OGSTools Framework - Complete Workflow Guide
This guide demonstrates the complete OGSTools workflow for setting up, running,
and analyzing OpenGeoSys (OGS) simulations. It helps to get an overview of
how the different components work together.
Workflow Overview
1. **Setup**: Load or create Project files and Meshes
2. **Compose**: Combine components into a Model with Execution settings
3. **Run**: Execute simulations and get Results
4. **Analyze**: Visualize and examine simulation outputs
5. **Store**: Save and reload simulation data for later use
For detailed information on each component, see the linked examples throughout this guide.
from ogstools.examples import load_meshes_simple_lf, load_project_simple_lf
# 1. Setup: Project Files and Meshes
# The first step is to prepare your simulation inputs. OGSTools provides two main
# components for this:
# - **Project Files** (:py:class:`~ogstools.Project`): Contains the simulation configuration (process type, parameters, boundary conditions, etc.) based on OGS .prj files (XML-format).
# - **Meshes** (:py:class:`~ogstools.Meshes`): Contains the computational domain geometry and mesh data. Can include multiple meshes (domain + boundary meshes).
# For this example, we load pre-configured components.
project = load_project_simple_lf()
meshes = load_meshes_simple_lf()
# **In practice, you would:**
# - Create Project files programmatically: See :ref:`sphx_glr_auto_examples_howto_prjfile_plot_creation.py`
# - Generate meshes (with GMSH, Pyvista or similar): See :ref:`sphx_glr_auto_user-guide_plot_msh2vtu.py`, :ref:`sphx_glr_auto_examples_howto_preprocessing_plot_extract_boundaries.py`
# Understanding Meshes: Input Geometry with PyVista
# :py:class:`~ogstools.Meshes` is the input mesh for OGS. Technically it is a collection of PyVista Unstructured grids that represent
# your simulation domain. You can access and manipulate individual meshes:
# Access a specific boundary mesh
print(f"Available meshes: {list(meshes.keys())}")
# Meshes are PyVista objects - The example shows how you can set initial conditions or properties
meshes["right"].point_data["pressure"] = np.full(meshes["left"].n_points, 3.1e7)
# Visualize the mesh topology
fig_topology = meshes.plot()
fig_topology.show()
# **See also:**
# - :ref:`sphx_glr_auto_examples_howto_preprocessing_plot_meshlib_vtu_input.py` - Load meshes from VTU files
# - :ref:`sphx_glr_auto_examples_howto_preprocessing_plot_initial_properties_and_variables.py` - Set initial conditions
# 2. Compose a Model
# A :py:class:`~ogstools.Model` combines all components needed to run a simulation:
# - **project**: The simulation configuration (:py:class:`~ogstools.Project`)
# - **meshes**: The computational meshes (:py:class:`~ogstools.Meshes`)
# - **execution**: Runtime settings (:py:class:`~ogstools.Execution`)
# The Execution object controls how OGS runs (threads, MPI ranks, logging, etc.):
model = ot.Model(project=project, meshes=meshes)
# Optionally configure execution settings
# e.g. model.execution.interactive = True # Uncomment for stepwise control
# Visualize the model setup with boundary conditions
fig_constraints = model.plot_constraints()
fig_constraints.show()
