Saving and Loading Models - The Storage System#
OGSTools provides a unified storage system for managing simulation artifacts.
This guide uses Model for all examples, but the same principles and methods apply to all storage-capable objects. All inherit from StorageBase and share the same storage interface.
The examples start with basic operations and progress to advanced features.
from ogstools.gmsh_tools import rect
# Set up a temporary directory for our examples
work_dir = Path(mkdtemp())
ot.StorageBase.Userpath = work_dir
Basic Usage: Creating and Saving a Model#
Create and save a model in just a few lines.
# Create components
meshes = ot.Meshes.from_gmsh(rect(n_edge_cells=10))
prj_path = EXAMPLES_DIR / "prj" / "mechanics.prj"
project = ot.Project(input_file=prj_path)
# Create and save the model
my_model = ot.Model(project=project, meshes=meshes)
# Provide a path OR just .save()
my_model.save(work_dir / "my_model")
print(f"Model saved to: {my_model.active_target}")
Model saved to: /tmp/tmpr_ma5f_f/my_model
Loading a Model#
Load a previously saved model using its path.
loaded_model = ot.Model.from_folder(work_dir / "my_model")
print(loaded_model)
Model id: 20260323_113702_195936
   Model(saved to: file:///tmp/tmpr_ma5f_f/my_model)
  Project: saved to file:///tmp/tmpr_ma5f_f/my_model/project
  Meshes: saved to file:///tmp/tmpr_ma5f_f/my_model/meshes
  Execution: saved to file:///tmp/tmpr_ma5f_f/my_model/execution.yaml
Using IDs for Organization#
Alternatively, assign an ID to organize models in class-specific subdirectories. All objects with assigned id will be stored under ot.StorageBase.Userpath
model_experiment_1 = ot.Model(project=project, meshes=meshes, id="experiment_1")
model_experiment_1.save()
print(f"Model saved to: {model_experiment_1.active_target}")
# Load by ID
model_copy_experiment_1 = ot.Model.from_id("experiment_1")
print(f"Loaded by ID: {model_copy_experiment_1.active_target}")
Model saved to: /tmp/tmpr_ma5f_f/Model/experiment_1
Loaded by ID: /tmp/tmpr_ma5f_f/Model/experiment_1
Overwriting with Backup#
By default, overwriting requires explicit permission and creates backups. Change the behavior by changing ot.StorageBase.Backup=True/False
my_model.save(work_dir / "my_first_model", overwrite=True)
[PosixPath('/tmp/tmpr_ma5f_f/my_first_model/.envrc')]
Archiving for Sharing#
Use archive=True to create self-contained copies (replaces symlinks with files).
my_model.save(work_dir / "archived", archive=True, overwrite=True)
[PosixPath('/tmp/tmpr_ma5f_f/archived/.envrc')]
Roundtrip: Save and Load#
All storage classes support complete roundtrip (save → load → identical object). The __repr__ output shows how to reload objects:
print(my_model)
# Output shows: Model.from_folder('/path/to/repr_example')
Model id: 20260323_113702_097341
   Model(saved to: file:///tmp/tmpr_ma5f_f/archived)
Advanced Topics#
The following sections cover advanced storage concepts and internal behavior.
Storage Principles Overview#
The storage system follows these core principles:
  • Object-centric design: Work with Python objects; files are technical artifacts
  • Never overwrites originals: file → (copy) → object → new file (by default)
  • Cascading storage: Saving a parent (Model) automatically saves children
  • Deepcopy-aware: Copied objects get new, independent save targets
  • UserPath: Set StorageBase.Userpath for organized, ID-based storage
Inspecting Save Status#
Objects track their save state through several properties.
model_status = ot.Model(project=project, meshes=meshes)
print("Before saving:")
print(f"  is_saved: {model_status.is_saved}")
print(f"  active_target: {model_status.active_target}")
print(f"  next_target: {model_status.next_target}")
model_status.save(work_dir / "status_example")
print("\nAfter saving:")
Before saving:
  is_saved: False
  active_target: None
  next_target: /tmp/ogstools_root/Model/20260323_113702_305268
After saving:
  is_saved: True
  active_target: /tmp/tmpr_ma5f_f/status_example
Object-Centric Design: Files as Technical Artifacts#
OGSTools follows an object-centric philosophy: you work with Model objects, and files are just technical artifacts created when needed.
# Load and work with objects in memory
model_obj = ot.Model(project=ot.Project(input_file=prj_path), meshes=meshes)
# Files are created only when you explicitly save
model_obj.save(work_dir / "model_artifact")
print(f"Files created at: {model_obj.active_target}")
Files created at: /tmp/tmpr_ma5f_f/model_artifact
Cascading Storage: Hierarchical Save Propagation#
Saving a Model automatically saves all children (Project, Meshes, Execution).
model_cascade = ot.Model(
    meshes=ot.Meshes.from_gmsh(rect(n_edge_cells=5)),
print(f"Before save - Meshes is_saved: {model_cascade.meshes.is_saved}")
print(f"Before save - Project is_saved: {model_cascade.project.is_saved}")
model_cascade.save(work_dir / "cascade_model")
print(f"After save - Meshes is_saved: {model_cascade.meshes.is_saved}")
print(f"After save - Project is_saved: {model_cascade.project.is_saved}")
print("All components saved under the Model folder!")
