Logparser: Advanced topics#
We address to following:
Handling OGS logs from parallel computation (OGS with MPI runs).
Reduce computation time required for log processing.
Creating custom analyses.
Although these topics are discussed together, they are independent of each other and can be utilized separately as needed.
log_parallel,
Logs from parallel computations (with MPI)#
The log file to be investigated in this example is the result of a mpirun (-np 3) from https://gitlab.opengeosys.org/ogs/ogs/-/blob/master/Tests/Data/EllipticPETSc/cube_1e3_XDMF_np3.prj
records = ot.logparser.parse_file(log_parallel)
df_parallel = ot.logparser.fill_ogs_context(df_records)
df_parallel
df_ts = ot.logparser.analysis_time_step(df_parallel)
df_ts
Aggregate measurements over all MPI processes#
If you are not particularly interested in the performance of each MPI_process pandas gives you all you need to further process data. However, for performance measurement it is recommended to consider always the slowest MPI_process for meaningful interpretation of overall performance (because of synchronization barriers in the evaluation scheme of OGS). Then the resulting DataFrame has the same structure like a DataFrame gained from serial OGS log.
<Axes: >
Reduce computation time to process logs#
To reduce the computation to evaluate the logs, you can either - Reduce set of regular expressions, when you exactly know, what you final analysis will need AND / OR - Save and load the pandas.DataFrame for the records.
Reduce regular expression#
The logparser tries to find matching regular expressions for each line. By default it iterates over all entries specified in ogstools.logparser.ogs_regexes.
You can reduce it to the amount of entries you are actually interested in.
For this example we are only interested in the number of iterations per time step.
Because the parsing process is expensive, it is useful to store the records to a file.
According to ogstools.logparser.parse_file
via parameter regexes a list of reduced or custom regexes can be provided.
Save and load records#
We recommend saving the records by any of these methodes http://pandas.pydata.org/pandas-docs/stable/user_guide/io.html.
For example with HDF:
`python
df_records.to_hdf("anyfilename.csv")
pd.read_hdf("anyfilename.csv")
Custom analyses#
Introduction into functions of the logparser#
The function ogstools.logparser.parse_file iterates over all lines in the log file. For a specific set of regular expressions it finds and creates a new entry into a list (here named records)
print(log_file.read())
print(df_records.columns)
df_records
info: This is OpenGeoSys-6 version 6.5.0-286-ge7ef7067.
info: OGS started on 2024-03-20 11:10:50+0100.
info: Reading project file /home/meisel/o/s/Tests/Data/Parabolic/HT/ConstViscosity/square_5500x5500.prj.
info: readRasters ...
info: readRasters done
info: ConstantParameter: alpha_l
info: ConstantParameter: alpha_t
info: MeshNodeParameter: T0
info: MeshNodeParameter: P0
info: ConstantParameter: p_Dirichlet_topleft
info: ConstantParameter: t_Dirichlet_bottom
info: ConstantParameter: t_Dirichlet_top
info: No source terms for process variable 'T' found.
info: No source terms for process variable 'p' found.
info: Initialize processes.
info: [time] Output of timestep 0 took 0.00447606 s.
info: OpenGeoSys is now initialized.
info: Solve processes.
info: === Time stepping at step #1 and time 1e-07 with step size 1e-07
info: [time] Assembly took 0.0339198 s.
info: [time] Applying Dirichlet BCs took 0.00056946 s.
info: *** Eigen solver compute()
info: -> compute with Eigen iterative linear solver BiCGSTAB (precon ILUT)
info: *** Eigen solver solve()
info: -> solve with Eigen iterative linear solver BiCGSTAB (precon ILUT)
info: iteration: 1/10000
info: residual: 3.923222e-27
info: [time] Linear solver took 0.0752248 s.
info: Convergence criterion: |dx|=2.5591e+07, |x|=1.0114e+09, |dx|/|x|=2.5303e-02
info: [time] Iteration #1 took 0.109927 s.
info: [time] Assembly took 0.014345 s.
info: [time] Applying Dirichlet BCs took 0.000374662 s.
info: iteration: 0/10000
info: residual: 2.203582e-16
info: [time] Linear solver took 0.0172711 s.
info: Convergence criterion: |dx|=0.0000e+00, |x|=1.0114e+09, |dx|/|x|=0.0000e+00
info: [time] Iteration #2 took 0.0323778 s.
info: [time] Solving process #0 took 0.142436 s in time step #1
info: [time] Time step #1 took 0.142505 s.
info: === Time stepping at step #2 and time 1.01e-05 with step size 1e-05
info: [time] Assembly took 0.0133623 s.
info: [time] Applying Dirichlet BCs took 0.000503002 s.
info: residual: 1.554436e-16
info: [time] Linear solver took 0.0272443 s.
info: [time] Iteration #1 took 0.0415321 s.
info: [time] Solving process #0 took 0.0416756 s in time step #2
info: [time] Time step #2 took 0.0418056 s.
info: === Time stepping at step #3 and time 0.0010101 with step size 0.001
info: [time] Assembly took 0.0195802 s.
info: [time] Applying Dirichlet BCs took 0.000451196 s.
info: residual: 3.566227e-15
info: [time] Linear solver took 0.0128035 s.
info: [time] Iteration #1 took 0.0332257 s.
info: [time] Solving process #0 took 0.0333669 s in time step #3
info: [time] Time step #3 took 0.0334961 s.
info: === Time stepping at step #4 and time 0.1010101 with step size 0.1
info: [time] Assembly took 0.0219811 s.
info: [time] Applying Dirichlet BCs took 0.000411231 s.
info: residual: 3.564145e-13
info: [time] Linear solver took 0.0265756 s.
info: [time] Iteration #1 took 0.0535933 s.
info: [time] Solving process #0 took 0.0537398 s in time step #4
info: [time] Time step #4 took 0.0538576 s.
info: === Time stepping at step #5 and time 1.1010101 with step size 1
info: [time] Assembly took 0.0230674 s.
info: [time] Applying Dirichlet BCs took 0.000568268 s.
info: residual: 8.715184e-25
info: [time] Linear solver took 0.0624193 s.
info: Convergence criterion: |dx|=7.9470e+05, |x|=1.0107e+09, |dx|/|x|=7.8631e-04
info: [time] Iteration #1 took 0.0863797 s.
info: [time] Assembly took 0.0214225 s.
info: [time] Applying Dirichlet BCs took 0.000470009 s.
info: residual: 3.997404e-31
info: [time] Linear solver took 0.0433862 s.
info: Convergence criterion: |dx|=5.1365e+00, |x|=1.0107e+09, |dx|/|x|=5.0823e-09
info: [time] Iteration #2 took 0.0656637 s.
info: [time] Assembly took 0.0172118 s.
info: [time] Applying Dirichlet BCs took 0.000423151 s.
info: residual: 2.088883e-16
info: [time] Linear solver took 0.0288133 s.
info: Convergence criterion: |dx|=0.0000e+00, |x|=1.0107e+09, |dx|/|x|=0.0000e+00
info: [time] Iteration #3 took 0.0467204 s.
info: [time] Solving process #0 took 0.198908 s in time step #5
info: [time] Time step #5 took 0.198958 s.
info: === Time stepping at step #6 and time 11.1010101 with step size 10
info: [time] Assembly took 0.0261495 s.
info: [time] Applying Dirichlet BCs took 0.000463085 s.
info: residual: 3.026396e-31
info: [time] Linear solver took 0.023005 s.
info: Convergence criterion: |dx|=3.6481e-04, |x|=1.0107e+09, |dx|/|x|=3.6096e-13
info: [time] Iteration #1 took 0.0496941 s.
