Logparser: Predefined Analyses#
In this section, we showcase various predefined analyses available in the log parser. We utilize project files from the following benchmarks: ogs: Constant viscosity (Hydro-Thermal) and for the staggered scheme we use a prj from ogs tests: HT StaggeredCoupling HeatTransportInStationaryFlow
log_adaptive_timestepping,
log_staggered,
The preprocessing of logs remains consistent across all examples and thoroughly explained in Logparser: Advanced topics.
Analysis of iterations per time step#
For detailed explanation, refer to: Logparser: Introduction. (Section: Use predefined analyses)
ogstools.logparser.analysis_time_step
df_ts_it
Analysis of computational efficiency by time step#
The resulting table represents performance metrics for different parts of the simulation,
organized by time step. It utilizes ogstools.logparser.analysis_time_step.
displaying metrics such
as output time [s], step size [s], time step solution time [s], assembly time [s],
Dirichlet time [s], and linear solver time [s].
df_ts = ot.logparser.analysis_time_step(df_log)
df_ts = df_ts.loc[0]
# Removing MPI_process (index=0) from result (all are 0) for serial log.
df_ts
Selecting specific metrics (3) and plotting using pandas plot function.
df_ts[["assembly_time", "dirichlet_time", "linear_solver_time"]].plot(
logy=True, grid=True
<Axes: xlabel='time_step'>
Analysis of convergence criteria - Newton iterations#
The ogstools.logparser.analysis_convergence_newton_iteration
function allows for the examination of convergence criteria based on
Newton iterations. The resulting table provides convergence metrics for monolithic processes.
For details, refer to the documentation on
<convergence_criterion > defined in in the prj file.
|x| is a norm of a vector of the global component (e.g. pressure, temperature, displacement).
|dx| is the change of a norm of the global component between 2 iteration of non linear solver.
|dx|/|x| is the relative change of a norm of the global component
For this example we had defined in the prj-file:
<convergence_criterion>
<type>DeltaX</type>
<norm_type>NORM2</norm_type>
<abstol>1.e-3</abstol>
</convergence_criterion>
The resulting table contains |x|, |dx| and |dx|/|x| at different time steps, processes and non linear solver iterations.
ot.logparser.analysis_convergence_newton_iteration(df_log)
Staggered#
The resulting table provides convergence criteria for staggered coupled processes,
utilizing ogstools.logparser.analysis_convergence_coupling_iteration
Logs are generated from running
ogs benchmark: HeatTransportInStationaryFlow
records = ot.logparser.parse_file(log_staggered)
ot.logparser.analysis_convergence_coupling_iteration(df_log)
Analysis of model time and clock time#
The ogstools.logparser.model_and_clock_time function allows to
examine needed iterations, clock time, and step size over model time per
attempted time step. This is especially useful to analyze the runtime
behaviour of a simulation which employs adaptive time stepping. The following
example failed as the simulation reached the minimal allowed time step size.
records = ot.logparser.parse_file(log_adaptive_timestepping)
df_t = ot.logparser.model_and_clock_time(df_log)
df_t[["step_size", "clock_time", "iterations"]].plot(grid=True, subplots=True)
array([<Axes: xlabel='model_time'>, <Axes: xlabel='model_time'>,
<Axes: xlabel='model_time'>], dtype=object)
To get an overview of the convergence behavior of the nonlinear solver over the entire simulation we can plot the relative error as a heatmap.
fig = ot.logparser.plot_convergence(df_log, "dx_x")
We can also plot this data over the model time. Note, that the last timesteps are so small, that they are not visible anymore here:
fig = ot.logparser.plot_convergence(df_log, "dx_x", x_metric="model_time")
Further we can calculate the convergence order and plot it in the same manner.
In order to estimate the convergence order we need to take into account
multiple values and thus cannot assign each iteration a convergence order.
Only for iterations i of i >= n an order is calculated and plotted.
See: convergence_order_per_ts_iteration()
for more info.
fig = ot.logparser.plot_convergence_order(df_log)
Total running time of the script: (0 minutes 2.101 seconds)