# Show the folder structure
print("\nFolder structure created:")
for item in sorted((work_dir / "cascade_model").rglob("*")):
    if item.is_file():
        rel_path = item.relative_to(work_dir / "cascade_model")
        print(f"  {rel_path}")
Before save - Meshes is_saved: False
Before save - Project is_saved: False
After save - Meshes is_saved: True
After save - Project is_saved: True
  .envrc
  execution.yaml
  meshes/bottom.vtu
  meshes/domain.vtu
  meshes/left.vtu
  meshes/meta.yaml
  meshes/right.vtu
  meshes/top.vtu
  project/default.prj
Control Child Storage: Pre-specifying Child Targets#
You can control where children are saved by specifying their targets BEFORE saving the parent. This is useful for sharing components between models.
# Create meshes and save to a shared location first
shared_meshes = ot.Meshes.from_gmsh(rect(n_edge_cells=6))
shared_meshes.save(work_dir / "shared_meshes")
print(f"Meshes saved to: {shared_meshes.active_target}")
# Create a model with the pre-saved meshes
model_controlled = ot.Model(
    project=ot.Project(input_file=prj_path), meshes=shared_meshes
print("\nBefore Model.save():")
print(f"  Meshes user_specified_target: {shared_meshes.user_specified_target}")
# Save the model - meshes location is respected, not moved!
# It would be fine to decide here (short before model.save()) where to store the children (e.g. meshes)
model_controlled.save(work_dir / "controlled_model")
print("\nAfter Model.save():")
print(f"  Model saved to: {model_controlled.active_target}")
print(f"  Meshes still at: {model_controlled.meshes.active_target}")
print("  Meshes NOT moved into Model folder - pre-specified target respected!")
# Show both folder structures to illustrate the separation
print("\nModel folder structure:")
for item in sorted((work_dir / "controlled_model").rglob("*")):
    if item.is_file():
        rel_path = item.relative_to(work_dir / "controlled_model")
        print(f"  controlled_model/{rel_path}")
print("\nShared meshes folder (separate location):")
for item in sorted((work_dir / "shared_meshes").rglob("*")):
    if item.is_file():
        rel_path = item.relative_to(work_dir / "shared_meshes")
        print(f"  shared_meshes/{rel_path}")
Meshes saved to: /tmp/tmpr_ma5f_f/shared_meshes
  Meshes user_specified_target: True
After Model.save():
  Model saved to: /tmp/tmpr_ma5f_f/controlled_model
  Meshes still at: /tmp/tmpr_ma5f_f/shared_meshes
  controlled_model/.envrc
  controlled_model/execution.yaml
  controlled_model/project/default.prj
  shared_meshes/bottom.vtu
  shared_meshes/domain.vtu
  shared_meshes/left.vtu
  shared_meshes/meta.yaml
  shared_meshes/right.vtu
  shared_meshes/top.vtu
Deepcopy-Aware: Independent Storage for Copies#
Deepcopy creates an independent Model with a new save target.
from copy import deepcopy
original = ot.Model(project=project, meshes=meshes)
original.save(work_dir / "original_model")
copied = deepcopy(original)
print(f"Copy is_saved: {copied.is_saved}")  # False - needs its own save
copied.save(work_dir / "copied_model")
print(f"Original: {original.active_target}")
print(f"Copy: {copied.active_target}")
# Show both folders exist independently
print("\nBoth models exist independently:")
print(f"  original_model/ exists: {(work_dir / 'original_model').exists()}")
print(f"  copied_model/ exists: {(work_dir / 'copied_model').exists()}")
Copy is_saved: False
Original: /tmp/tmpr_ma5f_f/original_model
Copy: /tmp/tmpr_ma5f_f/copied_model
  original_model/ exists: True
  copied_model/ exists: True
UserPath and Organized Storage#
Setting UserPath creates organized, class-specific subdirectories for IDs.
ot.StorageBase.Userpath = work_dir / "organized"
# Do this always in the beginning and do not change it in the middle of your workflow.
# It is recommended to have a variable name similar to the id.
model_experiment_A = ot.Model(project=project, meshes=meshes, id="experiment_A")
model_experiment_A.save()
print(f"Saved to: {model_experiment_A.active_target}")
# Show the organized folder structure with class-specific subdirectories
print("\nUserPath folder structure:")
for item in sorted((work_dir / "organized").rglob("*")):
    rel_path = item.relative_to(work_dir / "organized")
    indent = "  " * (len(rel_path.parts) - 1)
    if item.is_dir():
        print(f"{indent}{rel_path.name}/")
        print(f"{indent}{rel_path.name}")
Saved to: /tmp/tmpr_ma5f_f/organized/Model/experiment_A
Model/
  experiment_A/
    .envrc
    execution.yaml
    meshes/
    project/
## Roundtrip Methods
Saving and loading methods for each class:
  • ogstools.Model: .save() → Model.from_folder(path) / Model.from_id(id)
  • ogstools.Simulation: .save() → Simulation.from_folder(path) / Simulation.from_id(id)
  • ogstools.Meshes: .save() → Meshes.from_folder(path) / Meshes.from_file(meta)
  • ogstools.Project: .save() → Project(input_file=path)
  • ogstools.MeshSeries: .save() → MeshSeries(filepath=path)
  • ogstools.Execution: .save() → Execution.from_file(path)
Total running time of the script: (0 minutes 0.984 seconds)
