How to Create Simple Mechanics Problem#
The following example consists of a simple mechanics problem. The source file can be found in the [OGS benchmark folder](https://gitlab.opengeosys.org/ogs/ogs/-/blob/master/Tests/Data/Mechanics/Linear/square_1e2.prj?ref_type=heads). The names of the method calls are based on the corresponding XML tags.
Initialize the ogs6py object:
output_dir = Path(mkdtemp())
Define geometry and/or meshes, we expect the gml to be in the same folder like the prj file:
prj.geometry.add_geometry(file_pathname=EXAMPLES_DIR / "prj" / "square_1x1.gml")
Set process and provide process related data:
prj.processes.set_process(
    name="SD",
    type="SMALL_DEFORMATION",
    integration_order="2",
    specific_body_force="0 0",
Define time stepping and output cycles:
prj.time_loop.add_process(
    process="SD",
    convergence_type="DeltaX",
    norm_type="NORM2",
    abstol="1e-15",
prj.time_loop.set_stepping(
    process="SD",
    type="FixedTimeStepping",
    t_initial="0",
    t_end="1",
    repeat="4",
    delta_t="0.25",
prj.time_loop.add_output(
    type="VTK",
    prefix="blubb",
    repeat="1",
    each_steps="10",
prj.media.add_property(
    medium_id="0",
    phase_type="Solid",
    name="density",
    type="Constant",
    value="1",
Define parameters needed for material properties and BC:
Set initial and boundary conditions:
prj.process_variables.set_ic(
    components="2",
    order="1",
prj.process_variables.add_bc(
    geometry="left",
    type="Dirichlet",
    component="0",
    parameter="dirichlet0",
    geometry="bottom",
    type="Dirichlet",
    component="1",
    geometry="top",
    type="Dirichlet",
    component="1",
    parameter="dirichlet1",
Set linear and nonlinear solver(s):
    type="Newton",
    max_iter="4",
    name="general_linear_solver",
    kind="lis",
    solver_type="cg",
    precon_type="jacobi",
    max_iteration_step="10000",
    error_tolerance="1e-16",
    kind="eigen",
    solver_type="CG",
    precon_type="DIAGONAL",
    kind="petsc",
    prefix="sd",
    solver_type="cg",
    precon_type="bjacobi",
m = ot.Model(project=prj, meshes=EXAMPLES_DIR / "prj")
fig = m.plot_constraints()
plot creation
m.run()
Simulation(model=Model.from_folder('/tmp/ogstools_root/Model/20260323_113729_825861'), result=Result('/tmp/ogstools_root/Result/20260323_113730_123028'))
log_file='/tmp/ogstools_root/Result/20260323_113730_123028/log.txt'
meshseries_file='/tmp/ogstools_root/Result/20260323_113730_123028/blubb.pvd'
status=Status: terminated with error
OGS execution was not successful.info: Parsing the OGS commandline passed
info: This is OpenGeoSys-6 version 6.5.7. Log version: 2, Log level: info.
info: OGS starts on 2026-03-23 11:37:30+0000 in serial mode / Python embedded mode.
warning: OMP_NUM_THREADS is not set, falling back to: 16
info: Eigen use 16 threads
info: Reading project file ../../../../../../../tmp/tmpa97at3yv/mechanics_new.prj.
error: File /tmp/tmpa97at3yv/mechanics_new.prj does not exist.
critical: /project/BaseLib/PrjProcessing.cpp:307 readAndPatchPrj()
error: Could not open project file '/tmp/tmpa97at3yv/mechanics_new.prj' for reading.
Could not construct OGSSimulation object
StorageBase(id='20260323_113730_213487', is_saved=False, _active_target=None, next_target=PosixPath('/tmp/ogstools_root/Simulation/20260323_113730_213487'))
Total running time of the script: (0 minutes 0.391 seconds)
