Analyzing Meshseries Data#
In this example we show how to aggregate data in a model over all timesteps as well as plot differences between to timesteps. For this purpose we use a component transport example from the ogs benchmark gallery (https://www.opengeosys.org/docs/benchmarks/hydro-component/elder/).
from ogstools.meshplotlib import examples, plot, setup
setup.reset()
mesh_series = examples.meshseries_CT_2D
si = Scalar(
You aggregate the data in MeshSeries over all timesteps given some aggregation function, e.g. “min”, “max”, “var” (see: aggregate()). The following code gets the maximum saturation for each point in the mesh over all timesteps and plots it. Note: the aggragation function returns the resulting mesh and a new property corresponding to the aggregated data, to ensure no duplicate unit conversion or data transformation is happening in the plot function.
mesh = mesh_series.aggregate(si, "max")
fig = plot(mesh, si)
plot special
Likewise we can calculate and visualize the variance of the saturation:
mesh = mesh_series.aggregate(si, "var")
plot special
Difference between the last and the first timestep:
mesh = difference(mesh_series.read(-1), mesh_series.read(0), si)
plot special
Total running time of the script: (0 minutes 1.138 seconds)
