Feflowlib: How to modify boundary conditions after conversion of a FEFLOW model.
This example shows how boundary conditions can be modified after converting a FEFLOW model.
First we will change the values of the boundary conditions and later we will show how to define a new boundary mesh.
# 0. Necessary imports
from ogstools.feflowlib import assign_bulk_ids
temp_dir = ot.definitions.temp_dir("converted_models", "examples")
feflow_model = ot.FeflowModel(feflow_model_2D_HT, temp_dir / "HT_model")
mesh = feflow_model.mesh
print(mesh)
# 2. Plot the temperature simulated in FEFLOW on the mesh.
fig = ot.plot.contourf(mesh, "P_TEMP", show_edges=True)
# 3. As the FEFLOW data now are a pyvista.UnstructuredGrid, all pyvista functionalities can be applied to it.
# Further information can be found at https://docs.pyvista.org/version/stable/user-guide/simple.html.
# For example it can be saved as a VTK Unstructured Grid File (\*.vtu).
# This allows to use the FEFLOW model for ``OGS`` simulation or to observe it in ``Paraview```.
ot.mesh.save(mesh, temp_dir / "HT_mesh.vtu")
# 4. Run the FEFLOW model in OGS.
feflow_model.run()
ms = ot.MeshSeries(temp_dir / "HT_model.pvd")
# 5. Plot the temperature simulated in OGS.
# 6. The boundary meshes are manipulated to alter the model.
# The original boundary conditions are shown in this example: :ref:`sphx_glr_auto_examples_howto_conversions_plot_F_feflowlib_HT_simulation.py`
# 6.1 The Dirichlet boundary conditions for the hydraulic head are set to 0. Therefore, no water flows from the left to the right edge.
bc_flow = feflow_model.subdomains["P_BC_FLOW"]["P_BC_FLOW"]
feflow_model.subdomains["P_BC_FLOW"]["P_BC_FLOW"][bc_flow == 10] = 0
# 6.2 Overwrite the new boundary conditions and run the model.
# 6.3 The corresponding simulation results look like.
# Read the last timestep:
# 6.4 Create a new boundary mesh and overwrite the existing subdomains with this boundary mesh.
assign_bulk_ids(mesh)
# Get the points of the bulk mesh to build a new boundary mesh.
wanted_pts = [1492, 1482, 1481, 1491, 1479, 1480, 1839, 1840]
new_bc = mesh.extract_points(
    [pt in wanted_pts for pt in mesh["bulk_node_ids"]],
    adjacent_cells=False,
    include_cells=False,
new_bc["bulk_node_ids"] = np.array(wanted_pts, dtype=np.uint64)
# Define the temperature values of these points.
new_bc["P_BC_HEAT"] = np.array([300] * len(wanted_pts), dtype=np.float64)
feflow_model.subdomains["P_BC_HEAT"] = new_bc
# 7. Run the new model and plot the simulation results.
