Extract a 1D profile from 2D and plot it#
import ogstools as ogs
Single fracture#
Define a profile line by providing a list of points in x, y, z coordinates and load an example data set:
mesh = examples.load_meshseries_HT_2D_XDMF().mesh(-1)
profile_HT = np.array([[4, 2, 0], [4, 18, 0]])
mesh_sp, mesh_kp = ogs.meshlib.sample_polyline(
    mesh, ["pressure", "temperature"], profile_HT
It has returned a pandas DataFrame containing all information about the profile and a numpy array with the position of the “knot-points”. Let’s investigate the DataFrame first:
mesh_sp.head(10)
We can see the spatial coordinates of points on the profile (“x”, “y”, “z” - columns), distances from the beginning of the profile (“dist”) and within current segment (“dist_in_segment”). Note, that since we defined our profile on only two points, there is only one segment, hence in this special case columns dist and dist_in_segment are identical. At the end of the DataFrame we can can find two columns with the variables that we are interested in: “temperature” and “pressure”. Each occupies one column, as those are scalar values. Using columns “dist”, “pressure” and “temperature” we can easily plot the data:
fig, ax = plt.subplots(1, 1, figsize=(7, 5))
ax = mesh.plot_linesample(
    x="dist",
    variable="pressure",
    profile_points=profile_HT,
    ax=ax,
    fontsize=15,
ax_twinx = ax.twinx()
ax_twinx = mesh.plot_linesample(
    x="dist",
    variable="temperature",
    ax=ax_twinx,
    fontsize=15,
ogs.plot.utils.color_twin_axes(
    [ax, ax_twinx],
    [ogs.variables.pressure.color, ogs.variables.temperature.color],
What happens when we are interested in a vector variable? We can see it in the following example using the Darcy velocity:
    mesh, "darcy_velocity", profile_HT
mesh_sp.head(5)
Now we have two columns for the variable. The Darcy velocity is a vector, therefore “sample_over_polyline” has split it into two columns and appended the variable name with increasing integer. Note, that this suffix has no physical meaning and only indicates order. It is up to user to interpret it in a meaningful way. By the OpenGeoSys conventions, “darcy_velocity_0” will be in the x-direction and “darcy_velocity_1” in y-direction.
Elder benchmark#
In this example we will use a Variable object from the ogstools to sample the data. This allows “sample_over_polyline” to automatically convert from the “data_unit” to the “output_unit”:
profile_CT = np.array([[47.0, 1.17, 72.0], [-4.5, 1.17, -59.0]])
mesh = examples.load_meshseries_CT_2D_XDMF().mesh(11)
    mesh, ogs.variables.saturation, profile_CT
As before we can see the profile parameters and propertiy values in a DataFrame:
mesh_sp.head(5)
This time we will prepare more complicated plot showing both the mesh and the profile.
fig, ax = mesh.plot_linesample_contourf(
    ogs.variables.saturation, profile_CT, resolution=100
THM#
It is also possible to obtain more than one variable at the same time using more complex profiles. They can be constructed by providing more than 2 points. With those points:
profile_THM = np.array(
        [-1000.0, -175.0, 6700.0],  # Point A
        [-600.0, -600.0, 6700.0],  # Point B
        [100.0, -300.0, 6700.0],  # Point C
        [3500, -900.0, 6700.0],  # Point D
the profile will run as follows:
Point B will at the same time be the last point in the first segment AB and first one in second segment BC, however in the returned array, it will occur only once. For this example we will use a different dataset:
mesh = examples.load_meshseries_THM_2D_PVD().mesh(-1)
ms_THM_sp, dist_at_knot = ogs.meshlib.sample_polyline(
    mesh,
    [ogs.variables.pressure, ogs.variables.temperature],
    profile_THM,
    resolution=100,
Again, we can investigate the returned DataFrame, but this time we will have a look at its beginning:
ms_THM_sp.head(5)
and end:
ms_THM_sp.tail(10)
Note, that unlike in the first example, here the columns “dist” and “dist_in_segment” are not identical, as this time profile consists of multiple segments. The following figure illustrates the difference:
plt.rcdefaults()
ax: plt.Axes
fig, ax = plt.subplots(1, 1, figsize=(7, 3))
ax.plot(ms_THM_sp["dist"], label="dist")
ax.plot(ms_THM_sp["dist_in_segment"], label="dist_in_segment")
ax.set_xlabel("Point ID / -")
ax.set_ylabel("Distance / m")
ax.legend()
The orange line returns to 0 twice. It is because of how the overlap of nodal points between segments is handled. A nodal point always belongs to the segment it starts: point B is included in segment BC but not AB and point C in CD but not in in BC. The following figure shows the profile on the mesh:
plt.rcdefaults()
    profile_THM,
    resolution=100,
Total running time of the script: (0 minutes 1.864 seconds)
