Plotting different process variables on already existing Matplotlib figures / axes#
This tutorial covers plotting meshseries data using user defined matplotlib objects for figure and / or axes. This is useful if different plotting functions ogstools are to be used on different subplots within the same figure.
import ogstools as ogs
meshseries = examples.load_meshseries_THM_2D_PVD()
ogs.plot.setup.combined_colorbar = False
Compare different variables#
It is possible to plot various variables in different subplots of the same figure:
fig, ax = plt.subplots(2, 1, figsize=(15, 15))
meshseries.mesh(0).plot_contourf(ogs.variables.temperature, fig=fig, ax=ax[0])
meshseries.mesh(1).plot_contourf(ogs.variables.displacement, fig=fig, ax=ax[1])
Plot two time steps and their difference#
We can use the same approach to plot the difference between different time steps can be plotted. Color bars can be drawn automatically, if user provides both Figure and Axes objects:
fig, ax = plt.subplots(3, 1, figsize=(20, 30))
meshseries.mesh(1).plot_contourf(ogs.variables.temperature, fig=fig, ax=ax[1])
diff_mesh = meshseries.mesh(1).difference(
    meshseries.mesh(0), ogs.variables.temperature
diff_mesh.plot_contourf(ogs.variables.temperature, fig=fig, ax=ax[2])
ax[0].set_title(r"$T(\mathrm{t}_{0})$")
ax[1].set_title(r"$T(\mathrm{t}_{end})$")
ax[2].set_title(r"$T(\mathrm{t}_{end})$-$T(\mathrm{t}_{0})$")
Total running time of the script: (0 minutes 1.681 seconds)