info: [time] Solving process #0 took 0.0497864 s in time step #6
info: [time] Time step #6 took 0.0498065 s.
info: === Time stepping at step #7 and time 111.1010101 with step size 100
info: [time] Assembly took 0.00879804 s.
info: [time] Applying Dirichlet BCs took 0.000399928 s.
info: residual: 3.532821e-30
info: [time] Linear solver took 0.0213475 s.
info: Convergence criterion: |dx|=1.1463e-04, |x|=1.0107e+09, |dx|/|x|=1.1342e-13
info: [time] Iteration #1 took 0.030793 s.
info: [time] Solving process #0 took 0.0309831 s in time step #7
info: [time] Time step #7 took 0.0310661 s.
info: === Time stepping at step #8 and time 112.1010101 with step size 1
info: [time] Assembly took 0.018846 s.
info: [time] Applying Dirichlet BCs took 0.000457557 s.
info: residual: 4.739659e-13
info: [time] Linear solver took 0.0227558 s.
info: [time] Iteration #1 took 0.0423717 s.
info: [time] Solving process #0 took 0.0424966 s in time step #8
info: [time] Time step #8 took 0.0426045 s.
info: === Time stepping at step #9 and time 10112.1010101 with step size 10000
info: [time] Assembly took 0.0149187 s.
info: [time] Applying Dirichlet BCs took 0.000423683 s.
info: residual: 3.435195e-27
info: [time] Linear solver took 0.0642781 s.
info: Convergence criterion: |dx|=1.3017e-03, |x|=1.0107e+09, |dx|/|x|=1.2880e-12
info: [time] Iteration #1 took 0.0798325 s.
info: [time] Assembly took 0.0228339 s.
info: [time] Applying Dirichlet BCs took 0.000390014 s.
info: residual: 5.432492e-14
info: [time] Linear solver took 0.0209465 s.
info: [time] Iteration #2 took 0.0445612 s.
info: [time] Solving process #0 took 0.124508 s in time step #9
info: [time] Time step #9 took 0.124606 s.
info: === Time stepping at step #10 and time 30112.1010101 with step size 20000
info: [time] Assembly took 0.0182128 s.
info: [time] Applying Dirichlet BCs took 0.000487623 s.
info: residual: 6.897988e-25
info: [time] Linear solver took 0.020961 s.
info: Convergence criterion: |dx|=1.2900e-01, |x|=1.0107e+09, |dx|/|x|=1.2764e-10
info: [time] Iteration #1 took 0.0400691 s.
info: [time] Assembly took 0.0101489 s.
info: [time] Applying Dirichlet BCs took 0.000380736 s.
info: residual: 1.632629e-13
info: [time] Linear solver took 0.0241102 s.
info: [time] Iteration #2 took 0.0350143 s.
info: [time] Solving process #0 took 0.0752233 s in time step #10
info: [time] Time step #10 took 0.0753644 s.
info: === Time stepping at step #11 and time 70112.1010101 with step size 40000
info: [time] Assembly took 0.00781979 s.
info: [time] Applying Dirichlet BCs took 0.000462857 s.
info: residual: 2.758753e-24
info: [time] Linear solver took 0.0458995 s.
info: Convergence criterion: |dx|=2.5750e-01, |x|=1.0107e+09, |dx|/|x|=2.5478e-10
info: [time] Iteration #1 took 0.0545244 s.
info: [time] Assembly took 0.0268339 s.
info: [time] Applying Dirichlet BCs took 0.000412412 s.
info: residual: 6.530468e-13
info: [time] Linear solver took 0.019183 s.
info: [time] Iteration #2 took 0.046819 s.
info: [time] Solving process #0 took 0.101476 s in time step #11
info: [time] Time step #11 took 0.101619 s.
info: === Time stepping at step #12 and time 150112.1010101 with step size 80000
info: [time] Assembly took 0.021082 s.
info: [time] Applying Dirichlet BCs took 0.000428099 s.
info: residual: 1.103398e-23
info: [time] Linear solver took 0.0636489 s.
info: Convergence criterion: |dx|=5.1497e-01, |x|=1.0107e+09, |dx|/|x|=5.0954e-10
info: [time] Iteration #1 took 0.0880191 s.
info: [time] Assembly took 0.0163409 s.
info: [time] Applying Dirichlet BCs took 0.000534195 s.
info: residual: 1.862392e-23
info: [time] Linear solver took 0.0750684 s.
info: Convergence criterion: |dx|=1.0285e+00, |x|=1.0107e+09, |dx|/|x|=1.0176e-09
info: [time] Iteration #2 took 0.0923162 s.
info: [time] Assembly took 0.0254823 s.
info: [time] Applying Dirichlet BCs took 0.000412396 s.
info: residual: 4.001846e-27
info: [time] Linear solver took 0.0593291 s.
info: Convergence criterion: |dx|=3.2547e-03, |x|=1.0107e+09, |dx|/|x|=3.2204e-12
info: [time] Iteration #3 took 0.0856021 s.
info: [time] Assembly took 0.0207366 s.
info: [time] Applying Dirichlet BCs took 0.000416248 s.
info: residual: 1.219976e-15
info: [time] Linear solver took 0.0204311 s.
info: [time] Iteration #4 took 0.0419823 s.
info: [time] Solving process #0 took 0.308181 s in time step #12
info: [time] Time step #12 took 0.308312 s.
info: === Time stepping at step #13 and time 250112.1010101 with step size 100000
info: [time] Assembly took 0.0171854 s.
info: [time] Applying Dirichlet BCs took 0.000503751 s.
info: residual: 1.280457e-26
info: [time] Linear solver took 0.0449801 s.
info: Convergence criterion: |dx|=1.6632e-04, |x|=1.0107e+09, |dx|/|x|=1.6457e-13
info: [time] Iteration #1 took 0.063108 s.
info: [time] Solving process #0 took 0.063262 s in time step #13
info: [time] Time step #13 took 0.0633941 s.
info: === Time stepping at step #14 and time 450112.1010101 with step size 200000
info: [time] Assembly took 0.0185143 s.
info: [time] Applying Dirichlet BCs took 0.000449672 s.
info: residual: 6.895060e-23
info: [time] Linear solver took 0.0671654 s.
info: Convergence criterion: |dx|=1.2903e+00, |x|=1.0107e+09, |dx|/|x|=1.2767e-09
info: [time] Iteration #1 took 0.0865541 s.
info: [time] Assembly took 0.016444 s.
info: [time] Applying Dirichlet BCs took 0.000371709 s.
info: residual: 1.345547e-22
info: [time] Linear solver took 0.0654912 s.
info: Convergence criterion: |dx|=2.5746e+00, |x|=1.0107e+09, |dx|/|x|=2.5475e-09
info: [time] Iteration #2 took 0.0826806 s.
info: [time] Assembly took 0.0137897 s.
info: [time] Applying Dirichlet BCs took 0.000463929 s.
info: residual: 3.090595e-26
info: [time] Linear solver took 0.0572341 s.
info: Convergence criterion: |dx|=1.1392e-02, |x|=1.0107e+09, |dx|/|x|=1.1272e-11
info: [time] Iteration #3 took 0.0718971 s.
info: [time] Assembly took 0.0185488 s.
info: [time] Applying Dirichlet BCs took 0.00041392 s.
info: residual: 1.082961e-14
info: [time] Linear solver took 0.021471 s.
info: [time] Iteration #4 took 0.0408793 s.
info: [time] Solving process #0 took 0.282293 s in time step #14
info: [time] Time step #14 took 0.28247 s.
