Interactive Mesh manipulation (OGSTools - Integrated)
We demonstrate how to access and modify in situ meshes during an OpenGeoSys simulation.
Key features in this tutorial:
- Inspect mesh data via standard PyVista functions
- Dynamically modify point/cell properties (e.g., boundary conditions)
- React to simulation progress or state in an adaptive simulation loop
This tutorial builds on the :ref:`sphx_glr_auto_examples_howto_simulation_plot_100_ogs_interactive_simulator.py`. For a lower-level control, see :ref:`sphx_glr_auto_examples_howto_simulation_plot_250_ogs_interactive_mesh_native.py`.
# Imports and definitions
from time import sleep  # For simulation pause / interrupt
from ogstools.simulation import SimulationController
# Select a Project
# We will start with a simple liquid flow project.
working_dir = Path(mkdtemp())
prj, meshes = load_model_liquid_flow_simple()
prj.write_input(working_dir / "LiquidFlowSimple.prj")
_ = meshes.save(working_dir)
# Read and write in situ meshes
# We will work with these functions:
# - :py:meth:`ot.Mesh.from_simulator <ogstools.meshlib.Mesh.from_simulator>`
#      gives you direct access to the values of th in situ-Mesh during a running OGS simulation
# - :class:`~ogstools.simulation.simulation_controller.SimulationController`,
#   that works exactly like `OGSSimulation` introduced in :ref:`sphx_glr_auto_examples_howto_simulation_plot_100_ogs_interactive_simulator.py`.
# This example demonstrates an adaptive simulation loop:
# 1. The simulation is monitored for steady-state convergence
# 2. Boundary conditions are dynamically adjusted during runtime
sim2_result_dir = working_dir / "sim2"
sim2_result_dir.mkdir(exist_ok=True)
arguments = [
    str(working_dir / "LiquidFlowSimple.prj"),
    "-o",
    str(sim2_result_dir),
sim2 = SimulationController(
    arguments
)  # we will restart the same simulation as above into new folder
domain_mesh = ot.Mesh.from_simulator(sim2, "domain", ["pressure"])
# Let us store the mesh of a time step to compare it later
previous_domain_mesh_pressure = domain_mesh.point_data["pressure"]
domain_mesh_pressure = previous_domain_mesh_pressure
# Later, we will dynamically modify the left boundary mesh
left_mesh = ot.Mesh.from_simulator(sim2, "left", ["pressure"])
steady_state_threshold = 0.1 * len(previous_domain_mesh_pressure)  # constant
delta = steady_state_threshold + 1e-10  # to be computed for each time step
# Main simulation loop
# The simulation is advanced step-by-step until either:
# - The simulation reaches the defined end time, or
# - The user interrupts execution (Ctrl+C or Stop the Jupyter cell)
while (
    sim2.current_time() < sim2.end_time()
    and not sim2.is_interrupted()
    # any other stopping condition based on the mesh, log, ...
    # e.g. # `delta > steady_state_threshold``
    previous_domain_mesh_pressure = domain_mesh.point_data["pressure"].copy()
    sim2.execute_time_step()
    sleep(0.01)  # Must have, if you want to pause the simulation
    # --------------- until here minimal loop -------------------------------
    # Example for an In-loop condition
    # 1. Check, if a steady state is reached
    # 2. Change a boundary condition
    delta = np.max(
        np.absolute(
            domain_mesh.point_data["pressure"] - previous_domain_mesh_pressure
    if delta < steady_state_threshold:
        print(
            "The steady state condition is reached. Now a new boundary condition is applied."
        # [:] Is important! Otherwise you would assign a new numpy array to pressure (which would write into the in situ mesh)
        left_mesh.point_data["pressure"][:] = np.full(left_mesh.n_points, 3.1e7)
    # else: we keep the boundary conditions constant
# This simulation reaches the steady state condition twice
# 1st with left boundary pressure at 2.9e7 Pa, 2nd: 3.1e7 Pa
# Intermediate plot
# If the simulation is paused or interrupted, you can inspect the current state of the mesh.
# You are free to adapt the mesh and continue the simulation as shown in while loop above.
# Let us just plot the pressure field.
fig = ot.plot.contourf(domain_mesh, "pressure")
# Continue the ("paused") simulation
# Or run over multiple steps (see while loop above)
sim2.execute_simulation()
# Necessary to close, otherwise you can not reinitialize simulation with same prj-file (arguments)
sim2.close()
# Visualization
# We visualize how the dynamically updated boundary conditions affected the pressure field.
# Changes in boundary conditions can be clearly observed.
ms = ot.MeshSeries(sim2_result_dir / "LiquidFlow_Simple.pvd")
# Time slice over x
ms_probe = ot.MeshSeries.extract_probe(ms, points, "pressure")
# Note: Alternatively, for boundary conditions only (no interaction), have a look at our guide about
# `Defining boundary conditions with Python <https://www.opengeosys.org/docs/userguide/features/python_bc/>`_.
