How to plot data at observation points#
timesteps. Since requested observation points don’t necessarily coincide with
ogstools.meshlib.mesh_series.MeshSeries.probe for more details.
import ogstools as ogs
si = ogs.variables.saturation
Let’s define 4 observation points and plot them on the mesh.
points = np.asarray(
[[x, 0, 60] for x in [0, 40, 80, 120]]
+ [[x, 0, 40] for x in [0, 40, 80, 120]]
fig = mesh_series.mesh(0).plot_contourf(si)
fig.axes[0].scatter(points[:, 0], points[:, 2], s=50, fc="none", ec="r", lw=3)
for i, point in enumerate(points):
fig.axes[0].annotate(str(i), (point[0], point[2] - 5), va="top")
plt.rcdefaults() # TODO
And now probe the points and the values over time:
labels = [f"{i}: {label}" for i, label in enumerate(ogs.plot.utils.justified_labels(points))]
fig = mesh_series.plot_probe(
points=points[:4], variable=si, time_unit="a", labels=labels[:4]
You can also pass create your own matplotlib figure and pass the axes object. Additionally, you can pass any keyword arguments which are known by matplotlibs plot function to further customize the curves. In this case marker and linewidth are not part of the API of plot_probe but get processed correctly anyway. If you want to have more freedom with the data you can just do the probing, adapt to your needs and then do the plotting yourself:
fig, axs = plt.subplots(nrows=2, figsize=[10, 5])
points[:4], si, time_unit="a", ax=axs[0], colors=["k"],
labels=labels[:4], marker=".")
points[4:], si, time_unit="a", ax=axs[1], linestyles=["-"],
labels=labels[4:], linewidth=1,
# add the mean of the observation point timeseries
values = si.transform(mesh_series.probe(points, data_name=si.data_name))
mean_values = np.mean(values.reshape((-1, 2, 4)), axis=-1)
ts = mesh_series.timevalues("a")
for index in range(2):
fig.axes[index].plot(ts, mean_values[:, index], "rk"[index], label="mean")
fig.axes[index].legend()
Total running time of the script: (0 minutes 0.873 seconds)