info: === Time stepping at step #15 and time 850112.1010101 with step size 400000
info: [time] Assembly took 0.0211512 s.
info: [time] Applying Dirichlet BCs took 0.000473236 s.
info: residual: 6.225048e-24
info: [time] Linear solver took 0.060144 s.
info: Convergence criterion: |dx|=6.9970e-04, |x|=1.0107e+09, |dx|/|x|=6.9232e-13
info: [time] Iteration #1 took 0.0822231 s.
info: [time] Solving process #0 took 0.0823688 s in time step #15
info: [time] Time step #15 took 0.0825334 s.
info: === Time stepping at step #16 and time 1650112.1010101 with step size 800000
info: [time] Assembly took 0.021392 s.
info: [time] Applying Dirichlet BCs took 0.000495058 s.
info: residual: 1.101465e-21
info: [time] Linear solver took 0.0602497 s.
info: Convergence criterion: |dx|=5.1618e+00, |x|=1.0107e+09, |dx|/|x|=5.1074e-09
info: [time] Iteration #1 took 0.082563 s.
info: [time] Assembly took 0.0213065 s.
info: [time] Applying Dirichlet BCs took 0.000448777 s.
info: residual: 2.190699e-21
info: [time] Linear solver took 0.0629832 s.
info: Convergence criterion: |dx|=1.0304e+01, |x|=1.0107e+09, |dx|/|x|=1.0196e-08
info: [time] Iteration #2 took 0.085185 s.
info: [time] Assembly took 0.0242304 s.
info: [time] Applying Dirichlet BCs took 0.00048778 s.
info: residual: 1.708893e-24
info: [time] Linear solver took 0.0667052 s.
info: Convergence criterion: |dx|=4.2945e-02, |x|=1.0107e+09, |dx|/|x|=4.2492e-11
info: [time] Iteration #3 took 0.0931335 s.
info: [time] Assembly took 0.0163042 s.
info: [time] Applying Dirichlet BCs took 0.000525207 s.
info: residual: 2.969843e-13
info: [time] Linear solver took 0.0251236 s.
info: [time] Iteration #4 took 0.0422218 s.
info: [time] Solving process #0 took 0.303355 s in time step #16
info: [time] Time step #16 took 0.303479 s.
info: === Time stepping at step #17 and time 2650112.1010101 with step size 1000000
info: [time] Assembly took 0.0240154 s.
info: [time] Applying Dirichlet BCs took 0.000594654 s.
info: residual: 3.297712e-23
info: [time] Linear solver took 0.0740627 s.
info: Convergence criterion: |dx|=4.9137e-03, |x|=1.0107e+09, |dx|/|x|=4.8618e-12
info: [time] Iteration #1 took 0.099074 s.
info: [time] Assembly took 0.0191855 s.
info: [time] Applying Dirichlet BCs took 0.000468138 s.
info: residual: 3.427798e-21
info: [time] Linear solver took 0.0496421 s.
info: Convergence criterion: |dx|=1.2910e+01, |x|=1.0107e+09, |dx|/|x|=1.2773e-08
info: [time] Iteration #2 took 0.069741 s.
info: [time] Assembly took 0.0147353 s.
info: [time] Applying Dirichlet BCs took 0.000517042 s.
info: residual: 3.834469e-24
info: [time] Linear solver took 0.0662517 s.
info: Convergence criterion: |dx|=4.9039e-02, |x|=1.0107e+09, |dx|/|x|=4.8521e-11
info: [time] Iteration #3 took 0.0820015 s.
info: [time] Assembly took 0.0236096 s.
info: [time] Applying Dirichlet BCs took 0.000507289 s.
info: residual: 6.318654e-13
info: [time] Linear solver took 0.0152811 s.
info: [time] Iteration #4 took 0.0398616 s.
info: [time] Solving process #0 took 0.291007 s in time step #17
info: [time] Time step #17 took 0.291142 s.
info: === Time stepping at step #18 and time 4650112.1010101 with step size 2000000
info: [time] Assembly took 0.0092182 s.
info: [time] Applying Dirichlet BCs took 0.000523341 s.
info: residual: 3.443835e-23
info: [time] Linear solver took 0.0199865 s.
info: Convergence criterion: |dx|=7.9073e-03, |x|=1.0107e+09, |dx|/|x|=7.8238e-12
info: [time] Iteration #1 took 0.03011 s.
info: [time] Assembly took 0.012428 s.
info: [time] Applying Dirichlet BCs took 0.000466344 s.
info: residual: 1.368109e-20
info: [time] Linear solver took 0.0165668 s.
info: Convergence criterion: |dx|=2.5822e+01, |x|=1.0107e+09, |dx|/|x|=2.5550e-08
info: [time] Iteration #2 took 0.0299184 s.
info: [time] Assembly took 0.0157581 s.
info: [time] Applying Dirichlet BCs took 0.000488571 s.
info: residual: 3.054953e-23
info: [time] Linear solver took 0.0565781 s.
info: Convergence criterion: |dx|=7.5514e-02, |x|=1.0107e+09, |dx|/|x|=7.4717e-11
info: [time] Iteration #3 took 0.0732414 s.
info: [time] Assembly took 0.0214326 s.
info: [time] Applying Dirichlet BCs took 0.000496026 s.
info: residual: 1.158761e-23
info: [time] Linear solver took 0.0775445 s.
info: Convergence criterion: |dx|=2.8985e-02, |x|=1.0107e+09, |dx|/|x|=2.8679e-11
info: [time] Iteration #4 took 0.0999409 s.
info: [time] Assembly took 0.0224163 s.
info: [time] Applying Dirichlet BCs took 0.000514027 s.
info: residual: 6.151126e-26
info: [time] Linear solver took 0.0456955 s.
info: Convergence criterion: |dx|=6.2202e-05, |x|=1.0107e+09, |dx|/|x|=6.1546e-14
info: [time] Iteration #5 took 0.0691302 s.
info: [time] Solving process #0 took 0.302749 s in time step #18
info: [time] Time step #18 took 0.302912 s.
info: === Time stepping at step #19 and time 8650112.1010101 with step size 4000000
info: [time] Assembly took 0.0230017 s.
info: [time] Applying Dirichlet BCs took 0.000562641 s.
info: residual: 6.962318e-23
info: [time] Linear solver took 0.0804542 s.
info: Convergence criterion: |dx|=6.2865e-03, |x|=1.0107e+09, |dx|/|x|=6.2202e-12
info: [time] Iteration #1 took 0.104296 s.
info: [time] Assembly took 0.0308402 s.
info: [time] Applying Dirichlet BCs took 0.000467691 s.
info: residual: 5.438178e-20
info: [time] Linear solver took 0.057247 s.
info: Convergence criterion: |dx|=5.1639e+01, |x|=1.0107e+09, |dx|/|x|=5.1095e-08
info: [time] Iteration #2 took 0.0887297 s.
info: [time] Assembly took 0.0127346 s.
info: [time] Applying Dirichlet BCs took 0.000545304 s.
info: residual: 2.430409e-22
info: [time] Linear solver took 0.0481795 s.
info: Convergence criterion: |dx|=1.1037e-01, |x|=1.0107e+09, |dx|/|x|=1.0920e-10
info: [time] Iteration #3 took 0.0617213 s.
info: [time] Assembly took 0.0214436 s.
info: [time] Applying Dirichlet BCs took 0.000654207 s.
info: residual: 9.159843e-23
info: [time] Linear solver took 0.0609787 s.
info: Convergence criterion: |dx|=1.1535e-01, |x|=1.0107e+09, |dx|/|x|=1.1413e-10
info: [time] Iteration #4 took 0.0836296 s.
