Run a simulation
OGSTools is a Python library designed to simplify the process of running
simulations with the OpenGeoSys (OGS) framework. The `Project` class is a core
component of OGSTools, providing a convenient interface for creating and
altering OGS6 input files up and executing OGS simulations. This allows you to
automate OGS-workflows in Python via Jupyter or just plain Python scripts.
The development of this functionality was first started in
[ogs6py](https://github.com/joergbuchwald/ogs6py/) and is continued in OGSTools.
Here you'll find the detailed API: :py:obj:`ogstools.ogs6py.project.Project`.
Features:
- alternate existing files (e.g., for parameter sweeps)
- create new input files from scratch
- execute project files
- tailored alteration of input files e.g. for mesh replacements or restarts
- display and export parameter settings
In this guide, we will walk you through the process of using the `Project` class
and then run a simple simulation from an existing model setup.
Assuming you have prepared a model with your mesh and a project file you can
use the following setup, to run it from python.
**Choosing the OGS binary**
Execution details (which OGS binary to use, MPI settings, logging, …) are
controlled via :py:class:`ogstools.core.execution.Execution`.  Pre-built OGS
binaries and container images for each release are available at
`<https://www.opengeosys.org/6.5.7/releases/>`_.
To apply site-wide defaults on a shared system (e.g. HPC cluster), set the
``OGS_EXECUTION_DEFAULTS`` environment variable to a YAML file that overrides
only the keys you need::
    export OGS_EXECUTION_DEFAULTS=/path/to/my_defaults.yaml
See :py:class:`ogstools.core.execution.Execution` for the full list of options.
results_dir = ot.definitions.temp_dir(prefix="simulate", dir="examples")
prj_path_in = ot.definitions.EXAMPLES_DIR / "prj" / "simple_mechanics.prj"
prj_path_out = results_dir / "simple_mechanics_modified.prj"
prj = ot.Project(
    input_file=prj_path_in, output_file=prj_path_out, output_dir=results_dir
model = ot.Model(prj, meshes=ot.definitions.EXAMPLES_DIR / "prj")
sim = model.run()
# Optionally save the simulation data
sim.save()
print(sim)
# Manipulating the Project
# By using a prj-file as a template and modifying it in python we have an easy
# way to parametrize simulations. Below are some methods, which change
# different parts of the model definition. For more detailed information have
# a look into the API.
# The subsequent code would work but for clarity we recommend saving 2 different states of the prj object into 2 different files.
# Either tell that you are going to change prj object (prj.copy) OR do prj.save() after you have changed but before you run the simulation.
prj2 = prj.copy()
prj2.replace_parameter_value(name="E", value=1e9)
# You can achieve the same via the `replace_text` method:
prj2.replace_text(1e9, xpath="./parameters/parameter[name='E']/value")
# Let's also replace the output prefix of the result
prj2.replace_text("E=1e9", xpath="./time_loop/output/prefix")
# The density of a phase can also be changed
prj2.replace_phase_property_value(
# After modifying the Project you can execute the model in the same way as
# before. You have to prj.save(new_name) here, or beforehand by prj2.copy.
model2 = ot.Model(prj2, meshes=model.meshes)
sim = model2.run()
print(sim)
# Alternatively, for more control
simc = model2.controller()  # this call is not blocking
simc.terminate()  # do something while the simulation is running
simc.run()  # this call is blocking, it waits for the simulation to finish
# .. image:: /examples/howto_simulation/bokeh_logs.png
#    :alt: Bokeh log plot
# Creating a Project from scratch
# You can also create a Project without a prj-file. Have a look at this example
# to see how: :ref:`sphx_glr_auto_examples_howto_prjfile_plot_creation.py`
