Labeling directional shared axes#
Warning
This example discusses functionality that may experience breaking changes in the near future!
For this example we load a 2D meshseries from within the meshplotlib
examples. This tutorial covers automatic labeling the directional axes (X and Y)
under various conditions (shared and nor shared X and Y axes).
Import Python packages, change some settings and load example data set
from ogstools.meshplotlib import (
clear_labels,
examples,
label_spatial_axes,
plot,
setup,
from ogstools.propertylib.presets import temperature
plt.rcParams.update({"font.size": 32})
setup.reset()
setup.combined_colorbar = False
meshseries = examples.meshseries_THM_2D
mesh_a = meshseries.read(0)
mesh_b = meshseries.read(1)
First, by default (without shared axes) both X and Y axes will be labeled automatically. The default is that both axes are shared and this will be respected.
fig = plot([mesh_a, mesh_b], temperature)
On user provided figure and axis, this behaviour is different. To allow for more complex combinations of plot functions, meshseries and process variables, the axis belonging to specific subplot has to be passed. In this case the default is to plot labels on each axis regardless of whether it is share or not.
fig, ax = plt.subplots(2, 2, figsize=(40, 20), sharex=True, sharey=True)
plot(mesh_a, temperature, fig=fig, ax=ax[0][0])
plot(mesh_b, temperature, fig=fig, ax=ax[1][0])
diff_ab = difference(mesh_a, mesh_b, temperature)
diff_ba = difference(mesh_b, mesh_a, temperature)
plot(diff_ab, temperature, fig=fig, ax=ax[0][1])
plot(diff_ba, temperature, fig=fig, ax=ax[1][1])
If user wishes to have labels respecting shared axes, they need to be first removed and applied again. Meshplotlib provides two function that make it easy: clear_labels and label_spatial_axes. They have to be called after the last plot related function call.
plot(difference(mesh_a, mesh_b, temperature), temperature, fig=fig, ax=ax[0][1])
plot(difference(mesh_b, mesh_a, temperature), temperature, fig=fig, ax=ax[1][1])
clear_labels(ax)
label_spatial_axes(ax)
Total running time of the script: (0 minutes 3.054 seconds)