info: [time] Assembly took 0.0365908 s.
info: [time] Applying Dirichlet BCs took 0.000512783 s.
info: residual: 8.727488e-25
info: [time] Linear solver took 0.0702422 s.
info: Convergence criterion: |dx|=6.4755e-04, |x|=1.0107e+09, |dx|/|x|=6.4072e-13
info: [time] Iteration #5 took 0.107665 s.
info: [time] Solving process #0 took 0.446277 s in time step #19
info: [time] Time step #19 took 0.446366 s.
info: === Time stepping at step #20 and time 16650112.1010101 with step size 8000000
info: [time] Assembly took 0.013829 s.
info: [time] Applying Dirichlet BCs took 0.000528671 s.
info: residual: 3.606570e-24
info: [time] Linear solver took 0.0692799 s.
info: Convergence criterion: |dx|=1.2556e-02, |x|=1.0107e+09, |dx|/|x|=1.2423e-11
info: [time] Iteration #1 took 0.0838507 s.
info: [time] Assembly took 0.0216656 s.
info: [time] Applying Dirichlet BCs took 0.000565566 s.
info: residual: 2.098259e-19
info: [time] Linear solver took 0.0436111 s.
info: Convergence criterion: |dx|=1.0317e+02, |x|=1.0107e+09, |dx|/|x|=1.0209e-07
info: [time] Iteration #2 took 0.0663122 s.
info: [time] Assembly took 0.021517 s.
info: [time] Applying Dirichlet BCs took 0.00050098 s.
info: residual: 1.920213e-21
info: [time] Linear solver took 0.0542954 s.
info: Convergence criterion: |dx|=5.5997e-01, |x|=1.0107e+09, |dx|/|x|=5.5407e-10
info: [time] Iteration #3 took 0.0766593 s.
info: [time] Assembly took 0.0160444 s.
info: [time] Applying Dirichlet BCs took 0.000493856 s.
info: residual: 7.128691e-22
info: [time] Linear solver took 0.0498257 s.
info: Convergence criterion: |dx|=4.5608e-01, |x|=1.0107e+09, |dx|/|x|=4.5126e-10
info: [time] Iteration #4 took 0.0664466 s.
info: [time] Assembly took 0.0232136 s.
info: [time] Applying Dirichlet BCs took 0.000524407 s.
info: residual: 1.330595e-23
info: [time] Linear solver took 0.0595085 s.
info: Convergence criterion: |dx|=6.5255e-03, |x|=1.0107e+09, |dx|/|x|=6.4567e-12
info: [time] Iteration #5 took 0.0833332 s.
info: [time] Assembly took 0.0172717 s.
info: [time] Applying Dirichlet BCs took 0.000504955 s.
info: residual: 6.126753e-24
info: [time] Linear solver took 0.0755228 s.
info: Convergence criterion: |dx|=1.8966e-03, |x|=1.0107e+09, |dx|/|x|=1.8766e-12
info: [time] Iteration #6 took 0.093641 s.
info: [time] Assembly took 0.0328819 s.
info: [time] Applying Dirichlet BCs took 0.000498042 s.
info: residual: 4.035475e-13
info: [time] Linear solver took 0.0295249 s.
info: [time] Iteration #7 took 0.0630056 s.
info: [time] Solving process #0 took 0.533439 s in time step #20
info: [time] Time step #20 took 0.533457 s.
info: === Time stepping at step #21 and time 26650112.1010101 with step size 10000000
info: [time] Assembly took 0.0231703 s.
info: [time] Applying Dirichlet BCs took 0.000551359 s.
info: residual: 5.775742e-24
info: [time] Linear solver took 0.0528029 s.
info: Convergence criterion: |dx|=1.5687e-02, |x|=1.0107e+09, |dx|/|x|=1.5522e-11
info: [time] Iteration #1 took 0.0766222 s.
info: [time] Assembly took 0.019873 s.
info: [time] Applying Dirichlet BCs took 0.000460744 s.
info: residual: 3.245132e-19
info: [time] Linear solver took 0.0796815 s.
info: Convergence criterion: |dx|=1.2901e+02, |x|=1.0107e+09, |dx|/|x|=1.2764e-07
info: [time] Iteration #2 took 0.10043 s.
info: [time] Assembly took 0.0218404 s.
info: [time] Applying Dirichlet BCs took 0.000522138 s.
info: residual: 3.733737e-21
info: [time] Linear solver took 0.0613702 s.
info: Convergence criterion: |dx|=9.8192e-01, |x|=1.0107e+09, |dx|/|x|=9.7155e-10
info: [time] Iteration #3 took 0.0840929 s.
info: [time] Assembly took 0.0242156 s.
info: [time] Applying Dirichlet BCs took 0.000510704 s.
info: residual: 1.374642e-21
info: [time] Linear solver took 0.0671988 s.
info: Convergence criterion: |dx|=7.0903e-01, |x|=1.0107e+09, |dx|/|x|=7.0155e-10
info: [time] Iteration #4 took 0.0924146 s.
info: [time] Assembly took 0.0214263 s.
info: [time] Applying Dirichlet BCs took 0.000503901 s.
info: residual: 3.201189e-23
info: [time] Linear solver took 0.0484241 s.
info: Convergence criterion: |dx|=1.3398e-02, |x|=1.0107e+09, |dx|/|x|=1.3257e-11
info: [time] Iteration #5 took 0.0708119 s.
info: [time] Assembly took 0.0491615 s.
info: [time] Applying Dirichlet BCs took 0.000673643 s.
info: residual: 1.455928e-23
info: [time] Linear solver took 0.108954 s.
info: Convergence criterion: |dx|=3.6855e-03, |x|=1.0107e+09, |dx|/|x|=3.6466e-12
info: [time] Iteration #6 took 0.159245 s.
info: [time] Assembly took 0.0129523 s.
info: [time] Applying Dirichlet BCs took 0.00048545 s.
info: residual: 9.488953e-13
info: [time] Linear solver took 0.0146722 s.
info: [time] Iteration #7 took 0.0281966 s.
info: [time] Solving process #0 took 0.612083 s in time step #21
info: [time] Time step #21 took 0.6121 s.
info: === Time stepping at step #22 and time 46650112.1010101 with step size 20000000
info: [time] Assembly took 0.0191219 s.
info: [time] Applying Dirichlet BCs took 0.000598393 s.
info: residual: 1.423177e-19
info: [time] Linear solver took 0.0482615 s.
info: Convergence criterion: |dx|=3.1251e-02, |x|=1.0107e+09, |dx|/|x|=3.0921e-11
info: [time] Iteration #1 took 0.0682326 s.
info: [time] Assembly took 0.0260671 s.
info: [time] Applying Dirichlet BCs took 0.00048177 s.
info: residual: 1.289525e-18
info: [time] Linear solver took 0.0166761 s.
info: Convergence criterion: |dx|=2.5723e+02, |x|=1.0107e+09, |dx|/|x|=2.5452e-07
info: [time] Iteration #2 took 0.0437004 s.
info: [time] Assembly took 0.00965485 s.
info: [time] Applying Dirichlet BCs took 0.000487506 s.
info: residual: 2.859707e-20
info: [time] Linear solver took 0.0149462 s.
info: Convergence criterion: |dx|=4.7252e+00, |x|=1.0107e+09, |dx|/|x|=4.6753e-09
info: [time] Iteration #3 took 0.0254978 s.
info: [time] Assembly took 0.009837 s.
info: [time] Applying Dirichlet BCs took 0.000494783 s.
info: residual: 1.024623e-20
info: [time] Linear solver took 0.0797483 s.
