Materials and Media#
Section author: Norbert Grunwald
NB! Works for HEAT_CONDUCTION and TH2M (with Phase Transitions) only so far.
This example shows how to build OpenGeoSys media definitions directly
from a YAML-based Material Library using
MaterialManager
and MediaSet.
The YAML schema defines materials with:
name - unique material identifier
properties - sets of constitutive relations (with type, parameters, scope)
scope - indicates whether a property applies at phase or medium level
Together with the built-in process schemas (e.g. TH2M_PT),
these building blocks allow you to construct full Media definitions
including phases and components, and import them into an OGS project XML
via set_media().
from ogstools import definitions as defs
model_dir = Path(mkdtemp())
Example materials#
Materials are provided as YAML files in the built-in Material Library. For example, here are the definitions of “opalinus_clay” (solid) and “water” (fluid):
print((Path(defs.MATERIALS_DIR) / "opalinus.yml").read_text(encoding="utf-8"))
print((Path(defs.MATERIALS_DIR) / "water.yml").read_text(encoding="utf-8"))
group: medium
properties:
biot_coefficient:
- type: Constant
unit: 0.6
value: 1
bishops_effective_stress:
- type: BishopsPowerLaw
unit: 1
exponent: 1
density:
- type: Constant
unit: kg/m³
value: 2600
permeability:
- type: Constant
unit: m²
value: 1.e-21
poisson_ratio:
- type: Constant
unit: 1
value: 0.23
porosity:
- type: Constant
unit: 1
value: 0.15
saturation:
- type: SaturationVanGenuchten
exponent: 0.2
p_b: 48000000
residual_gas_saturation: 0.01
residual_liquid_saturation: 0.01
specific_heat_capacity:
- type: Constant
unit: J/(kg·K)
value: 995
thermal_conductivity:
# Thermal conductivity of the individual phase (e.g. solid or fluid),
# used in local energy balance equations of that phase.
- type: Constant
scope: phase
unit: W/(m·K)
value: 1.7
# Effective thermal conductivity of the full medium,
# typically calculated from the phase conductivities using
# porosity-weighted mixing models.
- type: SaturationWeightedThermalConductivity
mean_type: arithmetic_squareroot
dry_thermal_conductivity: 1.36
wet_thermal_conductivity: 1.7
scope: medium
unit: W/(m·K)
- type: EffectiveThermalConductivityPorosityMixing
scope: medium
unit: W/(m·K)
thermal_expansivity:
- type: Constant
unit: 1/K
value: 1.7e-5
tortuosity:
- type: Constant
unit: 1
value: 1
youngs_modulus:
- type: Constant
unit: Pa
value: 6500000000
relative_permeability:
- type: RelativePermeabilityVanGenuchten
exponent: 0.2
minimum_relative_permeability_liquid: 1e-12
unit: 1
relative_permeability_nonwetting_phase:
- type: RelativePermeabilityNonWettingPhaseVanGenuchtenMualem
exponent: 0.2
min_relative_permeability: 1e-5
unit: 1
group: liquid
type: phase
properties:
molar_mass:
- type: Constant
value: 0.018016
unit: kg/mol
source: "CODATA 2018 recommended values"
- type: Constant
value: 4187
unit: J/(kg·K)
source: "CRC Handbook of Chemistry and Physics"
- type: Constant
value: 0.6
unit: W/(m·K)
density:
- type: Constant
value: 1000
unit: kg/m³
source: "at 4 °C, standard value"
- type: Linear
reference_value: 1000
independent_variables:
concentration:
reference_condition: 0.0
slope: 2.0e-6
temperature:
reference_condition: 293.15
slope: 1.5e-5
viscosity:
- type: Constant
value: 1.0e-3
unit: Pa·s
source: "at 20 °C, standard value"
vapour_pressure:
- type: ClausiusClapeyron
triple_temperature: 273.16
triple_pressure: 611.66
critical_temperature: 647.096
critical_pressure: 22.064e6
reference_temperature: 373.15
reference_pressure: 101325
source: "IAPWS, 1995 formulation"
diffusion:
- type: Constant
value: 1.0e-9
unit: m²/s
source: "typical value for water in porous media"
specific_latent_heat:
- type: Constant
value: 2268000.0
unit: J/kg
source: "at 100 °C, standard value"
Media creation#
We build a MaterialManager from the built-in library, filter it with a schema, and construct a MediaSet object.
