Spatial & temporal refinement - nuclear decay#
ogstools.physics.nuclearwasteheat model.
import ogstools as ogs
from ogstools import examples, meshlib, msh2vtu, physics, studies, workflow
temp_dir = Path(mkdtemp(prefix="nuclear_decay"))
Let’s run the different simulations with increasingly fine spatial and
temporal discretization via ogs6py. The mesh and its boundaries are generated
easily via gmsh and ogstools.msh2vtu. First some definitions:
n_refinements = 4
prefix = "stepsize_{0}"
sim_results = []
msh_path = temp_dir / "rect.msh"
script_path = Path(examples.pybc_nuclear_decay).parent
ogs_args = f"-m {temp_dir} -o {temp_dir} -s {script_path}"
Now the actual simulations:
for dt, n_cells in zip(time_step_sizes, edge_cells, strict=False):
ogs.meshlib.rect(
lengths=100.0, n_edge_cells=[n_cells, 1], out_name=msh_path
_ = msh2vtu.msh2vtu(msh_path, output_path=temp_dir, log_level="ERROR")
prj = ogs.Project(output_file=temp_dir / "default.prj", input_file=prj_path)
prj.replace_text(str(dt * sec_per_yr), ".//delta_t")
prj.replace_text(prefix.format(dt), ".//prefix")
prj.write_input()
prj.run_model(write_logs=False, args=ogs_args)
sim_results += [temp_dir / (prefix.format(dt) + "_rect_domain.xdmf")]
OGS finished with project file /tmp/nuclear_decaycp0tgweo/default.prj.
Execution took 1.7088615894317627 s
Execution took 1.7861390113830566 s
Execution took 1.9428648948669434 s
Execution took 2.2398030757904053 s
for sim_result, dt in zip(sim_results, time_step_sizes, strict=False):
mesh_series = ogs.MeshSeries(sim_result)
results = {"heat_flux": [], "temperature": []}
for ts in mesh_series.timesteps:
mesh = mesh_series.mesh(ts)
results["temperature"] += [np.max(mesh.point_data["temperature"])]
max_T = ogs.variables.temperature.transform(results["temperature"])
# times 2 due to symmetry, area of repo, to kW
results["heat_flux"] += [np.max(mesh.point_data["heat_flux"][:, 0])]
tv = np.asarray(mesh_series.timevalues("a"))
ax1.plot(tv, max_T, lw=1.5, label=f"{dt=}")
edges = np.append(0, tv)
ax2.set_xlabel("time / yrs")
ax1.set_ylabel("max T / °C")
ax2.set_ylabel("heat / kW")
ax1.legend()
ax2.legend()
report_name = temp_dir / "report.ipynb"
output_name=report_name,
mesh_paths=sim_results,
timevalue=30 * sec_per_yr,
variable_name="temperature",
refinement_ratio=2.0,
timevalue=150 * sec_per_yr,
mesh_series = [meshlib.MeshSeries(sim_result) for sim_result in sim_results]
mesh_series, ogs.variables.temperature, units=["s", "yrs"]
0%| | 0/7 [00:00<?, ?it/s]
57%|█████▋ | 4/7 [00:00<00:00, 32.70it/s]
100%|██████████| 7/7 [00:00<00:00, 33.02it/s]
Looking at the errors, we see a higher error right at the beginning. This is likely due to the more dynamic behavior at the beginning.
Total running time of the script: (0 minutes 20.804 seconds)
