How to work with FEFLOW data in pyvista.#
In this example we show how a simple FEFLOW model consisting of two layers can be converted to a pyvista.UnstructuredGrid.
Let us convert only the points and cells at first.
import ifm_contrib as ifm
convert_geometry_mesh,
update_geometry,
from ogstools.feflowlib.examples import path_2layers_model
# Load a FEFLOW model (.fem) or FEFLOW results file (.dac) as a FEFLOW document.
feflow_model = ifm.loadDocument(path_2layers_model)
pv_mesh = convert_geometry_mesh(feflow_model)
pv_mesh.plot(show_edges=True, off_screen=True)
02.04.2024 16:19:56 - INFO - There are 75 number of points and 32 number of cells to be converted.
02.04.2024 16:19:57 - INFO - Translator(prefix=None)
02.04.2024 16:19:57 - INFO - awaiting runner setup
02.04.2024 16:19:57 - INFO - awaiting site startup
02.04.2024 16:19:57 - INFO - Print WSLINK_READY_MSG
02.04.2024 16:19:57 - INFO - Schedule auto shutdown with timout 0
02.04.2024 16:19:57 - INFO - awaiting running future
To this mesh we add point and cell data.
pv_mesh = update_geometry(pv_mesh, feflow_model)
pv_mesh.plot(scalars="P_HEAD", show_edges=True, off_screen=True)
print(pv_mesh)
02.04.2024 16:19:57 - INFO - MaterialIDs refer to: {}
02.04.2024 16:19:57 - INFO - These data arrays refer to point data: ['SLICE', 'TOP_NODE', 'X', 'Y', 'P_BC_FLOW', 'P_ELEV', 'P_HEAD', 'P_MSH_XY', 'P_MSH_Y', 'P_PRESS']
02.04.2024 16:19:57 - INFO - These data arrays refer to cell data: ['LAYER', 'TOP_ELEMENT', 'P_COMP', 'P_CONDX', 'P_CONDY', 'P_CONDZ', 'P_INACTIVE_ELE', 'P_IOFLOW', 'P_SOUF', 'P_TRAF_IN', 'P_TRAF_OUT', 'MaterialIDs']
02.04.2024 16:19:57 - INFO - These data arrays have been neglected as they are full of nans: ['P_MOD_FLOW', 'P_BCFLOWMOD_2ND', 'P_BCFLOWMOD_2ND_INT', 'P_BCFLOWMOD_3RD', 'P_BCFLOWMOD_3RD_INT', 'P_BCFLOWMOD_4TH', 'P_BCFLOW_2ND', 'P_BCFLOW_2ND_INT', 'P_BCFLOW_3RD', 'P_BCFLOW_3RD_INT', 'P_BCFLOW_4TH', 'P_FLOWBCC_1ST_MAX', 'P_FLOWBCC_FIRST', 'P_FLOWBCC_2ND_MAX', 'P_FLOWBCC_2ND_MAX_INT', 'P_FLOWBCC_2ND_MIN', 'P_FLOWBCC_2ND_MIN_INT', 'P_FLOWBCC_3RD_MAX_FLUX', 'P_FLOWBCC_3RD_MAX_HEAD', 'P_FLOWBCC_3RD_MAX_INT_FLUX', 'P_FLOWBCC_3RD_MAX_INT_HEAD', 'P_FLOWBCC_3RD_MIN_FLUX', 'P_FLOWBCC_3RD_MIN_HEAD', 'P_FLOWBCC_3RD_MIN_INT_FLUX', 'P_FLOWBCC_3RD_MIN_INT_HEAD', 'P_FLOWBCC_LAST', 'P_FLOWBCC_4TH_MIN']
UnstructuredGrid (0x7f30bceaf520)
N Cells: 32
N Points: 75
X Bounds: 3.000e+01, 7.000e+01
Y Bounds: 3.000e+01, 7.000e+01
Z Bounds: -2.000e+01, 0.000e+00
N Arrays: 22
This allows to use the FEFLOW model for OGS simulation or to observe it in Paraview`.
pv_mesh.save("2layers_model.vtu")
As the converted mesh is a pyvista.UnstructuredGrid, we can plot it using meshplotlib.
fig = mpl.plot(pv_mesh.slice("z"), "P_HEAD")
Total running time of the script: (0 minutes 2.597 seconds)
