Convergence study (spatial & temporal refinement)#
ogstools.physics.nuclearwasteheat model.
from shutil import rmtree
from ogs6py import ogs
from ogstools import meshlib, msh2vtu, physics, propertylib, studies, workflow
temp_dir = Path(mkdtemp(prefix="nuclear_decay"))
Let’s run the different simulations with increasingly fine spatial and
temporal discretization via ogs6py. The mesh and its boundaries are generated
easily via gmsh and ogstools.msh2vtu. First some definitions:
n_refinements = 4
prefix = "stepsize_{0}"
sim_results = []
msh_path = temp_dir / "rect.msh"
script_path = Path(studies.convergence.examples.nuclear_decay_bc).parent
prj_path = studies.convergence.examples.nuclear_decay_prj
ogs_args = f"-m {temp_dir} -o {temp_dir} -s {script_path}"
Now the actual simulations:
for dt, n_cells in zip(time_step_sizes, edge_cells):
meshlib.rect(lengths=100.0, n_edge_cells=[n_cells, 1], out_name=msh_path)
_ = msh2vtu.msh2vtu(msh_path, output_path=temp_dir, log_level="ERROR")
model = ogs.OGS(PROJECT_FILE=temp_dir / "default.prj", INPUT_FILE=prj_path)
model.replace_text(str(dt * sec_per_yr), ".//delta_t")
model.replace_text(prefix.format(dt), ".//prefix")
sim_results += [temp_dir / (prefix.format(dt) + "_rect_domain.xdmf")]
OGS finished with project file /tmp/nuclear_decaya7ry_642/default.prj.
Execution took 0.8562610149383545 s
Execution took 0.9398870468139648 s
Execution took 1.1167018413543701 s
Execution took 1.5174167156219482 s
for sim_result, dt in zip(sim_results, time_step_sizes):
mesh_series = meshlib.MeshSeries(sim_result)
results = {"heat_flux": [], "temperature": []}
for ts in mesh_series.timesteps:
mesh = mesh_series.read(ts)
results["temperature"] += [np.max(mesh.point_data["temperature"])]
max_T = propertylib.presets.temperature(results["temperature"]).magnitude
# times 2 due to symmetry, area of repo, to kW
results["heat_flux"] += [np.max(mesh.point_data["heat_flux"][:, 0])]
tv = np.asarray(mesh_series.timevalues) / sec_per_yr
ax1.plot(tv, max_T, lw=1.5, label=f"{dt=}")
edges = np.append(0, tv)
ax2.set_xlabel("time / yrs")
ax1.set_ylabel("max T / °C")
ax2.set_ylabel("heat / kW")
ax1.legend()
ax2.legend()
report_name = temp_dir / "report.ipynb"
output_name=report_name,
mesh_paths=sim_results,
timevalue=30 * sec_per_yr,
property_name="temperature",
refinement_ratio=2.0,
timevalue=150 * sec_per_yr,
mesh_series = [meshlib.MeshSeries(sim_result) for sim_result in sim_results]
mesh_series, propertylib.presets.temperature, units=["s", "yrs"]
Looking at the relative errors, we see a higher error right at the beginning. This is likely due to the more dynamic behavior at the beginning.
fig = studies.convergence.plot_convergence_error_evolution(evolution_metrics)
Total running time of the script: (0 minutes 19.520 seconds)