info: Convergence criterion: |dx|=2.7489e+00, |x|=1.0107e+09, |dx|/|x|=2.7198e-09
info: [time] Iteration #4 took 0.0905229 s.
info: [time] Assembly took 0.0260935 s.
info: [time] Applying Dirichlet BCs took 0.000509841 s.
info: residual: 4.778641e-22
info: [time] Linear solver took 0.0736834 s.
info: Convergence criterion: |dx|=1.1488e-01, |x|=1.0107e+09, |dx|/|x|=1.1367e-10
info: [time] Iteration #5 took 0.100747 s.
info: [time] Assembly took 0.0252624 s.
info: [time] Applying Dirichlet BCs took 0.000497624 s.
info: residual: 2.094654e-22
info: [time] Linear solver took 0.0795271 s.
info: Convergence criterion: |dx|=2.6975e-02, |x|=1.0107e+09, |dx|/|x|=2.6690e-11
info: [time] Iteration #6 took 0.105751 s.
info: [time] Assembly took 0.0260997 s.
info: [time] Applying Dirichlet BCs took 0.000510138 s.
info: residual: 1.608621e-23
info: [time] Linear solver took 0.0740004 s.
info: Convergence criterion: |dx|=1.9786e-03, |x|=1.0107e+09, |dx|/|x|=1.9578e-12
info: [time] Iteration #7 took 0.101076 s.
info: [time] Assembly took 0.0216142 s.
info: [time] Applying Dirichlet BCs took 0.000507624 s.
info: residual: 5.933828e-24
info: [time] Linear solver took 0.0794924 s.
info: Convergence criterion: |dx|=2.5618e-04, |x|=1.0107e+09, |dx|/|x|=2.5347e-13
info: [time] Iteration #8 took 0.102069 s.
info: [time] Solving process #0 took 0.638249 s in time step #22
info: [time] Time step #22 took 0.638343 s.
info: === Time stepping at step #23 and time 86650112.1010101 with step size 40000000
info: [time] Assembly took 0.0225036 s.
info: [time] Applying Dirichlet BCs took 0.000578201 s.
info: residual: 1.187212e-15
info: [time] Linear solver took 0.0543914 s.
info: Convergence criterion: |dx|=6.2013e-02, |x|=1.0107e+09, |dx|/|x|=6.1358e-11
info: [time] Iteration #1 took 0.0779522 s.
info: [time] Assembly took 0.031318 s.
info: [time] Applying Dirichlet BCs took 0.000500233 s.
info: residual: 5.360515e-17
info: [time] Linear solver took 0.0505156 s.
info: Convergence criterion: |dx|=5.1073e+02, |x|=1.0107e+09, |dx|/|x|=5.0534e-07
info: [time] Iteration #2 took 0.0828466 s.
info: [time] Assembly took 0.0118941 s.
info: [time] Applying Dirichlet BCs took 0.000504473 s.
info: residual: 2.365615e-17
info: [time] Linear solver took 0.0693802 s.
info: Convergence criterion: |dx|=2.0657e+01, |x|=1.0107e+09, |dx|/|x|=2.0439e-08
info: [time] Iteration #3 took 0.0826429 s.
info: [time] Assembly took 0.0308051 s.
info: [time] Applying Dirichlet BCs took 0.000523822 s.
info: residual: 2.249125e-18
info: [time] Linear solver took 0.0173893 s.
info: Convergence criterion: |dx|=1.0309e+01, |x|=1.0107e+09, |dx|/|x|=1.0200e-08
info: [time] Iteration #4 took 0.0491226 s.
info: [time] Assembly took 0.0131434 s.
info: [time] Applying Dirichlet BCs took 0.000505885 s.
info: residual: 4.213716e-19
info: [time] Linear solver took 0.0192532 s.
info: Convergence criterion: |dx|=9.1809e-01, |x|=1.0107e+09, |dx|/|x|=9.0840e-10
info: [time] Iteration #5 took 0.0331606 s.
info: [time] Assembly took 0.0151095 s.
info: [time] Applying Dirichlet BCs took 0.00051152 s.
info: residual: 6.926832e-20
info: [time] Linear solver took 0.082378 s.
info: Convergence criterion: |dx|=1.7880e-01, |x|=1.0107e+09, |dx|/|x|=1.7691e-10
info: [time] Iteration #6 took 0.0982584 s.
info: [time] Assembly took 0.0268157 s.
info: [time] Applying Dirichlet BCs took 0.000680818 s.
info: residual: 7.206968e-21
info: [time] Linear solver took 0.0157026 s.
info: Convergence criterion: |dx|=2.8398e-02, |x|=1.0107e+09, |dx|/|x|=2.8098e-11
info: [time] Iteration #7 took 0.0434817 s.
info: [time] Assembly took 0.01331 s.
info: [time] Applying Dirichlet BCs took 0.000534274 s.
info: residual: 1.973337e-21
info: [time] Linear solver took 0.0199458 s.
info: Convergence criterion: |dx|=2.3589e-03, |x|=1.0107e+09, |dx|/|x|=2.3340e-12
info: [time] Iteration #8 took 0.0340326 s.
info: [time] Assembly took 0.0125402 s.
info: [time] Applying Dirichlet BCs took 0.000508992 s.
info: residual: 1.740807e-22
info: [time] Linear solver took 0.0148467 s.
info: Convergence criterion: |dx|=7.4357e-04, |x|=1.0107e+09, |dx|/|x|=7.3572e-13
info: [time] Iteration #9 took 0.0281507 s.
info: [time] Solving process #0 took 0.531541 s in time step #23
info: [time] Time step #23 took 0.531668 s.
info: === Time stepping at step #24 and time 286650112.10101 with step size 200000000
info: [time] Assembly took 0.0152213 s.
info: [time] Applying Dirichlet BCs took 0.000556115 s.
info: iteration: 2/10000
info: residual: 6.824456e-19
info: [time] Linear solver took 0.0630246 s.
info: Convergence criterion: |dx|=2.8915e-01, |x|=1.0107e+09, |dx|/|x|=2.8610e-10
info: [time] Iteration #1 took 0.079121 s.
info: [time] Assembly took 0.0116689 s.
info: [time] Applying Dirichlet BCs took 0.0004632 s.
info: residual: 1.443255e-19
info: [time] Linear solver took 0.0230499 s.
info: Convergence criterion: |dx|=2.3717e+03, |x|=1.0107e+09, |dx|/|x|=2.3467e-06
info: [time] Iteration #2 took 0.0356718 s.
info: [time] Assembly took 0.00956139 s.
info: [time] Applying Dirichlet BCs took 0.00049555 s.
info: residual: 5.163510e-20
info: [time] Linear solver took 0.0157453 s.
info: Convergence criterion: |dx|=4.9492e+02, |x|=1.0107e+09, |dx|/|x|=4.8970e-07
info: [time] Iteration #3 took 0.0262035 s.
info: [time] Assembly took 0.0102175 s.
info: [time] Applying Dirichlet BCs took 0.00047951 s.
info: residual: 2.755883e-20
info: [time] Linear solver took 0.0155018 s.
info: Convergence criterion: |dx|=1.3974e+02, |x|=1.0107e+09, |dx|/|x|=1.3826e-07
info: [time] Iteration #4 took 0.0266431 s.
info: [time] Assembly took 0.00923808 s.
info: [time] Applying Dirichlet BCs took 0.000477191 s.
info: residual: 2.608289e-14
info: [time] Linear solver took 0.0147356 s.
info: Convergence criterion: |dx|=7.9993e+01, |x|=1.0107e+09, |dx|/|x|=7.9149e-08
info: [time] Iteration #5 took 0.024826 s.
