How to Create Time Slices#
In this example we show how to create a filled contourplot of transient data over a sampling line. For this purpose we use a component transport example from the ogs benchmark gallery (https://www.opengeosys.org/docs/benchmarks/hydro-component/elder/).
Let’s load the data and create 3 different lines to sample over: vertical, horizontal and diagonal.
import ogstools as ogs
si = ogs.variables.saturation
points_vert = np.linspace([25, 0, -75], [25, 0, 75], num=100)
points_hori = np.linspace([0, 0, 60], [150, 0, 60], num=100)
points_diag = np.linspace([25, 0, 75], [100, 0, 0], num=100)
fig = mesh_series.mesh(-1).plot_contourf(si, vmin=0)
fig.axes[0].plot(points_vert[[0, -1], 0], points_vert[[0, -1], 2], "-k2")
fig.axes[0].plot(points_hori[[0, -1], 0], points_hori[[0, -1], 2], "--k2")
fig.axes[0].plot(points_diag[[0, -1], 0], points_diag[[0, -1], 2], "-.k2")
[<matplotlib.lines.Line2D object at 0x7cd473a87370>]
The function plot_time_slice automatically detects if the line lies on a cardinal direction and labels the y-axes with the changing spatial dimension.
fig = mesh_series.plot_time_slice(si, points_vert, time_unit="a")
By default the plot is smoothened with interpolation. When deactivated, we see the raw sampled data. Be sure to adjust the number of sampling points if the MeshSeries contains a lot of timesteps.
    si, points_vert, time_unit="a", interpolate=False
The horizontal sampling line gets also labeled appropriately.
fig = mesh_series.plot_time_slice(si, points_hori, time_unit="a")
If the line doesn’t point in a cardinal direction the distance along the line is used for the y-axis by default. You can however, specify if you want to use spatial dimension via the argument “y_axis”. This may be useful when plotting data of an edge / boundary of the mesh.
fig = mesh_series.plot_time_slice(si, points_diag, time_unit="a")
Total running time of the script: (0 minutes 1.454 seconds)