# The constraints plot shows your model domain with annotated boundary conditions
# and source terms, making it easy to verify your setup before running.
# 3. Run: Execute the Simulation
# OGSTools provides two ways to run simulations:
# **Option 1: Direct run** (used here)
#   ``model.run()`` - Blocks until completion, returns :py:class:`~ogstools.Simulation`
# **Option 2: Controlled execution**
#   ``controller = model.controller()`` - Returns a SimulationController for monitoring
# The controller approach gives you fine-grained control over execution.
# **See also:** :ref:`sphx_glr_auto_examples_howto_simulation_plot_010_simulate.py`
# Monitor status
print(controller.status_str)
# Run to wait for completion
sim = controller.run()
# Check simulation status
print(f"Simulation status: {sim.status_str}")
# The :py:class:`~ogstools.Simulation` object contains:
# - **model**: The Model that was run
# - **result**: Link to output files (MeshSeries)
# - **log**: Parsed simulation log for analysis
# - **status**: Completion status (derived from log analysis)
# 4. Analyze: Visualize and Examine Results
# After simulation, you can analyze results using two main components:
# **MeshSeries** (:py:class:`~ogstools.MeshSeries`)
#   Access simulation results at different timesteps for visualization.
# **Log** (:py:class:`~ogstools.logparser.log.Log`)
#   Parse and analyze the simulation log (convergence, timing, errors).
# Visualizing Results with MeshSeries
# The ``sim.result`` property provides a MeshSeries interface to your output data.
# You can index it like a list to get results at specific timesteps:
# Get the final timestep and plot pressure distribution
fig = ot.plot.contourf(sim.meshseries[-1], "pressure")
# **MeshSeries capabilities:**
# - Access any timestep: ``sim.result[0]``, ``sim.result[-1]``
# - Iterate over time: ``for mesh in sim.result: ...``
# - Time slicing: ``sim.result[::10]`` (every 10th timestep)
# - Unit conversion: ``sim.result.scale(time="h", length="cm")``
# **See also:**
# - :ref:`sphx_glr_auto_examples_howto_quickstart_plot_meshseries.py` - Detailed MeshSeries tutorial
# - :ref:`sphx_glr_auto_examples_howto_plot_plot_contourf_2d.py` - 2D visualization options
# - :ref:`sphx_glr_auto_examples_howto_plot_plot_contourf_3d.py` - 3D visualization options
# - :ref:`sphx_glr_auto_examples_howto_plot_plot_animation.py` - Create time animations
# Analyzing Convergence with the Log Parser
# The log parser extracts convergence data, timestep information, and errors
# from the simulation log file:
# Plot clock time per solver phase
df_ts = ot.logparser.analysis_time_step(sim.log.df_log).reset_index()
times = ["assembly_time", "dirichlet_time", "linear_solver_time"]
ax = df_ts.plot.area(x="time_step", y=times, ylabel="clock time [s]", grid=True)
ax.get_figure().tight_layout()
ax.get_figure().show()
# Plot convergence behaviour
fig = sim.log.plot_convergence(metric="dx_x")
# The convergence plot is a heatmap of the relative error at each iteration
# and time step, giving an overview of how the nonlinear solver converged
# over the entire simulation and helping you identify potential numerical
# issues. In this simple example all timesteps converge in 2 iterations.
# **Log analysis capabilities:**
# - Convergence data: ``sim.log.convergence_newton_iteration()``
# - Time step info: ``sim.log.time_step()``
# - Termination status: ``sim.log.simulation_termination()``
# - Custom plots: ``sim.log.plot_convergence(metric="dx", x_metric="model_time")``
# **See also:**
# - :ref:`sphx_glr_auto_examples_howto_logparser_plot_100_logparser_intro.py` - Log parser introduction
# - :ref:`sphx_glr_auto_examples_howto_logparser_plot_101_logparser_analyses.py` - Analysis examples
# - :ref:`sphx_glr_auto_examples_howto_logparser_plot_102_logparser_advanced.py` - Advanced log parsing
# 5. Store: Save and Reload Simulations
# OGSTools provides a unified storage system for saving complete simulations
# (or individual components) for later analysis or sharing.
# **Key features:**
# - **Cascading save**: Saving a Simulation automatically saves Model and Results
# - **Archive mode**: Create self-contained copies (no symlinks)
# - **ID-based organization**: Use IDs for organized storage
# - **Complete roundtrip**: Save → load → identical object
tmp = ot.definitions.temp_dir("framework", "examples")
# Save the complete simulation with archive mode
# This creates a self-contained copy you can share or move
sim.save(tmp / "mysim", archive=True)
# The saved simulation can be loaded later for further investigation
