Features of propertylib#
propertylib provides a common interface for other modules to structure
reading, conversion and output of mesh data.
from ogstools.propertylib import presets
There are some predefined default properties:
tab = pd.DataFrame(presets.all_properties).set_index("output_name")
tab["type"] = [p.type_name for p in presets.all_properties]
tab.drop(["func", "bilinear_cmap"], axis=1).sort_values(["mask", "data_name"])
You can access properties either form the entire collection or from a subset which only contains properties available to a specific OGS process. Calling a property converts the argument from data_unit to output_unit and applies a function if specified.
print(presets.temperature(273.15)) # access from the entire collection
print(presets.strain(0.01)) # access from Mechanics collection
0 °C
1 %
VectorProperties and MatrixProperties contain other Properties which represent the result of an applied function on itself. Components can be accessed with brackets. VectorProperties should be of length 2 or 3 corresponding to the dimension. MatrixProperties likewise should be of length 4 [xx, yy, zz, xy] or 6 [xx, yy, zz, xy, yz, xz].
Element 1 (counting from 0) of a 3D displacement vector:
print(presets.displacement[1]([0.01, 0.02, 0.03]))
0.02 m
Magnitude of a 2D displacement vector from:
print(presets.displacement.magnitude([0.03, 0.04]))
0.05 m
Log of Magnitude of a 2D velocity vector from the Hydraulics collection:
print(presets.velocity.log_magnitude(np.sqrt([50, 50])))
1
Magnitude and trace of a 3D strain matrix:
eps = np.array([1, 3, 9, 1, 2, 2]) * 1e-2
print(presets.strain.magnitude(eps))
print(presets.strain.trace(eps))
10 %
13 %
You can change the attributes of the defaults. For example for temperature from the Thermal Collection from the default output_unit °C to °F:
temp = np.linspace(273.15, 373.15, 10)
fig, axs = plt.subplots(2)
axs[0].plot(presets.temperature(temp), color="r")
temperature_F = presets.temperature.replace(output_unit="°F")
axs[1].plot(temperature_F(temp), color="b")
/workspaces/tools/.venv-devcontainer/lib/python3.9/site-packages/matplotlib/cbook/__init__.py:1345: UnitStrippedWarning: The unit of the quantity is stripped when downcasting to ndarray.
return np.asarray(x, float)
Total running time of the script: (0 minutes 0.081 seconds)