info: [time] Assembly took 0.00914835 s.
info: [time] Applying Dirichlet BCs took 0.00045824 s.
info: residual: 1.443997e-13
info: [time] Linear solver took 0.0150136 s.
info: Convergence criterion: |dx|=3.2061e+00, |x|=1.0107e+09, |dx|/|x|=3.1723e-09
info: [time] Iteration #6 took 0.0249874 s.
info: [time] Assembly took 0.00916714 s.
info: [time] Applying Dirichlet BCs took 0.000468808 s.
info: residual: 2.748343e-14
info: [time] Linear solver took 0.0154507 s.
info: Convergence criterion: |dx|=7.4717e+00, |x|=1.0107e+09, |dx|/|x|=7.3929e-09
info: [time] Iteration #7 took 0.0254954 s.
info: [time] Assembly took 0.00932726 s.
info: [time] Applying Dirichlet BCs took 0.000460763 s.
info: residual: 1.304483e-14
info: [time] Linear solver took 0.0146949 s.
info: Convergence criterion: |dx|=1.9871e+00, |x|=1.0107e+09, |dx|/|x|=1.9661e-09
info: [time] Iteration #8 took 0.0248684 s.
info: [time] Assembly took 0.00951792 s.
info: [time] Applying Dirichlet BCs took 0.000460178 s.
info: residual: 5.486274e-15
info: [time] Linear solver took 0.0148138 s.
info: Convergence criterion: |dx|=3.7195e-01, |x|=1.0107e+09, |dx|/|x|=3.6802e-10
info: [time] Iteration #9 took 0.0251779 s.
info: [time] Assembly took 0.00945644 s.
info: [time] Applying Dirichlet BCs took 0.000477627 s.
info: residual: 1.051872e-15
info: [time] Linear solver took 0.0902688 s.
info: Convergence criterion: |dx|=2.7512e-01, |x|=1.0107e+09, |dx|/|x|=2.7221e-10
info: [time] Iteration #10 took 0.100964 s.
info: [time] Assembly took 0.02611 s.
info: [time] Applying Dirichlet BCs took 0.000502195 s.
info: residual: 8.877052e-16
info: [time] Linear solver took 0.0874353 s.
info: Convergence criterion: |dx|=7.1181e-02, |x|=1.0107e+09, |dx|/|x|=7.0430e-11
info: [time] Iteration #11 took 0.114503 s.
info: [time] Assembly took 0.0256881 s.
info: [time] Applying Dirichlet BCs took 0.0026324 s.
info: residual: 8.431247e-17
info: [time] Linear solver took 0.0375832 s.
info: Convergence criterion: |dx|=2.4581e-02, |x|=1.0107e+09, |dx|/|x|=2.4322e-11
info: [time] Iteration #12 took 0.0682709 s.
info: [time] Assembly took 0.021916 s.
info: [time] Applying Dirichlet BCs took 0.000522704 s.
info: residual: 1.468931e-16
info: [time] Linear solver took 0.0439646 s.
info: Convergence criterion: |dx|=1.4021e-02, |x|=1.0107e+09, |dx|/|x|=1.3873e-11
info: [time] Iteration #13 took 0.0666628 s.
info: [time] Assembly took 0.0158667 s.
info: [time] Applying Dirichlet BCs took 0.000520335 s.
info: residual: 1.803067e-17
info: [time] Linear solver took 0.0736381 s.
info: Convergence criterion: |dx|=5.6375e-03, |x|=1.0107e+09, |dx|/|x|=5.5780e-12
info: [time] Iteration #14 took 0.090402 s.
info: [time] Assembly took 0.0260508 s.
info: [time] Applying Dirichlet BCs took 0.000539873 s.
info: residual: 2.389473e-17
info: [time] Linear solver took 0.0894807 s.
info: Convergence criterion: |dx|=1.4113e-03, |x|=1.0107e+09, |dx|/|x|=1.3964e-12
info: [time] Iteration #15 took 0.116578 s.
info: [time] Assembly took 0.0260491 s.
info: [time] Applying Dirichlet BCs took 0.000737207 s.
info: residual: 6.487528e-18
info: [time] Linear solver took 0.0830073 s.
info: Convergence criterion: |dx|=1.3933e-03, |x|=1.0107e+09, |dx|/|x|=1.3786e-12
info: [time] Iteration #16 took 0.110276 s.
info: [time] Assembly took 0.0287378 s.
info: [time] Applying Dirichlet BCs took 0.000541664 s.
info: residual: 3.362514e-18
info: [time] Linear solver took 0.0660133 s.
info: Convergence criterion: |dx|=1.8927e-04, |x|=1.0107e+09, |dx|/|x|=1.8727e-13
info: [time] Iteration #17 took 0.0958317 s.
info: [time] Solving process #0 took 1.05774 s in time step #24
info: [time] Time step #24 took 1.05788 s.
info: === Time stepping at step #25 and time 686650112.10101 with step size 400000000
info: [time] Assembly took 0.0213952 s.
info: [time] Applying Dirichlet BCs took 0.000602471 s.
info: residual: 6.602848e-17
info: [time] Linear solver took 0.134175 s.
info: Convergence criterion: |dx|=5.4117e-01, |x|=1.0107e+09, |dx|/|x|=5.3546e-10
info: [time] Iteration #1 took 0.156677 s.
info: [time] Assembly took 0.0260976 s.
info: [time] Applying Dirichlet BCs took 0.000521255 s.
info: residual: 2.509758e-17
info: [time] Linear solver took 0.146039 s.
info: Convergence criterion: |dx|=4.4458e+03, |x|=1.0107e+09, |dx|/|x|=4.3988e-06
info: [time] Iteration #2 took 0.173033 s.
info: [time] Assembly took 0.0230301 s.
info: [time] Applying Dirichlet BCs took 0.000608493 s.
info: residual: 8.945349e-18
info: [time] Linear solver took 0.119366 s.
info: Convergence criterion: |dx|=1.7063e+03, |x|=1.0107e+09, |dx|/|x|=1.6883e-06
info: [time] Iteration #3 took 0.14352 s.
info: [time] Assembly took 0.0212955 s.
info: [time] Applying Dirichlet BCs took 0.000548331 s.
info: residual: 9.259264e-18
info: [time] Linear solver took 0.140963 s.
info: Convergence criterion: |dx|=1.8567e+02, |x|=1.0107e+09, |dx|/|x|=1.8371e-07
info: [time] Iteration #4 took 0.163283 s.
info: [time] Assembly took 0.0293954 s.
info: [time] Applying Dirichlet BCs took 0.000532464 s.
info: residual: 1.231128e-18
info: [time] Linear solver took 0.16593 s.
info: Convergence criterion: |dx|=3.9368e+02, |x|=1.0107e+09, |dx|/|x|=3.8952e-07
info: [time] Iteration #5 took 0.19621 s.
info: [time] Assembly took 0.036529 s.
info: [time] Applying Dirichlet BCs took 0.000834823 s.
info: residual: 2.588087e-18
info: [time] Linear solver took 0.148551 s.
info: Convergence criterion: |dx|=1.1913e+02, |x|=1.0107e+09, |dx|/|x|=1.1788e-07
info: [time] Iteration #6 took 0.186428 s.
info: [time] Assembly took 0.0348589 s.
info: [time] Applying Dirichlet BCs took 0.000721297 s.
info: residual: 1.025933e-18
info: [time] Linear solver took 0.256703 s.
info: Convergence criterion: |dx|=2.7841e+01, |x|=1.0107e+09, |dx|/|x|=2.7547e-08
info: [time] Iteration #7 took 0.292765 s.
