Meshes from gmsh (msh2vtu)
Here you find, how you can generate OGS-compatible meshes from a .msh file.
This is accomplished by extracting domain-, boundary- and physical groups
from the gmsh mesh. This requires the mesh entities to be assigned to a physical
group in the gmsh mesh.
model_dir = ot.definitions.temp_dir("msh2vtu", "user-guide")
msh = examples.msh_geolayers_2d
# Conversion
# Using :class:`~ogstools.Meshes`. :meth:`~ogstools.Meshes.from_gmsh` we can
# generate unstructured grids from a given .msh file. As OGS wants to have the
# MaterialIDs numbered beginning from zero, you usually want to set reindex to
# True. The return value is a dict with the mesh names pointing to the
# corresponding meshes. Here we print the filenames and the number of cells. For
# a purely file based approach, OGSTools also provides `msh2vtu` as a command
# line application. Please, call it with `--help` for info about the usage.
meshes = ot.Meshes.from_gmsh(filename=msh, reindex=True, log=False)
print(*[f"{name}: {mesh.n_cells=}" for name, mesh in meshes.items()], sep="\n")
# Let's plot the domain mesh and mark the subdomains.
domain = meshes["domain"]
fig = ot.plot.contourf(domain, ot.variables.material_id, show_edges=False)
style = {"size": 32, "backgroundcolor": "lightgrey", "ha": "center"}
    text_xy = [mesh.center[0], 0.5 * (mesh.center[1] + mesh.bounds[2])]
    fig.axes[0].annotate(name.split("_")[-1], text_xy, **style)
# Note regarding saving
# If you want to save the meshes to be used in a OGS simulation, make sure
# to save the meshes in the following way, so that they are conforming to OGS
# standards:
meshes.save(model_dir)
