Remeshing with triangle elements#
This short example showcases the function remesh_with_tri which allows us to take an existing mesh and re-discretize it with triangle elements. This is useful for models, where the underlying meshing script is not available or hard to adapt.
import ogstools as ogs
from ogstools.msh2vtu import msh2vtu
mesh = examples.load_meshseries_THM_2D_PVD().mesh(1)
elements.
fig = mesh.plot_contourf(ogs.variables.material_id)
Here, we do the remeshing and use msh2vtu to convert the resulting msh file to an OGS-compatible vtu file.
temp_dir = Path(mkdtemp())
msh_path = temp_dir / "tri_mesh.msh"
ogs.meshlib.gmsh_meshing.remesh_with_triangle(mesh, msh_path)
msh2vtu(msh_path, temp_dir, reindex=False, log_level="ERROR")
mesh = ogs.Mesh(temp_dir / "tri_mesh_domain.vtu")
Total running time of the script: (0 minutes 3.636 seconds)
