How to plot data at observation points#
In this example we plot the data values on observation points over all timesteps. Since requested observation points don’t necessarily coincide with actual nodes of the mesh different interpolation options are available. See ogstools.meshlib.mesh_series.MeshSeries.probe for more details. Here we use a component transport example from the ogs benchmark gallery (https://www.opengeosys.org/docs/benchmarks/hydro-component/elder/).
from ogstools import meshplotlib
from ogstools.meshplotlib.examples import meshseries_CT_2D as mesh_series
from ogstools.meshplotlib.utils import justified_labels
meshplotlib.setup.reset()
si = Scalar(
Let’s define 4 observation points and plot them on the mesh.
points = np.asarray(
    [[x, 0, 60] for x in [0, 40, 80, 120]]
    + [[x, 0, 40] for x in [0, 40, 80, 120]]
fig = meshplotlib.plot(mesh_series.read(0), si)
fig.axes[0].scatter(points[:, 0], points[:, 2], s=50, fc="none", ec="r", lw=3)
for i, point in enumerate(points):
    fig.axes[0].annotate(str(i), (point[0], point[2] - 5), va="top")
plt.rcdefaults()
plot observation points
And now probe the points and the values over time:
labels = [f"{i}: {label}" for i, label in enumerate(justified_labels(points))]
fig = meshplotlib.plot_probe(
    mesh_series=mesh_series, points=points[:4], mesh_property=si,
    time_unit="a", labels=labels[:4]
You can also pass create your own matplotlib figure and pass the axes object. Additionally, you can pass any keyword arguments which are known by matplotlibs plot function to further customize the curves. In this case marker and linewidth are not part of the API of plot_probe but get processed correctly anyway.
fig, axs = plt.subplots(nrows=2, figsize=[10, 5])
    mesh_series, points[:4], si, time_unit="a", ax=axs[0], colors=["k"],
    labels=labels[:4], marker=".")
    mesh_series, points[4:], si, time_unit="a", ax=axs[1], linestyles=["-"],
    labels=labels[4:], linewidth=1,
Total running time of the script: (0 minutes 1.017 seconds)
