Calculate differences between meshes
This example shows how to calculate differences between meshes.
# sphinx_gallery_start_ignore
# sphinx_gallery_thumbnail_number = 2
# pylint: disable=wrong-import-position, wrong-import-order
# sphinx_gallery_end_ignore
ot.plot.setup.dpi = 75
def custom_mesh(lengths: int, element_order: int, quads: bool):
    "Creates a custom mesh and runs a Mechanics simulation on it."
    rect = ot.gmsh_tools.rect(
        lengths=lengths,
        n_edge_cells=21,
        structured_grid=quads,
        order=element_order,
    meshes = ot.Meshes.from_gmsh(rect)
    prj = ot.Project(input_file=examples.prj_mechanics).copy()
    if element_order == 2:
        prj.replace_text(4, ".//integration_order")
    model = ot.Model(prj, meshes)
    sim = model.run()
    return sim.meshseries.mesh(-1)
# Difference between two meshes
# The simplest case is calculating the difference between two meshes. For this
# example, we read two different timesteps from a MeshSeries. It is not required
# that they belong to the same MeshSeries object. As long, as the meshes contain
# the variable of interest, the difference will work fine.
mesh_series = examples.load_meshseries_THM_2D_PVD().scale(spatial="km")
mesh1 = mesh_series.mesh(0)
mesh2 = mesh_series.mesh(-1)
# The following call will return a mesh containing the difference of the
# variable between the two provided meshes. Then we plot the difference:
mesh_diff = ot.mesh.difference(mesh1, mesh2, ot.variables.temperature)
fig = ot.plot.contourf(mesh_diff, ot.variables.temperature)
# Difference between two meshes of different topology
# This examples shall demonstrate how we can compare meshes of different size
# and/or topology. To demonstrate this, we create two artificial meshes.
quad_mesh = custom_mesh(lengths=0.8, element_order=1, quads=True)
tri_mesh = custom_mesh(lengths=1, element_order=2, quads=False)
# They are visibly quite similar, aside from the difference in cell type and
# size:
fig = ot.plot.contourf([quad_mesh, tri_mesh], ot.variables.stress["xx"])
# To better quantify it we form the difference and plot the result. The base
# mesh of which we subtract from provides the topology to show the differences.
# Thus we see data here on the quad mesh. Be aware that comparing different
# topologies is inherently affected by interpolation.
diff_mesh = ot.mesh.difference(quad_mesh, tri_mesh, ot.variables.stress)
fig = ot.plot.contourf(diff_mesh, ot.variables.stress.difference["xx"])
# Doing it the other way around shows the difference on the tri-mesh. Here, we
# see, that the subtracted mesh was smaller then the base mesh and thus, the
# which are outside of the domain of the second mesh are masked.
diff_mesh = ot.mesh.difference(tri_mesh, quad_mesh, ot.variables.stress)
# Differences between multiple meshes
# It is possible to calculate the difference between multiple meshes at the same
# time. Multiple meshes can be provided either as list or numpy arrays.
# 4 ways of calculating the difference are presented here.
# Pairwise difference
# In order to calculate pairwise differences, two lists or arrays of equal
# length have to be provided as the input. They can contain an arbitrary number
# of different meshes, as long as their length is equal.
# Consider the two following lists:
# .. math::
#   \text{List}_{1} = \begin{bmatrix} A_{1} & B_{1} & C_{1}\\ \end{bmatrix}
#   \text{List}_{2} = \begin{bmatrix} A_{2} & B_{2} & C_{2}\\ \end{bmatrix}
# The output array will contain following differences between meshes:
# .. math::
#   \begin{bmatrix} A_{1}-A_{2} & B_{1}-B_{2} & C_{1}-C_{2}\\ \end{bmatrix}
# and will have the same shape as the input lists. As in the example below:
meshes_1 = [mesh1] * 3
meshes_2 = [mesh2] * 3
mesh_diff_pair_wise = ot.mesh.difference_pairwise(
    meshes_1, meshes_2, ot.variables.temperature
# Matrix difference - one array
# If only one list or array is provided, the differences between every possible
# pair of objects in the array will be returned.
# Consider following list:
# .. math::
#   \text{List} = \begin{bmatrix} A & B & C\\ \end{bmatrix}
# .. math::
#   \begin{bmatrix} A-A & B-A & C-A\\ A-B & B-B & C-B \\ A-C & B-C & C-C \\ \end{bmatrix}
# and will have shape of (len(mesh_list), len(mesh_list)). As in the following
# example:
mesh_diff_matrix = ot.mesh.difference_matrix(
    mesh_list, variable=ot.variables.temperature
# Matrix difference - two arrays of different length
# Unlike difference_pairwise(), difference_matrix() can accept two lists/arrays
# of different lengths. As in Section 3, the differences between all possible
# pairs of meshes in both lists/arrays will be calculated.
# Consider following lists:
# .. math::
#   \text{List}_1 = \begin{bmatrix} A_1 & B_1 & C_1\\ \end{bmatrix}
# .. math::
#   \text{List}_2 = \begin{bmatrix} A_2 & B_2 \\ \end{bmatrix}
# .. math::
#   \begin{bmatrix} A_1-A_2 & A_1-B_2 \\ B_1-A_2 & B_1-B_2 \\ C_1-A_2 & C_1-B_2 \\ \end{bmatrix}
# and will have a shape of (len(mesh_list_matrix_1), len(mesh_list_matrix_2)).
# As in the following example:
    mesh_list_matrix_1, mesh_list_matrix_2, ot.variables.temperature
# Difference between two meshseries
# It is possible to calculate the difference between two MeshSeries objects.
# First, an artificial data set will be generated by copying an example data set and increasing the pressure values by 25%.
ms = examples.load_meshseries_THM_2D_PVD().scale(spatial="km", time="d")
ms2 = ms.copy()
ms2.point_data["pressure"] *= 1.25
# Now a difference between original and altered MeshSeries can be computed:
diff_ms = ot.MeshSeries.difference(ms2, ms, ot.variables.pressure)
# As a reference, the last steps of the original and altered MeshSeries
# can be plotted:
fig_T = ot.plot.contourf(ms[-1], ot.variables.pressure, show_edges=False)
fig_T.show()
fig_T_2 = ot.plot.contourf(ms2[-1], ot.variables.pressure, show_edges=False)
fig_T_2.show()
# The MeshSeries object returned by the difference() method, can be used in the
# same way as any other one. However, to plot the pressure difference either
# use the string "pressure_difference" (see comment in the code block below) or the derived variable.
# ot.variable.pressure.difference.
fig_T_diff = ot.plot.contourf(
    diff_ms[-1], ot.variables.pressure.difference, show_edges=True
fig_T_diff.show()
# fig_T_diff = ot.plot.contourf(diff_ms[-1], "pore_pressure_difference")
