How to Create Simple Mechanics Problem
The following example consists of a simple mechanics problem.
The source file can be found in the [OGS benchmark folder](https://gitlab.opengeosys.org/ogs/ogs/-/blob/master/Tests/Data/Mechanics/Linear/square_1e2.prj?ref_type=heads).
The names of the method calls are based on the corresponding XML tags.
# Initialize the ogs6py object:
output_dir = ot.definitions.temp_dir("prj_creation", "examples")
# Define geometry and/or meshes, we expect the gml to be in the same folder like the prj file:
prj.geometry.add_geometry(
    filename=ot.definitions.EXAMPLES_DIR / "prj" / "square_1x1.gml"
# Set process and provide process related data:
prj.processes.set_process(
    name="SD",
    type="SMALL_DEFORMATION",
    integration_order="2",
    specific_body_force="0 0",
# Define time stepping and output cycles:
prj.time_loop.add_process(
    process="SD",
    convergence_type="DeltaX",
    norm_type="NORM2",
    abstol="1e-15",
prj.time_loop.set_stepping(
    process="SD",
    type="FixedTimeStepping",
    t_initial="0",
    t_end="1",
    repeat="4",
    delta_t="0.25",
prj.time_loop.add_output(
    type="VTK",
    prefix="blubb",
    repeat="1",
    each_steps="10",
prj.media.add_property(
    medium_id="0",
    phase_type="Solid",
    name="density",
    type="Constant",
    value="1",
# Define parameters needed for material properties and BC:
# Set initial and boundary conditions:
prj.process_variables.set_ic(
    components="2",
    order="1",
prj.process_variables.add_bc(
    geometry="left",
    type="Dirichlet",
    component="0",
    parameter="dirichlet0",
    geometry="bottom",
    type="Dirichlet",
    component="1",
    geometry="top",
    type="Dirichlet",
    component="1",
    parameter="dirichlet1",
# Set linear and nonlinear solver(s):
    type="Newton",
    max_iter="4",
    name="general_linear_solver",
    kind="lis",
    solver_type="cg",
    precon_type="jacobi",
    max_iteration_step="10000",
    error_tolerance="1e-16",
    kind="eigen",
    solver_type="CG",
    precon_type="DIAGONAL",
    kind="petsc",
    prefix="sd",
    solver_type="cg",
    precon_type="bjacobi",
m = ot.Model(project=prj, meshes=ot.definitions.EXAMPLES_DIR / "prj")
fig = m.plot_constraints()
m.run()
