Read mesh from file (vtu or xdmf) into pyvista mesh#
MeshSeries takes as mandatory argument a str OR pathlib.Path that represents the location of the pvd or xdmf file. Here, we load example data:
ms # print MeshSeries meta information
MeshSeries:
filepath: /builds/ogs/tools/ogstools/ogstools/examples/meshseries/2D_single_fracture_HT_2D_single_fracture.xdmf
spatial_unit: m
data_type: xdmf
timevalues: 0.0s to 0.0s in 97 steps
reader: <ogstools.meshlib.xdmf_reader.XDMFReader object at 0x7cd485ade230>
rawdata_file: /builds/ogs/tools/ogstools/ogstools/examples/meshseries/2D_single_fracture_HT.h5
Accessing time values#
All time value (in seconds) are within a range (e.g. can be converted to list) Python slicing is supported.
print(f"First 3 time values are: {ms.timevalues()[:3]}.")
# Accessing a specific time step
timestep = 10
print(f"Time value at step {timestep} is {ms.timevalues()[timestep]} s.")
First 3 time values are: [ 0. 900. 1800.].
Time value at step 10 is 9000.0 s.
To get a single mesh at a specified timestep. Read data is cached.
mesh_ts10 = ms.mesh(timestep)
# The mesh taken from a specific time step of the mesh series is a pyvista mesh
# Here we use pyvista functionality plot.
You can select a time steps with the [] operator This example shows the last time step (result) and shows meta information about the mesh.
print(ms[-1])
Mesh (0x7cd485c942e0)
N Cells: 171
N Points: 190
X Bounds: 0.000e+00, 1.000e+01
Y Bounds: 0.000e+00, 2.000e+01
N Arrays: 4
MeshSeries from PVD file#
ms = examples.load_meshseries_THM_2D_PVD()
ms.mesh(0).plot()
Accessing Variables#
A MeshSeries provides access to all values of variable at all time steps.
mesh - Get a PyVista mesh at a specific time step and use PyVista functions (e.g., cell_data). - Efficient for a small set of timesteps, but all data is needed. -
ogstools.meshlib.mesh_series.MeshSeries.mesh-ogstools.meshlib.mesh_series.MeshSeries.__getitem__data[] - Get a specific variable over a specific time range. - Efficient (only XDMF) for a large set of timesteps , but a small amount of cells / points is needed. -
ogstools.meshlib.mesh_series.MeshSeries.data
# Indexing with data()
# `MeshSeries.data("<variable_name>")`` returns an object, that behaves like a
# `Numpy ndarray <https://numpy.org/doc/stable/reference/generated/numpy.ndarray.html>`_.
# It allows `multidimensional indexing on ndarrays <https://numpy.org/doc/stable/user/basics.indexing.html>`_
# beyond `Python slicing <https://www.geeksforgeeks.org/python-list-slicing/>`_.
# Typically, the first dimension is the time step, second dimension is the number of points/cells,
# and the last dimension is the number of components of the variable.
# Be aware that dimensions of length 1 are omitted, obeying to the rules of
# `Indexing on ndarrays <https://numpy.org/doc/stable/user/basics.indexing.html>`_.
# Data does not work for geometry/points or topology/cells).
# This mesh series has 97 time steps and 190 points.
# Temperature is a scalar, Darcy velocity is a vector with 2 components. Both are defined at points.
# 1. No range for a dimension (just single time step) -> this dimension gets omitted
ms.data("temperature")[1, :] # shape is (190,)
# 2. Select range with length for a dimension to keep dimension
ms.data("temperature")[1:2, :] # shape is (1, 190)
# 3. Select all values for all dimensions
ms.data("temperature")[:] # shape is (97,190)
# 4. Negative indices are allow - here we select last 2 steps
ms.data("darcy_velocity")[-2:, 1:4, :] # shape is(2, 3, 2)
# 5. Use select to get a specific range of time steps
temp_on_some_point = ms.data("temperature")[1:3, 2:5] # shape is (2,3)
print(
f"Temperature at time steps 1 and 2 for points 2, 3 and 4: {temp_on_some_point}"
Temperature at time steps 1 and 2 for points 2, 3 and 4: [[353.00036868 303. 353. ]
[353.00012081 303. 353. ]]
Values function#
Convenience function to get all values of a variable.
See ogstools.meshlib.mesh_series.MeshSeries.values.
dv_all = ms.values("darcy_velocity")
print(
f"Shape of darcy_velocity (time steps, num of points, x and y): {dv_all.shape}"
# temperature is a scalar - the last dimension of length 1 is omitted
t_all = ms.values("temperature")
print(f"Shape of temperature (time steps, num of points): {t_all.shape}")
Shape of darcy_velocity (time steps, num of points, x and y): (97, 190, 2)
Shape of temperature (time steps, num of points): (97, 190)
Total running time of the script: (0 minutes 1.178 seconds)
