Workflow with Feflowlib: Component-transport model - conversion, simulation, postprocessing
In this example we show how a simple mass transport FEFLOW model can be
converted to a pyvista.UnstructuredGrid and then be simulated in OGS with the
component transport process.
# 0. Necessary imports
)  # fmt: skip
# values of 0.
fig = ot.plot.contourf(clipped_mesh, concentration)
# 2. Setup a prj-file to run a OGS-simulation.
time_steps = list(zip([10] * 8, [8.64 * 10**i for i in range(8)], strict=False))
feflow_model.save()
# 3. Run the model.
feflow_model.run()
# 4. Read the last timestep and plot the results along a line on the upper edge
# of the mesh parallel to the x-axis.
    label = ["OGS", "FEFLOW"][i]
    ot.plot.line(
# 5. Concentration difference plotted on the mesh.
diff = ot.mesh.difference(feflow_model.mesh, ogs_sim_res, concentration)
# 5.1 Concentration difference plotted along a line.
fig = ot.plot.line(