subdomain: the subdomain name (string, one per entry)material: must match thenamein the YAML filematerial_ids: list of integers corresponding to the MatIDs in the mesh (allows grouping several mesh regions under one subdomain name)
db = ot.MaterialManager()
subdomains = [
"subdomain": "host_rock",
"material": "opalinus_clay",
"material_ids": [0, 3, 4], # multiple MatIDs grouped under one name
"subdomain": "buffer",
"material": "bentonite",
"material_ids": [1, 2],
fluids = {
"AqueousLiquid": "water",
"Gas": "carbon_dioxide",
} # required by TH2M_PT schema
filtered = db.filter(process="TH2M_PT", subdomains=subdomains, fluids=fluids)
media = ot.MediaSet(filtered)
Export to OGS Project XML#
The MediaSet is imported into an OGS Project instance
via Project.set_media().
prj = ot.Project()
prj.set_media(media)
xml_file = model_dir / "material_test.prj"
prj.write_input(xml_file)
print(xml_file.read_text())
<?xml version='1.0' encoding='ISO-8859-1'?>
<OpenGeoSysProject>
<mesh/>
<processes>
<process/>
</processes>
<time_loop>
<processes/>
</time_loop>
<parameters/>
<process_variables/>
<nonlinear_solvers/>
<linear_solvers/>
<media>
<medium id="0">
<properties>
<property>
<name>biot_coefficient</name>
<type>Constant</type>
<value>1</value>
</property>
<property>
<name>bishops_effective_stress</name>
<type>BishopsPowerLaw</type>
<exponent>1</exponent>
</property>
<property>
<name>permeability</name>
<value>1e-21</value>
</property>
<property>
<name>porosity</name>
<value>0.15</value>
</property>
<property>
<name>saturation</name>
<type>SaturationVanGenuchten</type>
<exponent>0.2</exponent>
<p_b>48000000</p_b>
<residual_gas_saturation>0.01</residual_gas_saturation>
<residual_liquid_saturation>0.01</residual_liquid_saturation>
</property>
<property>
<name>thermal_conductivity</name>
<type>SaturationWeightedThermalConductivity</type>
<mean_type>arithmetic_squareroot</mean_type>
<dry_thermal_conductivity>1.36</dry_thermal_conductivity>
<wet_thermal_conductivity>1.7</wet_thermal_conductivity>
</property>
<property>
<type>EffectiveThermalConductivityPorosityMixing</type>
</property>
<property>
<name>tortuosity</name>
<value>1</value>
</property>
<property>
<name>relative_permeability</name>
<type>RelativePermeabilityVanGenuchten</type>
<minimum_relative_permeability_liquid>1e-12</minimum_relative_permeability_liquid>
</property>
<property>
<name>relative_permeability_nonwetting_phase</name>
<type>RelativePermeabilityNonWettingPhaseVanGenuchtenMualem</type>
<min_relative_permeability>1e-5</min_relative_permeability>
</property>
</properties>
<phases>
<phase>
<type>Solid</type>
<properties>
<property>
<name>density</name>
<value>2600</value>
</property>
<property>
<name>specific_heat_capacity</name>
<value>995</value>
</property>
<property>
<value>1.7</value>
</property>
<property>
<name>thermal_expansivity</name>
<value>1.7e-05</value>
</property>
</properties>
</phase>
<phase>
<type>AqueousLiquid</type>
<properties>
<property>
<value>4187</value>
</property>
<property>
<value>0.6</value>
</property>
<property>
<value>1000</value>
</property>
<property>
<type>Linear</type>
<reference_value>1000</reference_value>
<independent_variable>
<variable_name>concentration</variable_name>
<reference_condition>0.0</reference_condition>
<slope>2e-06</slope>
</independent_variable>
<variable_name>temperature</variable_name>
<reference_condition>293.15</reference_condition>
<slope>1.5e-05</slope>
</property>
<property>
<name>viscosity</name>
<value>0.001</value>
</property>
</properties>
<components>
<component>
<name>carbon_dioxide</name>
<properties>
<property>
<name>specific_latent_heat</name>
<value>100.0</value>
</property>
<property>
<value>4187</value>
</property>
<property>
<name>diffusion</name>
<value>0.0</value>
</property>
<property>
<name>henry_coefficient</name>
<value>1.0</value>
</property>
</properties>
</component>
<component>
<name>water</name>
<properties>
<property>
<value>4187</value>
</property>
</properties>
</component>
</components>
