How to create Animations#
To demonstrate the creation of an animated plot we use a component transport example from the ogs benchmark gallery (https://www.opengeosys.org/docs/benchmarks/hydro-component/elder/).
from ogstools.meshplotlib import examples, setup
from ogstools.meshplotlib.animation import animate
setup.reset()
mesh_series = examples.meshseries_CT_2D
mesh_property = Scalar(
Let’s use fixed scale limits to prevent rescaling during the animation.
setup.p_min = 0
setup.p_max = 100
setup.dpi = 50
You can choose which timesteps to render by passing either an int array corresponding to the indices, or a float array corresponding to the timevalues to render. If a requested timevalue is not part of the timeseries it will be interpolated. In this case every second frame will be interpolated.
timevalues = np.linspace(
    mesh_series.timevalues[0], mesh_series.timevalues[-1], num=25
Now, let’s animate the saturation solution. A timescale at the top indicates existing timesteps and the position of the current timevalue. Note that rendering many frames in conjunction with large meshes might take a really long time.
titles = [f"{tv/(365.25*86400):.1f} yrs" for tv in timevalues]
anim = animate(mesh_series, mesh_property, timevalues, titles)
The animation can be saved (as mp4) like so:
from ogstools.meshplotlib.animation import save_animation
save_animation(anim, "Saturation", fps=5)
Total running time of the script: (0 minutes 10.567 seconds)
