Convergence study (spatial & temporal refinement)#
This example shows one possible implementation of how to do a convergence study with spatial and temporal refinement. For this, a simple model using a time dependent heat source on one side and constant temperature on the opposite side was set up. The heat source is generated with the ogstools.physics.nuclearwasteheat model.
Nasa convergence reference
More comprehensive reference
from ogs6py import ogs
from ogstools import meshlib, msh2vtu, physics, propertylib, studies, workflow
temp_dir = Path(mkdtemp(prefix="nuclear_decay"))
Let’s run the different simulations with increasingly fine spatial and temporal discretization via ogs6py. The mesh and its boundaries are generated easily via gmsh and ogstools.msh2vtu. First some definitions:
n_refinements = 4
prefix = "stepsize_{0}"
sim_results = []
msh_path = temp_dir / "rect.msh"
script_path = Path(studies.convergence.examples.nuclear_decay_bc).parent
prj_path = studies.convergence.examples.nuclear_decay_prj
ogs_args = f"-m {temp_dir} -o {temp_dir} -s {script_path}"
Now the actual simulations:
for dt, n_cells in zip(time_step_sizes, edge_cells):
    meshlib.rect(lengths=100.0, n_edge_cells=[n_cells, 1], out_name=msh_path)
    _ = msh2vtu.msh2vtu(msh_path, output_path=temp_dir, log_level="ERROR")
    model = ogs.OGS(PROJECT_FILE=temp_dir / "default.prj", INPUT_FILE=prj_path)
    model.replace_text(str(dt * sec_per_yr), ".//delta_t")
    model.replace_text(prefix.format(dt), ".//prefix")
    sim_results += [temp_dir / (prefix.format(dt) + "_rect_domain.xdmf")]
OGS finished with project file /tmp/nuclear_decayfomxm5j4/default.prj.
Execution took 0.5824856758117676 s
Execution took 0.6820333003997803 s
Execution took 0.886972188949585 s
Execution took 1.3099451065063477 s
for sim_result, dt in zip(sim_results, time_step_sizes):
    mesh_series = meshlib.MeshSeries(sim_result)
    results = {"heat_flux": [], "temperature": []}
    for ts in mesh_series.timesteps:
        mesh = mesh_series.read(ts)
        results["temperature"] += [np.max(mesh.point_data["temperature"])]
    max_T = propertylib.presets.temperature.transform(results["temperature"])
    # times 2 due to symmetry, area of repo, to kW
    results["heat_flux"] += [np.max(mesh.point_data["heat_flux"][:, 0])]
    tv = np.asarray(mesh_series.timevalues) / sec_per_yr
    ax1.plot(tv, max_T, lw=1.5, label=f"{dt=}")
    edges = np.append(0, tv)
ax2.set_xlabel("time / yrs")
ax1.set_ylabel("max T / °C")
ax2.set_ylabel("heat / kW")
ax1.legend()
ax2.legend()
plot convergence study nuclear decay
report_name = temp_dir / "report.ipynb"
    output_name=report_name,
    mesh_paths=sim_results,
    timevalue=30 * sec_per_yr,
    property_name="temperature",
    refinement_ratio=2.0,
report
    timevalue=150 * sec_per_yr,
report
mesh_series = [meshlib.MeshSeries(sim_result) for sim_result in sim_results]
    mesh_series, propertylib.presets.temperature, units=["s", "yrs"]
Looking at the errors, we see a higher error right at the beginning. This is likely due to the more dynamic behavior at the beginning.
Total running time of the script: (0 minutes 18.766 seconds)