</phase>
<phase>
<type>Gas</type>
<properties>
<property>
<value>0.6</value>
</property>
<property>
<type>IdealGasLawBinaryMixture</type>
</property>
<property>
</property>
</properties>
<components>
<component>
<properties>
<property>
<value>4187</value>
</property>
<property>
<name>molar_mass</name>
<value>0.018016</value>
</property>
</properties>
</component>
<component>
<name>water</name>
<properties>
<property>
<name>vapour_pressure</name>
<type>ClausiusClapeyron</type>
<critical_pressure>22.064e6</critical_pressure>
<critical_temperature>647.096</critical_temperature>
<reference_pressure>101325</reference_pressure>
<reference_temperature>373.15</reference_temperature>
<triple_pressure>611.66</triple_pressure>
<triple_temperature>273.16</triple_temperature>
</property>
<property>
<value>1e-06</value>
</property>
<property>
</property>
<property>
<value>2268000.0</value>
</property>
<property>
<value>4187</value>
</property>
</properties>
</component>
</components>
</phase>
</phases>
</medium>
<medium id="3">
<properties>
<property>
<value>1</value>
</property>
<property>
</property>
<property>
</property>
<property>
<value>0.15</value>
</property>
<property>
<p_b>48000000</p_b>
</property>
<property>
</property>
<property>
</property>
<property>
<value>1</value>
</property>
<property>
</property>
<property>
</property>
</properties>
<phases>
<phase>
<type>Solid</type>
<properties>
<property>
<value>2600</value>
</property>
<property>
<value>995</value>
</property>
<property>
<value>1.7</value>
</property>
<property>
</property>
</properties>
</phase>
<phase>
<properties>
<property>
<value>4187</value>
</property>
<property>
<value>0.6</value>
</property>
<property>
<value>1000</value>
</property>
<property>
<type>Linear</type>
</property>
<property>
</property>
</properties>
<components>
<component>
<properties>
<property>
</property>
<property>
<value>4187</value>
</property>
<property>
<value>0.0</value>
</property>
<property>
<value>1.0</value>
</property>
</properties>
</component>
<component>
<name>water</name>
<properties>
<property>
<value>4187</value>
</property>
</properties>
</component>
</components>
</phase>
<phase>
<type>Gas</type>
<properties>
<property>
<value>0.6</value>
</property>
<property>
</property>
<property>
</property>
</properties>
<components>
<component>
<properties>
<property>
<value>4187</value>
</property>
<property>
</property>
</properties>
</component>
<component>
<name>water</name>
<properties>
<property>
</property>
<property>
</property>
<property>
</property>
<property>
</property>
<property>
<value>4187</value>
</property>
</properties>
</component>
</components>
</phase>
</phases>
</medium>
<medium id="4">
<properties>
<property>
<value>1</value>
</property>
<property>
</property>
<property>
</property>
<property>
<value>0.15</value>
</property>
<property>
<p_b>48000000</p_b>
</property>
<property>
</property>
<property>
</property>
<property>
<value>1</value>
</property>
<property>
</property>
<property>
</property>
</properties>
<phases>
<phase>
<type>Solid</type>
<properties>
<property>
<value>2600</value>
</property>
<property>
<value>995</value>
</property>
<property>
<value>1.7</value>
</property>
<property>
</property>
</properties>
</phase>
<phase>
<properties>
<property>
<value>4187</value>
</property>
<property>
<value>0.6</value>
</property>
<property>
<value>1000</value>
</property>
<property>
<type>Linear</type>
</property>
<property>
</property>
</properties>
<components>
<component>
<properties>
<property>
</property>
<property>
<value>4187</value>
</property>
<property>
<value>0.0</value>
</property>
<property>
<value>1.0</value>
</property>
</properties>
</component>
<component>
<name>water</name>
<properties>
<property>
<value>4187</value>
</property>
</properties>
</component>
</components>
</phase>
<phase>
<type>Gas</type>
<properties>
<property>
<value>0.6</value>
</property>
<property>
</property>
<property>
</property>
</properties>
<components>