info: [time] Assembly took 0.0606095 s.
info: [time] Applying Dirichlet BCs took 0.000785365 s.
info: residual: 5.871695e-13
info: [time] Linear solver took 0.0856556 s.
info: Convergence criterion: |dx|=3.3401e+01, |x|=1.0107e+09, |dx|/|x|=3.3049e-08
info: [time] Iteration #8 took 0.14758 s.
info: [time] Assembly took 0.0296742 s.
info: [time] Applying Dirichlet BCs took 0.000617271 s.
info: residual: 5.659495e-13
info: [time] Linear solver took 0.112725 s.
info: Convergence criterion: |dx|=9.2048e+00, |x|=1.0107e+09, |dx|/|x|=9.1076e-09
info: [time] Iteration #9 took 0.14342 s.
info: [time] Assembly took 0.0260912 s.
info: [time] Applying Dirichlet BCs took 0.000649795 s.
info: residual: 2.824617e-13
info: [time] Linear solver took 0.119457 s.
info: Convergence criterion: |dx|=3.1718e+00, |x|=1.0107e+09, |dx|/|x|=3.1384e-09
info: [time] Iteration #10 took 0.146743 s.
info: [time] Assembly took 0.0259774 s.
info: [time] Applying Dirichlet BCs took 0.000792899 s.
info: residual: 6.533980e-14
info: [time] Linear solver took 0.0920518 s.
info: Convergence criterion: |dx|=3.1146e+00, |x|=1.0107e+09, |dx|/|x|=3.0817e-09
info: [time] Iteration #11 took 0.119253 s.
info: [time] Assembly took 0.0397097 s.
info: [time] Applying Dirichlet BCs took 0.000782478 s.
info: residual: 5.983954e-14
info: [time] Linear solver took 0.0914594 s.
info: Convergence criterion: |dx|=1.0785e+00, |x|=1.0107e+09, |dx|/|x|=1.0671e-09
info: [time] Iteration #12 took 0.132194 s.
info: [time] Assembly took 0.0176394 s.
info: [time] Applying Dirichlet BCs took 0.000692136 s.
info: residual: 1.893559e-14
info: [time] Linear solver took 0.0931344 s.
info: Convergence criterion: |dx|=3.4848e-01, |x|=1.0107e+09, |dx|/|x|=3.4480e-10
info: [time] Iteration #13 took 0.111913 s.
info: [time] Assembly took 0.0124299 s.
info: [time] Applying Dirichlet BCs took 0.000548075 s.
info: residual: 1.383884e-14
info: [time] Linear solver took 0.0792257 s.
info: Convergence criterion: |dx|=4.0521e-01, |x|=1.0107e+09, |dx|/|x|=4.0093e-10
info: [time] Iteration #14 took 0.0925643 s.
info: [time] Assembly took 0.0265337 s.
info: [time] Applying Dirichlet BCs took 0.000574429 s.
info: residual: 3.277019e-15
info: [time] Linear solver took 0.0926764 s.
info: Convergence criterion: |dx|=1.5042e-01, |x|=1.0107e+09, |dx|/|x|=1.4883e-10
info: [time] Iteration #15 took 0.119995 s.
info: [time] Assembly took 0.0313687 s.
info: [time] Applying Dirichlet BCs took 0.000571036 s.
info: residual: 4.401847e-15
info: [time] Linear solver took 0.0813106 s.
info: Convergence criterion: |dx|=6.0151e-02, |x|=1.0107e+09, |dx|/|x|=5.9516e-11
info: [time] Iteration #16 took 0.113364 s.
info: [time] Assembly took 0.0313232 s.
info: [time] Applying Dirichlet BCs took 0.000567394 s.
info: residual: 1.288306e-15
info: [time] Linear solver took 0.0346259 s.
info: Convergence criterion: |dx|=7.0091e-02, |x|=1.0107e+09, |dx|/|x|=6.9351e-11
info: [time] Iteration #17 took 0.0666246 s.
info: [time] Assembly took 0.033199 s.
info: [time] Applying Dirichlet BCs took 0.000543157 s.
info: residual: 1.102864e-15
info: [time] Linear solver took 0.0794821 s.
info: Convergence criterion: |dx|=1.2141e-02, |x|=1.0107e+09, |dx|/|x|=1.2013e-11
info: [time] Iteration #18 took 0.113317 s.
info: [time] Assembly took 0.0265633 s.
info: [time] Applying Dirichlet BCs took 0.000759692 s.
info: residual: 7.649486e-16
info: [time] Linear solver took 0.069375 s.
info: Convergence criterion: |dx|=1.7955e-02, |x|=1.0107e+09, |dx|/|x|=1.7765e-11
info: [time] Iteration #19 took 0.0969179 s.
info: [time] Assembly took 0.0296034 s.
info: [time] Applying Dirichlet BCs took 0.000690194 s.
info: residual: 1.458935e-16
info: [time] Linear solver took 0.085824 s.
info: Convergence criterion: |dx|=1.0476e-02, |x|=1.0107e+09, |dx|/|x|=1.0366e-11
info: [time] Iteration #20 took 0.116361 s.
info: [time] Assembly took 0.0265479 s.
info: [time] Applying Dirichlet BCs took 0.00054153 s.
info: residual: 2.981607e-16
info: [time] Linear solver took 0.0610518 s.
info: Convergence criterion: |dx|=2.0099e-03, |x|=1.0107e+09, |dx|/|x|=1.9887e-12
info: [time] Iteration #21 took 0.0886477 s.
info: [time] Assembly took 0.0277564 s.
info: [time] Applying Dirichlet BCs took 0.00055063 s.
info: residual: 6.262715e-17
info: [time] Linear solver took 0.0837933 s.
info: Convergence criterion: |dx|=4.1502e-03, |x|=1.0107e+09, |dx|/|x|=4.1064e-12
info: [time] Iteration #22 took 0.11242 s.
info: [time] Assembly took 0.0287242 s.
info: [time] Applying Dirichlet BCs took 0.000725651 s.
info: residual: 8.355963e-17
info: [time] Linear solver took 0.0860141 s.
info: Convergence criterion: |dx|=8.1862e-04, |x|=1.0107e+09, |dx|/|x|=8.0998e-13
info: [time] Iteration #23 took 0.115761 s.
info: [time] Solving process #0 took 3.14997 s in time step #25
info: [time] Time step #25 took 3.15011 s.
info: === Time stepping at step #26 and time 1000000000 with step size 313349887.89899
info: [time] Assembly took 0.0184143 s.
info: [time] Applying Dirichlet BCs took 0.000688037 s.
info: residual: 4.330297e-18
info: [time] Linear solver took 0.109821 s.
info: Convergence criterion: |dx|=4.5613e-01, |x|=1.0107e+09, |dx|/|x|=4.5131e-10
info: [time] Iteration #1 took 0.129151 s.
info: [time] Assembly took 0.0219858 s.
info: [time] Applying Dirichlet BCs took 0.000675136 s.
info: residual: 1.382792e-18
info: [time] Linear solver took 0.144941 s.
info: Convergence criterion: |dx|=3.7546e+03, |x|=1.0107e+09, |dx|/|x|=3.7149e-06
info: [time] Iteration #2 took 0.167965 s.
info: [time] Assembly took 0.0248749 s.
info: [time] Applying Dirichlet BCs took 0.000668005 s.
info: residual: 4.488838e-19
info: [time] Linear solver took 0.116155 s.
info: Convergence criterion: |dx|=1.1696e+03, |x|=1.0107e+09, |dx|/|x|=1.1573e-06
info: [time] Iteration #3 took 0.142168 s.
