"
script_path = Path(examples.pybc_nuclear_decay).parent
# Now the actual simulations:
for dt, n_cells in zip(time_step_sizes, edge_cells, strict=False):
    ot.gmsh_tools.rect(
        lengths=100.0, n_edge_cells=(n_cells, 1), out_name=msh_path
    meshes = ot.Meshes.from_gmsh(msh_path, log=False)
    mesh_path = temp_path / f"dt_{dt}_n_cells_{n_cells}"
    mesh_path.mkdir(parents=True, exist_ok=True)
    meshes.save(mesh_path)
    prj = ot.Project(output_file=temp_path / "default.prj", input_file=prj_path)
    prj.replace_text(str(dt * sec_per_yr), ".//delta_t")
    prj.replace_text(prefix.format(dt), ".//prefix")
    prj.write_input()
    ogs_args = f"-m {mesh_path} -o {temp_path} -s {script_path}"
    prj.run_model(write_logs=False, args=ogs_args)
    sim_results += [temp_path / (prefix.format(dt) + "_domain.xdmf")]
# %% plotting:
# Let's extract the temperature evolution and the applied heat via vtuIO and
# plot both:
for sim_result, dt in zip(sim_results, time_step_sizes, strict=False):
    ms = ot.MeshSeries(sim_result, time_unit="yrs")
    max_T = ot.variables.temperature.max.transform(ms)
    ax1.plot(ms.timevalues, max_T, lw=1.5, label=f"{dt=}")
    edges = np.append(0, ms.timevalues)
ax1.set(ylabel="max T / °C")
ax2.set(xlabel="time / yrs", ylabel="heat / kW")
ax1.legend()
ax2.legend()
# Temperature convergence at maximum heat production (t=30 yrs)
# The grid convergence at this timepoint deviates significantly from 1,
# meaning the convergence is suboptimal (at least on the left boundary where the
# heating happens). The chosen timesteps are still to coarse to reach an
# asymptotic range of convergence. The model behavior at this early part of the
# simulation is still very dynamic and needs finer timesteps to be captured with
# great accuracy. Nevertheless, the maximum temperature converges quadratically,
# as expected.
report_name = temp_path / "report.ipynb"
    output_name=report_name,
    mesh_paths=sim_results,
    timevalue=30 * sec_per_yr,
    variable_name="temperature",
    refinement_ratio=2.0,
# Temperature convergence at maximum temperature (t=150 yrs)
# The temperature convergence at this timevalue is much closer to 1, indicating
# a better convergence behaviour, which is due to the temperature gradient now
# changing only slowly. Convergence order is again quadratic.
    timevalue=150 * sec_per_yr,
# Convergence evolution over all timesteps
# We can also run the convergence evaluation on all timesteps and look at the
# relative errors (between finest discretization and Richardson extrapolation)
# and the convergence order over time to get a better picture of the transient
# model behavior.
ms = [ot.MeshSeries(sim_result) for sim_result in sim_results]
    ms, ot.variables.temperature, units=["s", "yrs"]
# Looking at the errors, we see a higher error right at the beginning.
# This is likely due to the more dynamic behavior at the beginning.
# A look at the convergence order evolution shows almost quadratic convergence
# over the whole timeframe. For the maximum temperature we even get better than
# quadratic behavior, which is coincidentally and most likely model dependent.