<component>
<properties>
<property>
<value>4187</value>
</property>
<property>
</property>
</properties>
</component>
<component>
<name>water</name>
<properties>
<property>
</property>
<property>
</property>
<property>
</property>
<property>
</property>
<property>
<value>4187</value>
</property>
</properties>
</component>
</components>
</phase>
</phases>
</medium>
<medium id="1">
<properties>
<property>
<value>0.6</value>
</property>
<property>
<value>0.4</value>
</property>
<property>
<value>1e-20</value>
</property>
<property>
<exponent>0.6</exponent>
<p_b>2.0e6</p_b>
<residual_gas_saturation>1e-15</residual_gas_saturation>
<residual_liquid_saturation>0.05</residual_liquid_saturation>
</property>
<property>
</property>
<property>
<value>1.0</value>
</property>
<property>
<value>1.0</value>
</property>
<property>
<exponent>0.3</exponent>
</property>
<property>
</property>
</properties>
<phases>
<phase>
<type>Solid</type>
<properties>
<property>
<value>2500</value>
</property>
<property>
<value>900</value>
</property>
<property>
<value>0.6</value>
</property>
<property>
<value>2e-05</value>
</property>
</properties>
</phase>
<phase>
<properties>
<property>
<value>4187</value>
</property>
<property>
<value>0.6</value>
</property>
<property>
<value>1000</value>
</property>
<property>
<type>Linear</type>
</property>
<property>
</property>
</properties>
<components>
<component>
<properties>
<property>
</property>
<property>
<value>4187</value>
</property>
<property>
<value>0.0</value>
</property>
<property>
<value>1.0</value>
</property>
</properties>
</component>
<component>
<name>water</name>
<properties>
<property>
<value>4187</value>
</property>
</properties>
</component>
</components>
</phase>
<phase>
<type>Gas</type>
<properties>
<property>
<value>0.6</value>
</property>
<property>
</property>
<property>
</property>
</properties>
<components>
<component>
<properties>
<property>
<value>4187</value>
</property>
<property>
</property>
</properties>
</component>
<component>
<name>water</name>
<properties>
<property>
</property>
<property>
</property>
<property>
</property>
<property>
</property>
<property>
<value>4187</value>
</property>
</properties>
</component>
</components>
</phase>
</phases>
</medium>
<medium id="2">
<properties>
<property>
<value>0.6</value>
</property>
<property>
<value>0.4</value>
</property>
<property>
</property>
<property>
<p_b>2.0e6</p_b>
</property>
<property>
</property>
<property>
<value>1.0</value>
</property>
<property>
<value>1.0</value>
</property>
<property>
</property>
<property>
</property>
</properties>
<phases>
<phase>
<type>Solid</type>
<properties>
<property>
<value>2500</value>
</property>
<property>
<value>900</value>
</property>
<property>
<value>0.6</value>
</property>
<property>
</property>
</properties>
</phase>
<phase>
<properties>
<property>
<value>4187</value>
</property>
<property>
<value>0.6</value>
</property>
<property>
<value>1000</value>
</property>
<property>
<type>Linear</type>
</property>
<property>
</property>
</properties>
<components>
<component>
<properties>
<property>
</property>
<property>
<value>4187</value>
</property>
<property>
<value>0.0</value>
</property>
<property>
<value>1.0</value>
</property>
</properties>
</component>
<component>
<name>water</name>
<properties>
<property>
<value>4187</value>
</property>
</properties>
</component>
</components>
</phase>
<phase>
<type>Gas</type>
<properties>
<property>
<value>0.6</value>
</property>
<property>
</property>
<property>
</property>
</properties>
<components>
<component>
<properties>
<property>
<value>4187</value>
</property>
<property>
</property>
</properties>
</component>
<component>
<name>water</name>
<properties>
<property>
</property>
<property>
</property>
<property>
</property>
<property>
</property>
<property>
<value>4187</value>
</property>
</properties>
</component>
</components>
</phase>
</phases>
</medium>
</media>
</OpenGeoSysProject>
Total running time of the script: (0 minutes 0.111 seconds)
