Convergence study (spatial refinement)#
from ogs6py import ogs
from ogstools import (
examples,
meshlib,
meshplotlib,
msh2vtu,
propertylib,
workflow,
meshplotlib.setup.reset()
temp_dir = Path(mkdtemp(suffix="steady_state_diffusion"))
report_name = str(temp_dir / "report.ipynb")
result_paths = []
The meshes and their boundaries are generated easily via gmsh and
ogstools.msh2vtu.
Then we run the different simulations with increasingly fine spatial
discretization via ogs6py and store the results for the convergence study.
refinements = 6
msh_path = temp_dir / "square.msh"
meshlib.gmsh_meshing.rect(
msh2vtu.msh2vtu(filename=msh_path, output_path=temp_dir, log_level="ERROR")
model = ogs.OGS(
PROJECT_FILE=temp_dir / "default.prj",
INPUT_FILE=examples.prj_steady_state_diffusion,
ogs_args = f"-m {temp_dir} -o {temp_dir}"
result_paths += [str(temp_dir / (prefix + ".pvd"))]
OGS finished with project file /tmp/tmpe0tqiu00steady_state_diffusion/default.prj.
Execution took 0.16755294799804688 s
Execution took 0.16966700553894043 s
Execution took 0.16870975494384766 s
Execution took 0.17183709144592285 s
Execution took 0.1815049648284912 s
Execution took 0.17935800552368164 s
analytical_solution_path = temp_dir / "analytical_solution.vtu"
solution = examples.analytical_diffusion(
meshlib.MeshSeries(result_paths[-1]).read(0)
meshplotlib.setup.show_element_edges = True
fig = meshplotlib.plot(solution, propertylib.properties.hydraulic_height)
output_name=report_name,
mesh_paths=result_paths,
property_name="hydraulic_height",
timevalue=1,
refinement_ratio=2.0,
Darcy velocity convergence#
property_name="velocity",
timevalue=1,
Total running time of the script: (0 minutes 24.679 seconds)
