This example demonstrates how to create a Borehole Heat Exchanger (BHE) mesh.
from pyvista.plotting import Plotter
from ogstools.meshlib.gmsh_meshing import bhe_mesh
from ogstools.msh2vtu import msh2vtu
Generate a customizable BHE mesh (using gmsh):
tmp_dir = Path(mkdtemp())
msh_file = tmp_dir / "bhe.msh"
bhe_mesh(
    width=20,
    length=30,
    depth=40,
    x_BHE=10,
    y_BHE=10,
    bhe_depth=25,
    out_name=msh_file,
Now we convert the gmsh mesh to the VTU format with msh2vtu. Passing the list of dimensions [1, 3] to msh2vtu ensures, that the line elements will also be part of the domain mesh.
msh2vtu(
    msh_file, output_path=tmp_dir, dim=[1, 3], reindex=True, log_level="ERROR"
0
Load the domain mesh and extract BHE line:
mesh = pv.read(tmp_dir / "bhe_domain.vtu")
bhe_line = mesh.extract_cells_by_type(pv.CellType.LINE)
Visualize the mesh:
p = Plotter()
p.add_mesh(mesh, style="wireframe", color="grey")
p.add_mesh(
    mesh.clip("x", bhe_line.center, crinkle=True),
    show_edges=True,
    scalars="MaterialIDs",
    cmap="Accent",
    categories=True,
    scalar_bar_args={"vertical": True, "n_labels": 2, "fmt": "%.0f"},
p.add_mesh(bhe_line, color="r", line_width=3)
p.show()
Total running time of the script: (0 minutes 0.545 seconds)
