How to convert a FEFLOW model and simulate it in OGS.#
In this example we show how a simple FEFLOW model can be converted to a pyvista.UnstructuredGrid and then be simulated in OGS.
Necessary imports
import tempfile
import ifm_contrib as ifm
from ogs6py import ogs
from pyvista import read
convert_properties_mesh,
extract_cell_boundary_conditions,
setup_prj_file,
steady_state_diffusion,
from ogstools.feflowlib.examples import path_box_Neumann
from ogstools.feflowlib.tools import (
extract_point_boundary_conditions,
get_material_properties,
Load a FEFLOW model (.fem) as a FEFLOW document and convert it.
feflow_model = ifm.loadDocument(path_box_Neumann)
pyvista_mesh = convert_properties_mesh(feflow_model)
pyvista_mesh.plot(
show_edges=True, off_screen=True, scalars="P_HEAD", cpos=[0, 1, 0.5]
print(pyvista_mesh)
path_writing = Path(tempfile.mkdtemp("feflow_test_simulation"))
path_mesh = path_writing / "boxNeumann.vtu"
pyvista_mesh.save(str(path_mesh))
UnstructuredGrid (0x7f59355e1880)
N Cells: 11462
N Points: 6768
X Bounds: 0.000e+00, 1.000e+02
Y Bounds: 0.000e+00, 1.000e+02
Z Bounds: -1.000e+02, 0.000e+00
N Arrays: 23
Extract the point and cell boundary conditions and write them to a temporary directory.
point_BC_dict = extract_point_boundary_conditions(path_writing, pyvista_mesh)
# Since there can be multiple point boundary conditions on the bulk mesh,
# they are saved and plotted iteratively.
for path, boundary_condition in point_BC_dict.items():
boundary_condition.save(path)
boundary_condition.plot()
path_topsurface, topsurface = extract_cell_boundary_conditions(
path_mesh, pyvista_mesh
# On the topsurface can be cell based boundary condition.
# The boundary conditions on the topsurface of the model are required for generalization.
topsurface.save(path_topsurface)
Setup a prj-file to run a OGS-simulation
path_prjfile = str(path_mesh.with_suffix(".prj"))
prjfile = ogs.OGS(PROJECT_FILE=str(path_prjfile))
# Get the template prj-file configurations for a steady state diffusion process
model = steady_state_diffusion(
path_writing / "sim_boxNeumann",
prjfile,
model = setup_prj_file(
path_mesh,
pyvista_mesh,
get_material_properties(pyvista_mesh, "P_CONDX"),
"steady state diffusion",
model,
model.write_input(str(path_prjfile))
# Simply print the prj-file as an example.
read_model = ET.parse(str(path_prjfile))
root = read_model.getroot()
ET.dump(root)
<OpenGeoSysProject>
<meshes>
<mesh>boxNeumann.vtu</mesh>
<mesh>topsurface_boxNeumann.vtu</mesh>
<mesh>P_BC_FLOW.vtu</mesh>
<mesh>P_BCFLOW_2ND.vtu</mesh>
</meshes>
<processes>
<process>
<secondary_variables>
</secondary_variables>
<process_variables>
<process_variable>HEAD_OGS</process_variable>
</process_variables>
</process>
</processes>
<media>
<medium id="0">
<properties>
<property>
<name>diffusion</name>
<type>Constant</type>
</property>
<property>
<name>reference_temperature</name>
<value>293.15</value>
</property>
</properties>
</medium>
</media>
<time_loop>
<processes>
<convergence_criterion>
<type>DeltaX</type>
<norm_type>NORM2</norm_type>
<abstol>1e-15</abstol>
</convergence_criterion>
<time_discretization>
<type>BackwardEuler</type>
</time_discretization>
<time_stepping>
<type>SingleStep</type>
</time_stepping>
</process>
</processes>
<output>
<type>VTK</type>
<prefix>/tmp/tmpiepoz_brfeflow_test_simulation/sim_boxNeumann</prefix>
<timesteps>
<pair>
<repeat>1</repeat>
<each_steps>1</each_steps>
</pair>
</timesteps>
<variables />
</output>
</time_loop>
<parameters>
<parameter>
<name>p0</name>
<value>0</value>
</parameter>
<parameter>
<name>P_BC_FLOW</name>
<type>MeshNode</type>
<mesh>P_BC_FLOW</mesh>
<field_name>P_BC_FLOW</field_name>
</parameter>
<parameter>
<name>P_BCFLOW_2ND</name>
<mesh>P_BCFLOW_2ND</mesh>
<field_name>P_BCFLOW_2ND</field_name>
</parameter>
<parameter>
<name>P_IOFLOW</name>
<type>MeshElement</type>
<mesh>topsurface_boxNeumann</mesh>
<field_name>P_IOFLOW</field_name>
</parameter>
<parameter>
<name>P_SOUF</name>
<field_name>P_SOUF</field_name>
</parameter>
</parameters>
<process_variables>
<process_variable>
<name>HEAD_OGS</name>
<components>1</components>
<order>1</order>
<boundary_conditions>
<boundary_condition>
<type>Dirichlet</type>
<parameter>P_BC_FLOW</parameter>
</boundary_condition>
<type>Neumann</type>
<parameter>P_BCFLOW_2ND</parameter>
<parameter>P_IOFLOW</parameter>
</boundary_conditions>
<source_terms>
<source_term>
<type>Volumetric</type>
<parameter>P_SOUF</parameter>
</source_term>
</source_terms>
</process_variable>
<nonlinear_solvers>
<nonlinear_solver>
<name>basic_picard</name>
<type>Picard</type>
<max_iter>10</max_iter>
</nonlinear_solver>
</nonlinear_solvers>
<linear_solvers>
<linear_solver>
<lis>-i cg -p jacobi -tol 1e-6 -maxiter 100000</lis>
<eigen>
<solver_type>CG</solver_type>
<error_tolerance>1e-6</error_tolerance>
</eigen>
<petsc>
<prefix>sd</prefix>
<parameters>-sd_ksp_type cg -sd_pc_type bjacobi -sd_ksp_rtol 1e-16 -sd_ksp_max_it 10000</parameters>
</petsc>
</linear_solver>
</linear_solvers>
</OpenGeoSysProject>
Run the model
model.run_model(logfile=str(path_writing / "out.log"))
OGS finished with project file /tmp/tmpiepoz_brfeflow_test_simulation/boxNeumann.prj.
Execution took 0.29024648666381836 s
ogs_sim_res = read(str(path_writing / "sim_boxNeumann_ts_1_t_1.000000.vtu"))
ogs_sim_res.plot(
show_edges=True, off_screen=True, scalars="HEAD_OGS", cpos=[0, 1, 0.5]
Calculate the difference to the FEFLOW simulation and plot it.
diff = pyvista_mesh["P_HEAD"] - ogs_sim_res["HEAD_OGS"]
pyvista_mesh["diff_HEAD"] = diff
pyvista_mesh.plot(
show_edges=True, off_screen=True, scalars="diff_HEAD", cpos=[0, 1, 0.5]
Total running time of the script: (0 minutes 1.269 seconds)