info: [time] Assembly took 0.0143621 s.
info: [time] Applying Dirichlet BCs took 0.000530206 s.
info: residual: 2.930213e-19
info: [time] Linear solver took 0.0923733 s.
info: Convergence criterion: |dx|=2.1311e+02, |x|=1.0107e+09, |dx|/|x|=2.1086e-07
info: [time] Iteration #4 took 0.107523 s.
info: [time] Assembly took 0.0221933 s.
info: [time] Applying Dirichlet BCs took 0.000557791 s.
info: residual: 1.001013e-19
info: [time] Linear solver took 0.116409 s.
info: Convergence criterion: |dx|=2.4623e+02, |x|=1.0107e+09, |dx|/|x|=2.4363e-07
info: [time] Iteration #5 took 0.139501 s.
info: [time] Assembly took 0.0294428 s.
info: [time] Applying Dirichlet BCs took 0.00054565 s.
info: residual: 1.670619e-19
info: [time] Linear solver took 0.0782704 s.
info: Convergence criterion: |dx|=4.5231e+01, |x|=1.0107e+09, |dx|/|x|=4.4753e-08
info: [time] Iteration #6 took 0.108731 s.
info: [time] Assembly took 0.0179394 s.
info: [time] Applying Dirichlet BCs took 0.000638441 s.
info: residual: 6.491493e-13
info: [time] Linear solver took 0.0781903 s.
info: Convergence criterion: |dx|=2.3167e+01, |x|=1.0107e+09, |dx|/|x|=2.2923e-08
info: [time] Iteration #7 took 0.097271 s.
info: [time] Assembly took 0.0266125 s.
info: [time] Applying Dirichlet BCs took 0.000595537 s.
info: residual: 5.118682e-14
info: [time] Linear solver took 0.0722823 s.
info: Convergence criterion: |dx|=1.4464e+01, |x|=1.0107e+09, |dx|/|x|=1.4312e-08
info: [time] Iteration #8 took 0.100002 s.
info: [time] Assembly took 0.0281198 s.
info: [time] Applying Dirichlet BCs took 0.000576768 s.
info: residual: 1.111841e-13
info: [time] Linear solver took 0.0815598 s.
info: Convergence criterion: |dx|=1.5594e+00, |x|=1.0107e+09, |dx|/|x|=1.5429e-09
info: [time] Iteration #9 took 0.110759 s.
info: [time] Assembly took 0.0290083 s.
info: [time] Applying Dirichlet BCs took 0.000563028 s.
info: residual: 2.902723e-14
info: [time] Linear solver took 0.0937462 s.
info: Convergence criterion: |dx|=1.8422e+00, |x|=1.0107e+09, |dx|/|x|=1.8227e-09
info: [time] Iteration #10 took 0.123652 s.
info: [time] Assembly took 0.072002 s.
info: [time] Applying Dirichlet BCs took 0.00068574 s.
info: residual: 1.443258e-14
info: [time] Linear solver took 0.0711161 s.
info: Convergence criterion: |dx|=8.8181e-01, |x|=1.0107e+09, |dx|/|x|=8.7250e-10
info: [time] Iteration #11 took 0.144456 s.
info: [time] Assembly took 0.0160304 s.
info: [time] Applying Dirichlet BCs took 0.000535039 s.
info: residual: 7.211160e-15
info: [time] Linear solver took 0.0880022 s.
info: Convergence criterion: |dx|=1.6826e-01, |x|=1.0107e+09, |dx|/|x|=1.6648e-10
info: [time] Iteration #12 took 0.105057 s.
info: [time] Assembly took 0.0289927 s.
info: [time] Applying Dirichlet BCs took 0.000531895 s.
info: residual: 2.451042e-15
info: [time] Linear solver took 0.070377 s.
info: Convergence criterion: |dx|=1.4363e-01, |x|=1.0107e+09, |dx|/|x|=1.4211e-10
info: [time] Iteration #13 took 0.100246 s.
info: [time] Assembly took 0.0228496 s.
info: [time] Applying Dirichlet BCs took 0.000604558 s.
info: residual: 1.620107e-15
info: [time] Linear solver took 0.108655 s.
info: Convergence criterion: |dx|=8.1532e-02, |x|=1.0107e+09, |dx|/|x|=8.0671e-11
info: [time] Iteration #14 took 0.132223 s.
info: [time] Assembly took 0.0341636 s.
info: [time] Applying Dirichlet BCs took 0.000645968 s.
info: residual: 4.144247e-16
info: [time] Linear solver took 0.0877642 s.
info: Convergence criterion: |dx|=1.6885e-02, |x|=1.0107e+09, |dx|/|x|=1.6706e-11
info: [time] Iteration #15 took 0.123259 s.
info: [time] Assembly took 0.0253124 s.
info: [time] Applying Dirichlet BCs took 0.000696657 s.
info: residual: 4.495464e-16
info: [time] Linear solver took 0.0828215 s.
info: Convergence criterion: |dx|=1.8005e-02, |x|=1.0107e+09, |dx|/|x|=1.7815e-11
info: [time] Iteration #16 took 0.109409 s.
info: [time] Assembly took 0.0208026 s.
info: [time] Applying Dirichlet BCs took 0.000670635 s.
info: residual: 5.842686e-17
info: [time] Linear solver took 0.0988801 s.
info: Convergence criterion: |dx|=9.3855e-03, |x|=1.0107e+09, |dx|/|x|=9.2863e-12
info: [time] Iteration #17 took 0.121111 s.
info: [time] Assembly took 0.0225653 s.
info: [time] Applying Dirichlet BCs took 0.000602268 s.
info: residual: 1.155358e-16
info: [time] Linear solver took 0.076736 s.
info: Convergence criterion: |dx|=1.6468e-03, |x|=1.0107e+09, |dx|/|x|=1.6294e-12
info: [time] Iteration #18 took 0.100514 s.
info: [time] Assembly took 0.0485127 s.
info: [time] Applying Dirichlet BCs took 0.000613604 s.
info: residual: 3.750725e-17
info: [time] Linear solver took 0.0826408 s.
info: Convergence criterion: |dx|=2.9943e-03, |x|=1.0107e+09, |dx|/|x|=2.9627e-12
info: [time] Iteration #19 took 0.132273 s.
info: [time] Assembly took 0.0261987 s.
info: [time] Applying Dirichlet BCs took 0.000597255 s.
info: residual: 2.220180e-17
info: [time] Linear solver took 0.082608 s.
info: Convergence criterion: |dx|=5.8810e-04, |x|=1.0107e+09, |dx|/|x|=5.8188e-13
info: [time] Iteration #20 took 0.109638 s.
info: [time] Solving process #0 took 2.40616 s in time step #26
info: [time] Time step #26 took 2.40623 s.
info: The whole computation of the time stepping took 26 steps, in which
the accepted steps are 26, and the rejected steps are 0.
info: [time] Output of timestep 26 took 0.00678165 s.
info: [time] Execution took 11.9144 s.
info: OGS terminated on 2024-03-20 11:11:02+0100.
Index(['type', 'line', 'mpi_process', 'version', 'message', 'time_step',
'output_time', 'step_start_time', 'step_size', 'assembly_time',
'dirichlet_time', 'linear_solver_time', 'dx', 'x', 'dx_x',
'iteration_number', 'iteration_time', 'process',
'time_step_solution_time', 'time_step_finished_time', 'execution_time'],
dtype='object')
df_log
Custom analyses - example#
We create a pivot_table where for each time step we can see the step_size and the number of iterations.
df_custom
Total running time of the script: (0 minutes 0.177 seconds)
