Convergence study (spatial refinement)#
Nasa convergence reference
More comprehensive reference
from ogs6py import ogs
from ogstools import meshlib, meshplotlib, msh2vtu, propertylib, workflow
from ogstools.studies.convergence.examples import (
    steady_state_diffusion_analytical_solution,
meshplotlib.setup.reset()
temp_dir = Path(mkdtemp(suffix="steady_state_diffusion"))
report_name = str(temp_dir / "report.ipynb")
result_paths = []
The meshes and their boundaries are generated easily via gmsh and ogstools.msh2vtu. Then we run the different simulations with increasingly fine spatial discretization via ogs6py and store the results for the convergence study.
refinements = 6
    msh_path = temp_dir / "square.msh"
    meshlib.gmsh_meshing.rect(
    msh2vtu.msh2vtu(filename=msh_path, output_path=temp_dir, log_level="ERROR")
    model = ogs.OGS(
        PROJECT_FILE=temp_dir / "default.prj",
        INPUT_FILE=convergence.examples.steady_state_diffusion_prj,
    ogs_args = f"-m {temp_dir} -o {temp_dir}"
    result_paths += [str(temp_dir / (prefix + ".pvd"))]
OGS finished with project file /tmp/tmpw5c65pqssteady_state_diffusion/default.prj.
Execution took 0.1457054615020752 s
Execution took 0.1478736400604248 s
Execution took 0.15001392364501953 s
Execution took 0.13739228248596191 s
Execution took 0.15207982063293457 s
Execution took 0.1596994400024414 s
analytical_solution_path = temp_dir / "analytical_solution.vtu"
solution = steady_state_diffusion_analytical_solution(
    meshlib.MeshSeries(result_paths[-1]).read(0)
meshplotlib.setup.show_element_edges = True
fig = meshplotlib.plot(solution, propertylib.presets.hydraulic_height)
plot convergence study steady state diffusion
    output_name=report_name,
    mesh_paths=result_paths,
    property_name="hydraulic_height",
    timevalue=1,
    refinement_ratio=2.0,
report
Darcy velocity convergence#
    property_name="velocity",
    timevalue=1,
report
Total running time of the script: (0 minutes 18.799 seconds)
