Visualizing 2D model data#
For this example we load a 2D meshseries from within the meshplotlib
examples. In the meshplotlib.setup we can provide a dictionary to map names
to material ids. First, let’s plot the material ids (cell_data). Per default in
the setup, this will automatically show the element edges.
from ogstools.propertylib import properties
mpl.setup.reset()
mpl.setup.length.output_unit = "km"
mpl.setup.material_names = {i + 1: f"Layer {i+1}" for i in range(26)}
mesh = examples.load_meshseries_THM_2D_PVD().read(1)
fig = mpl.plot(mesh, properties.material_id)
Now, let’s plot the temperature field (point_data) at the first timestep. The default temperature property from the propertylib reads the temperature data as Kelvin and converts them to degrees Celsius.
fig = mpl.plot(mesh, properties.temperature)
We can also plot components of vector properties:
fig = mpl.plot(mesh, properties.displacement[0])
fig = mpl.plot(mesh, properties.displacement[1])
This example has hydraulically deactivated subdomains:
fig = mpl.plot(mesh, properties.pressure.get_mask())
Let’s plot the fluid velocity field.
fig = mpl.plot(mesh, properties.velocity)
Let’s plot it again, this time log-scaled.
mpl.setup.log_scaled = True
mpl.setup.p_min = -8
Total running time of the script: (0 minutes 8.276 seconds)
